Re: "removable" radiator core support question [Re: 5thAve] #2735090
01/20/20 10:37 PM
01/20/20 10:37 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I guess I don't understand why? shruggy
I have a normal engine hoist and a deep sump pan on my RB and can easily clear the yoke. If I needed more room or had a hoist that wouldn't go up as high as I needed, I'd unbolt the front wheels and let the car down on a floor jack. wrench
Besides, grille is going to be in the way too!
'63 Dodge 330
11.19 @ 121 mph
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
Re: "removable" radiator core support question [Re: GY3] #2735188
01/21/20 09:03 AM
01/21/20 09:03 AM
moparx Offline OP
moparx  Offline OP
good point !
beer
Re: "removable" radiator core support question [Re: GY3] #2735238
01/21/20 11:50 AM
01/21/20 11:50 AM
Here
jcc Online content
jcc  Online Content
Here
1. Every car is different
2. When doing a swap with trans attached, by your self, it helps
3. And the extra 8"? until you get to the grill, which also is fairly easy to remove, makes a big difference
4. Nobody has yet made the case other then VIN number there is a real downside.
" All sorts of things can happen when you are open to new Ideas" Inventor of Kevlar
Re: "removable" radiator core support question [Re: jcc] #2735511
01/22/20 09:09 AM
01/22/20 09:09 AM
moparx Offline OP
moparx  Offline OP
another thing to remember with this particular setup, i moved the radiator to the front of the core support because it is a huge crossflow unit, and there is a bunch of room that is unused from the backside of the grille to the front side of the support. the removable support like Andy showed on his coronet will work perfectly for radiator R&R, as well as any future engine work if needed.
as to the numbers on the top portion of the support, they are stamped in an area that is well away from any area that will be cut.
also, the top side is pretty flexible as is. i would like to stiffen that up some if possible.
beer
Re: "removable" radiator core support question [Re: moparx] #2735685
01/22/20 08:58 PM
01/22/20 08:58 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
Welded tabs on then bolted it up. Painted it last so it matches. 68 Valiant 440
