Re: Aluminum 8 3/4 center section P4876445
[Re: jcc]
#2735449
01/21/20 10:47 PM
01/21/20 10:47 PM
Posts: 16,479 Canada
CrAzYMoPaRGuY
Canada
I hope I'm overbuilding...? lol 3000 pound 650hp 650 ft lb street car. Footbraked
I'll tie the front and back of housing together. Never thought of that.....
And I got a deal tooooo good to pass up, so I picked it up.... will see I guess.....
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#2735453
01/21/20 10:57 PM
01/21/20 10:57 PM
Posts: 9,456 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Good luck but its kinda like building a motor around a sub standard camshaft. Flip it and get the proper one.
STOP POTATO HATE!
[Re: Mr PotatoHead]
#2735463
01/22/20 12:01 AM
01/22/20 12:01 AM
CrAzYMoPaRGuY
Canada
Good luck but its kinda like building a motor around a sub standard camshaft. Flip it and get the proper one. I believe I have the proper one. You might like Ford9"s. I have had DISASTEROUS results with Ford 9"s, no thanks!!! Everybody has their own version of "substandard" camshafts. the successful guys use what works for THEM...!
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#2735467
01/22/20 12:14 AM
01/22/20 12:14 AM
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Im just giving you a hard time, I hope it works as you need it to. Hell,id buy one of it were cheap just to have one.
STOP POTATO HATE!
[Re: CrAzYMoPaRGuY]
#2735559
01/22/20 12:11 PM
01/22/20 12:11 PM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
Your 9" issues likely were due to using too many factory ford parts. Everything but the housing needs to be bought aftermarket...and the housing needs a backbrace. Once you buy a GOOD centersection, you shouldn't have any problems. 9" are strong when built right, they just aint cheap.
[Re: an8sec70cuda]
#2735716
01/23/20 01:08 AM
01/23/20 01:08 AM
CrAzYMoPaRGuY
Canada
Your 9" issues likely were due to using too many factory ford parts. Everything but the housing needs to be bought aftermarket...and the housing needs a backbrace. Once you buy a GOOD centersection, you shouldn't have any problems. 9" are strong when built right, they just aint cheap. Couldn't agree more, but I learned the "Ford" needs to be taken out of the "Ford 9"" after I sold the car. I have a brandX car with a big buck aftermarket 9', no problems at all.
CrAzYMoPaRGuY
[Re: 340Cuda]
#2735717
01/23/20 01:12 AM
01/23/20 01:12 AM
CrAzYMoPaRGuY
Canada
If nothing else its is sure good looking!
Sounds like if it does not work for you, there won't be much money lost.
Good luck and keep us posted. I got the case brand new through a dealership, $835 US. Hope it lasts the life of the car, I'll give it a chance for sure. I'll Dana the car no problem if need be, but I think I can get it to live. If I'm lucky..... lol
CrAzYMoPaRGuY
