Wrinkle Black Air Cleaner #2735216
01/21/20 10:53 AM
01/21/20 10:53 AM
Kentucky USA
RR6BBL1969 Offline OP
Kentucky USA
I need to freshen up a 1969 stock round air cleaner with the wrinkle black texture. I'm thinking to sand blast it clean, primer, and then a spray can of wrinkle black paint from Harley-Davidson. Any other or better suggestions?
Re: Wrinkle Black Air Cleaner [Re: RR6BBL1969] #2735226
01/21/20 11:21 AM
01/21/20 11:21 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I've used VHT wrinkle paint with good results but I think powder coating is going to give you the best finish. If you really want to spray paint it, baking it in an oven will even out the wrinkle and make the paint harder.
Re: Wrinkle Black Air Cleaner [Re: burdar] #2735241
01/21/20 11:58 AM
01/21/20 11:58 AM
Kentucky USA
Kentucky USA
Thank you.
Re: Wrinkle Black Air Cleaner [Re: RR6BBL1969] #2735259
01/21/20 12:51 PM
01/21/20 12:51 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Pre-heating is a good idea, and a heat gun works well during application.
I like to spray a coat of flat or semi gloss black before the wrinkle paint, so I can focus on texture.
Re: Wrinkle Black Air Cleaner [Re: burdar] #2735367
01/21/20 06:36 PM
01/21/20 06:36 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
I had good success with the VHT product as well.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Wrinkle Black Air Cleaner [Re: 70gtx440dana] #2735413
01/21/20 08:50 PM
01/21/20 08:50 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
VHT or Plasti-Kote( if they're still around. Placing on top of a heater will speed the process and cure it at the same time (after cooling) Even application / coats is the key to an even wrinkled finish twocents beer
Re: Wrinkle Black Air Cleaner [Re: TJP] #2735425
01/21/20 09:08 PM
01/21/20 09:08 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
I used VHT about 8-9 years ago and it still looks brand new. From what I found, heat is the most important aspect to the paint working as intended and getting an even finish.
I painted mine in the basement during Winter. The temp in the basement was around 55 but, I had two heaters pointing directly at the air cleaner. I think I would have had better results with even heat; like the temp in the room being 80 or doing it out in the sun, etc.
