69 Roadrunner Interior Panel Fitment Issue #2735707
01/22/20 11:12 PM
01/22/20 11:12 PM
California
BigDaddy440 Offline OP
California
Not even sure what the correct name is for this panel, but I'm having some issues installing both sides in my 69 roadrunner, and would appreciate any advice or knowledge on the subject.
THE PART:
Somewhere along the way of restoring my 69 Roadrunner (post car) I misplaced both these panels. The ones I'm using now (pictured) are not the originals. I bought them through Moparts and had them repainted without test fitting them. I figured they'd fit, I mean why wouldn't they? (was my thinking)
THE PROBLEM:
They look like the right part and fit into place, BUT in order to line up the screw holes along the bottom edge of the panel for a proper fit, the panel sits a bit too high and absolutely makes contact with the chrome latch that pops the window in and out.
THINGS I'VE CONSIDERED:
1) I might have purchased a set of 68 or 70 panels, and the 69 versions are different, and so these won't ever fit.
2) I installed the rear pop-out windows incorrectly so the latch isn't correctly placed causing the entire issue.
Here are more photos that might help with seeing the issue. Any helpful advice would be awesome.
Other side, but you can see how I have the pop out window mounted:
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: 69 Roadrunner Interior Panel Fitment Issue [Re: BigDaddy440] #2735708
01/22/20 11:20 PM
01/22/20 11:20 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Possibly you have ones for a hardtop with crank down windows. Just a thought.
Re: 69 Roadrunner Interior Panel Fitment Issue [Re: NITROUSN] #2735722
01/23/20 01:34 AM
01/23/20 01:34 AM
California
California
I appreciate that. These here have the void for the post, so I know they're not for a hardtop car. Thanks though!
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: 69 Roadrunner Interior Panel Fitment Issue [Re: BigDaddy440] #2735725
01/23/20 01:40 AM
01/23/20 01:40 AM
Illinois
sixbbl 69 Offline
sixbbl 69  Offline
Illinois
could be for a dodge. they are different.
Re: 69 Roadrunner Interior Panel Fitment Issue [Re: sixbbl 69] #2735728
01/23/20 02:02 AM
01/23/20 02:02 AM
California
California
Interesting....if so, very well may be the answer! Thank you.
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: 69 Roadrunner Interior Panel Fitment Issue [Re: BigDaddy440] #2735828
01/23/20 01:10 PM
01/23/20 01:10 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Yup, Dodge Coronet; they're longer because of the wheelbase.
Re: 69 Roadrunner Interior Panel Fitment Issue [Re: topside] #2735867
01/23/20 04:03 PM
01/23/20 04:03 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
Just like the vinyl top molding the dodge is slightly longer than plymouth
Re: 69 Roadrunner Interior Panel Fitment Issue [Re: mopargem] #2735874
01/23/20 04:30 PM
01/23/20 04:30 PM
BRIDGEWATER, CT.
WINGNUT Online content
WINGNUT  Online Content
BRIDGEWATER, CT.
The pop-out windows are longer on a Dodge than on a Plymouth too. WINGNUT
Re: 69 Roadrunner Interior Panel Fitment Issue [Re: WINGNUT] #2736019
01/24/20 04:24 AM
01/24/20 04:24 AM
California
California
Thank you guys. It seems the issue is that I bought Dodge panels rather than Plymouth. I won't tell you how long I've been scratching my head and trying to figure out what I was doing wrong...should have asked here sooner. Thank you MOPARTS, and thank you Sixbbl 69 for recognizing the likely issue.
-Dan
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: 69 Roadrunner Interior Panel Fitment Issue [Re: BigDaddy440] #2736091
01/24/20 12:27 PM
01/24/20 12:27 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
The glass is the same, the roof gutter trim is the same, the roof skin is the same Coronet to Satllite.
The vinyl top trim is different and the side chrome around the top opening is different Coronet to Satellite.
The difference is the angle from the door jamb to the corner of the window opening. So where the window fuzzies mount is at a different angle.Coronets go up higher. Looks like you have one dodge and one Plymouth panel.
Since the other side fits correctly, measure from the bottom edge straight up to the highest point on the panel. And compare
A hardtop panel won’t fit where a coupe panel belongs because coupe has cutouts.
Re: 69 Roadrunner Interior Panel Fitment Issue [Re: NANKET] #2736334
01/24/20 10:51 PM
01/24/20 10:51 PM
California
California
Neither right or left fit, they're are matching panels. I showed pictures of the passenger side of the car (without the panel) so members could see how my pop out windows were installed.
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: 69 Roadrunner Interior Panel Fitment Issue [Re: BigDaddy440] #2736335
01/24/20 11:00 PM
01/24/20 11:00 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
HT vs Coupe is easy to tell because Coupe panels have the provision for the B-pillar.
Re: 69 Roadrunner Interior Panel Fitment Issue [Re: topside] #2736471
01/25/20 12:28 PM
01/25/20 12:28 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
I have a spare set. Did not know there was difference Dodge vs. Plymouth. If you can tell me how to confirm they are Plymouth I would be happy to sell them.
Maybe you can post or PM me some dimensions of the ones you have. Joe
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 69 Roadrunner Interior Panel Fitment Issue [Re: 70gtx440dana] #2736597
01/25/20 06:18 PM
01/25/20 06:18 PM
California
California
Thank you Joe. I didn't know there was difference either. Nearly all other interior parts are shared. Shortly after posting, a moparts member offered to send me a clean plymouth set, so I think I'll be okay.
I'll post side by side pictures to note the differences when I can.
-Dan
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: 69 Roadrunner Interior Panel Fitment Issue [Re: BigDaddy440] #2739060
02/02/20 03:22 PM
02/02/20 03:22 PM
California
California
I received a pair of correct Plymouth panels from a very cool and friendly Moparts member (Hemirdrnnr).
At first glance I didn't see the difference, because I was looking at the overall length, which is actually the same. The difference (as shown in the photo below) is that the Dodge panel is taller / higher. This explains why my pop out window latches are making contact with the incorrect Dodge panels and won't work / fit correctly.
Thanks again to all involved in finding the much needed answer to this issue!
-Dan
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: 69 Roadrunner Interior Panel Fitment Issue [Re: BigDaddy440] #2739092
02/02/20 04:49 PM
02/02/20 04:49 PM
Lansing, MI
Lansing, MI
Great info....never would have guessed.
