70 B body steering column ground cable
#2736185
01/24/20 03:50 PM
01/24/20 03:50 PM
Posts: 2,120 New Mexico
JMCFAN
New Mexico
Where does it attach? I have it... was in one of the boxes with all other stuff.. lol
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
Re: 70 B body steering column ground cable
[Re: burdar]
#2736208
01/24/20 04:58 PM
01/24/20 04:58 PM
JMCFAN
New Mexico
If a B-body is like my A-body, it just attaches to one of the dash frame studs.(the upper studs that hold the column to the dash frame) The upper column bracket has white plastic bushings on it where the column mounts to the dash frame so it's insulated from a ground. My Challenger doesn't use any of those plastic bushings so no ground wire was used. Thanks! anthe the other end to the dash frame?
[Re: burdar]
#2736217
01/24/20 05:16 PM
01/24/20 05:16 PM
JMCFAN
New Mexico
Yes The stud on the dash frame. Install the nut to hold the column in place, then another nut to hold the ground wire.(this is how it was on my 68 A-body) Awesome thank!!
