Full time bearing seals #2736407
01/25/20 08:40 AM
01/25/20 08:40 AM
Conway, SC
T2R9 Offline OP
T2R9  Offline OP
Conway, SC
78 W150
When I disassembled the axle bearings there was no seals inside the knuckle against the axle shaft. The shop manual shows a slinger, (which I have) a lip seal and a cup that the lip seal sits in. The lip seal is available and I have them. The cup is no where to be found but a seal is available that I purchased. Question is. Does this seal replace the lip seal and if so does the seals lip face the bearing with the axle riding in it? Thanks
I figured it out. Thanks
Re: Full time bearing seals [Re: T2R9] #2737107
01/27/20 03:22 PM
01/27/20 03:22 PM
N
NITROUSN Offline
NITROUSN  Offline
N
That style will have a slinger pressed on the outer axle, then a rubber seal. The axle goes in and a cup like part is set into the knuckle at a precise depth.
Re: Full time bearing seals [Re: T2R9] #2737110
01/27/20 03:28 PM
01/27/20 03:28 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Here is a source of parts you need. parts
