Re: Paint job on a budget!? CONTINUED..page 44........
[Re: 78D150CLUB]
#27338
04/10/07 12:17 AM
04/10/07 12:17 AM
Posts: 13 toronto, ohio
andyoucankeepit
toronto, ohio
i ended up buying the aluminum but havent had time to experiment with it yet. are any of the other colors of silvers working for anyone? there is a stainless steel, and i think a pewter. i wanted to go with a lighter silver, so i picked aluminum. maybe the mixxing of spray can metallics between coats comes out good....i might attempt that.
03 cobra, 85 mustang, 59 galaxie, 68 sportster
[Re: 78D150CLUB]
#27339
04/10/07 09:31 AM
04/10/07 09:31 AM
Hmm, I could not find the post on the aluminum paint. Does anyone have experience with it? I wonder if you could mix the alumninum with a light grey and get silver. The other option I have found is to use some pearl additive to get at metallic effect. Something like this http://www.paintwithpearl.com/Pearls/silver/silverpics.htmbut I think you would need to add the pearl material to a base color and cut the base and pearl mixture with some clear. Anyone been able to find or use the rustoleum clear? I have been to the local Lowes and Home Depot and they don't have clear. Thanks, Nathan
#27340
04/10/07 02:05 PM
04/10/07 02:05 PM
Very nice.... although, I wouldn't wait too long before polishing, it's actualy a little easier while the paint is still 'soft'. I did my truck after about 48 hours, looks like a red mirror.
#27341
04/10/07 06:30 PM
04/10/07 06:30 PM
Aussie- Have been following Brightside posts with great interest. Last weekend I switched to Brightside dark blue after failing at perfection with Rustoleum. I added penetrol only in first couple of coats and was stunned how it flowed out. Last night, I unscientifically added more, maybe 50% and it came out like crap. Very mottled/orange peely. What percentage have you determined to be the best ? Are you also adding Mineral Spirits ? Also, has anyone found a good way of toning down the Brightside Fire Red with out making it look like a muddy mess ? Thanks, AL
[Re: 78D150CLUB]
#27342
04/10/07 06:32 PM
04/10/07 06:32 PM
I didn't do a spray can job as such, I just applied enough between layers of TremClad to add the sparkle without adding any color, then applied the next layer over and wetsanded. Beware of aluminium paint, it's mentioned in earlier posts as being totally different to work with and it doesn't sand or polish like regular TremClad does. IIRC, it's not a good base to paint over, either.
id really like to see some pics of your progress if u could
#27343
04/10/07 08:16 PM
04/10/07 08:16 PM
Thanks,
AL
I use a slightly different method to most people when it comes to thinning the paint. A couple of years ago I bought a piece-of-crap electric sprayer which came with a little cup with a hole in the bottom of it. The cup is dipped into the paint and you then time how long it takes for the cup to empty.
I have been using this method. I usually add about 400ml of paint, then about 100ml of Penetrol and then I add mineral spirits until I get a total cup flow time of 30 seconds. Once I'm at the 30 second mark, I'm ready to paint.
And I'm really happy that the plastic cup is more useful than the piece-of-crap electric sprayer.....
#27344
04/10/07 08:29 PM
04/10/07 08:29 PM
Posts: 1,475 Ontario, Canada
78D150CLUB
My avatar is a self portrait!!
Ontario, Canada
My truck has been done for about 6-8 months, but if you do a username search, you'll be able to see the pics I took during the process. Not the best quality, but I took Exit1965's advice and bought a better camera with the cash saved on the paint job The metallic doesn't show too well in a pic, but it's quite noticeable in sunlight. If we ever get any here, I'll wash the winter glop off and take a few new ones. This is during finishing stages last July\August.
I want to die like my Grampa, peacefully, in his sleep. Not screaming in terror like his passengers.
#27345
04/11/07 11:52 AM
04/11/07 11:52 AM
Aussie- Have been following Brightside posts with great interest. Last weekend I switched to Brightside dark blue after failing at perfection with Rustoleum. I added penetrol only in first couple of coats and was stunned how it flowed out. Last night, I unscientifically added more, maybe 50% and it came out like crap. Very mottled/orange peely. What percentage have you determined to be the best ? Are you also adding Mineral Spirits ? Thanks,
AL
I think that viscosity cup would be a great tool for our purposes. I can't seem to find one though. I had to use the method 69DartGt used: "... the second and later coats I thinned until after I stirred and picked the stir stick up out of the paint I could count to about 10 then the paint would go from a stream to drops if that makes sense. The paint seemed to lay down better much less orangepeel and no rolls, I had to do a lot of sanding after my first coat to get it to were I could paint again."
#27346
04/11/07 02:23 PM
04/11/07 02:23 PM
Posts: 133 Orange County, CA
Jolly_Raj_R
Orange County, CA
I did some poking around on the web and apparently the proper name for the viscosity cup you're talking about is a "Zahn Cup"... You measure the time it takes to empty the cup.. It's worth a search with the official name to see if they sell them outright.. According to Wikipedia its a common enough thing in the painting industry..
hope that helps
Raj ...maybe pulling an Exit1965 and painting his car white this summer..
[Re: Jolly_Raj_R]
#27347
04/12/07 01:58 PM
04/12/07 01:58 PM
Ok, so I am going to try this again now that the weather has stabilized. I am going with the Brightside and I have a couple questions. 1. has anyone laid Brightside over SEM self etching primer or any other self etching primer? 2. If so were there any adhesion issues? 3. Do I thin the Bright side or let it roll full strength? Thanks!!!!!
#27348
04/12/07 05:34 PM
04/12/07 05:34 PM
#27349
04/12/07 07:23 PM
04/12/07 07:23 PM
someone used it with his Van Sickle paint. actually had some nice results.
_taF
[Re: Radio Joe]
#27350
04/12/07 10:24 PM
04/12/07 10:24 PM
Posts: 26 Texas
texczech
Texas
I always seemed to have the dirt specks, but it was only a minor detail because I was concerned with thinning,smooth application,roller type etc...Now I am convinced that this is for real. I am using brightside and I have tried straight, thinned,with the reccommended thinner and other stuff- still pleased with the shine.The specks are my main problem now. I got a medium clay bar and it did take the specks out- you could feel them before, and after the clay bar you couldn't feel them , but see the spots where they were.I am now trying to lessen the speck effect. I think that since the brightside dries so slow, dirt has a chance to settle and affect the paint more so than if the paint dried faster. IF I could lessen the "dirt" speck problem, I would be fairly well satisfied with the final finsh, even with some orange peel.I'm thinking that on my earlier coats I didn't give the dirt specks enough attention and kept rolling over them and maginfying their effect. I would really like to hear from others who may have had to deal with this, if they had this.
[Re: texczech]
#27351
04/12/07 11:55 PM
04/12/07 11:55 PM
I've been painting with Rustoleum pro outside and have also had some issues with dirt specks and pollen in the paint.
I've noticed that if the paint is just the least bit tacky when the dirt hits it, it sort of sits up on top of the paint and doesn't really get "in" the paint. When the paint sets up the dirt and muck is pretty easily removed without any flaws in the paint. Usually don't need sandpaper to do it, just wet it all down and run my hand over it or a fingernail to remove it. It hasn't been a real problem.
[Re: texczech]
#27353
04/13/07 11:16 AM
04/13/07 11:16 AM
A clean garage helps (if you have one available.) I took a leaf blower to mine; blew out all the dust one day, did it again the next day. I then took a hose and sprayed water on the floor. Someone in a previous post recommended attaching a chain to the car to ground it and keep it from attracting dust. I got a kick out of the coach painting site: (http://www.stephen.hull.btinternet.co.uk/paint.html.) He said,"It's not unknown for the coach painter to go to extreme lengths in order to obtain the cleanest possible finish by wearing lint free overalls or simply just shorts and covering the human body with Linseed oil, this will stop human body fallout elliminating skin dust, hair, fluff etc from falling and contaminating freshly painted panels." I don't think we wanna go that far...I'm trying to erase this image of us all oiled up, wearing nothing but German lederhosen shorts and carrying a roller!
[Re: 78D150CLUB]
#27356
04/14/07 12:01 PM
04/14/07 12:01 PM
yeah, i've read on here how some ppl did it in some public parking lot or even in the parking lot of their apartment residence, even next to other cars. idk how they can do that. i wonder if they were ever complained on. i'm still in the process of painting mine, but there is so much mess and paint marks i can't remove.
_taF
#27357
04/14/07 08:05 PM
04/14/07 08:05 PM
Roller painting tubing ? anyone done it ? I need to paint black gloss on the tubes of a dragster I did half of it today with spray cans , sanded down the old flacking paint /rust and then spray bombing it so that it would not rust again, But I need it to be a better finish on the areas you see that is not covered by the aluminum panels. I am afraid it I really thin it out that the paint will go around the tube and start dripping, Any ideas or is iot better to get out the compressor thanks Beaulieu
