What does this spare wheel/tire assembly belong to? #2734992
01/20/20 03:59 PM
01/20/20 03:59 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Not sure if this is a factory spare or aftermarket? Date on the rim by the valve step appears to be M68 and it's a Goodyear F70-14. Did Chrysler offer a thin white wall tire? Not sure if the it belongs to a 69 B-Body?
Spare Wheel Assembly_4.jpgSpare Wheel Assembly_3.jpgSpare Wheel Assembly.jpgSpare Wheel Assembly_2.jpg
Re: What does this spare wheel/tire assembly belong to? [Re: vinnyd76] #2735005
01/20/20 04:30 PM
01/20/20 04:30 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
You could get either red or white stripes in the F70 size.
Does sidewall have "Speedway Wide Tread" on it ?
Re: What does this spare wheel/tire assembly belong to? [Re: topside] #2735016
01/20/20 05:19 PM
01/20/20 05:19 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
M38 11 = Motor Wheel * Plant #3 * 1968 * November ….. what's on the other side of the valve stem?
the tire is dated 411 = 41st week of 1971
the T86 "white streak" Goodyear Polyglas F70-14 was not available for a '69 B-body - it was available on 1970-'71 B&E-bodies
Re: What does this spare wheel/tire assembly belong to? [Re: 6bblgt] #2735029
01/20/20 05:52 PM
01/20/20 05:52 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Thank you for the info and quick response! I believe the other numbers are 13 55
Re: What does this spare wheel/tire assembly belong to? [Re: vinnyd76] #2735032
01/20/20 06:16 PM
01/20/20 06:16 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
…. November 13, 1968 14x5.5" wide wheel
