Driven GP-1 oil
#2734086
01/18/20 09:37 AM
01/18/20 09:37 AM
Posts: 8,067 Mt Morris Michigan
mopar dave
Mt Morris Michigan
OMG, another oil thread, yep. I have been looking for a good oil to replace the 15/50 Amsoil I have been using because according to the oil grade/bearing clearance guide I should be using a 10/40 or 15/40 group oil. Amsoil does not offer this group in a racing/flat tappet oil. They did tell me I could use their 10/30 no problem, but i'm uncomfortable with that. My clearances are .029/.033. I just found this GP-1 that is offered in a 15/40 group. They claim in a 383 small block chevy 5hp gain and cooler temps just by changing oil. Either way looks like a good enough oil. Anyone here ever use this stuff? They have my interests.
Re: Driven GP-1 oil
[Re: mopar dave]
#2734127
01/18/20 11:41 AM
01/18/20 11:41 AM
Thumperdart
State of confusion
Been running oil thinner than the "experts" say to do forever and zero issues w/similar clearances as you.........
Re: Driven GP-1 oil
[Re: BradH]
#2734141
01/18/20 12:20 PM
01/18/20 12:20 PM
Posts: 12,289 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
10w30 Amsoil race oil with clearances as big as yours. Can't be squeamish about oil pressure and you need to pay attention to internal oil leaks and excess oil going places other than the crank.
I even tried some 0w30. Oil pressure was too low.
I think tightening up the clearances a half or 3/4 a thou or so and using 10w30 on a bracket style deal is about right.
Re: Driven GP-1 oil
[Re: mopar dave]
#2734205
01/18/20 02:03 PM
01/18/20 02:03 PM
Posts: 4,457 Washington
madscientist
Washington
You should look for oils that DON'T advertise and spend all their time doing articles for webzines and any other place they can get some advertising time.
If you are buying a synthetic and not paying 20 bucks a quart you are wasting your time. The simple fact is quality oil is expensive. And the companies doing it budget very little for advertisement.
Re: Driven GP-1 oil
[Re: mopar dave]
#2734222
01/18/20 03:10 PM
01/18/20 03:10 PM
Thumperdart
State of confusion
Depends but usually Valvoline crude or sync but recently went with Royal Purple 10w30 just because.....
Re: Driven GP-1 oil
[Re: mopar dave]
#2734252
01/18/20 04:47 PM
01/18/20 04:47 PM
Posts: 26,279 United Socialist States of Ame...
tboomer
Since my car sits and only gets fired up once in a while I was thinking of going back to Rotella 15-40. It will be due for an oil change this spring. Currently has Brad Penn in it.
Re: Driven GP-1 oil
[Re: mopar dave]
#2734259
01/18/20 05:13 PM
01/18/20 05:13 PM
Posts: 4,492 northern,Ohio,USA
Clanton
northern,Ohio,USA
With going to a thinner oil do you think about changing the filter to a smaller micron filtering? OMG, another oil thread, yep. I have been looking for a good oil to replace the 15/50 Amsoil I have been using because according to the oil grade/bearing clearance guide I should be using a 10/40 or 15/40 group oil. Amsoil does not offer this group in a racing/flat tappet oil. They did tell me I could use their 10/30 no problem, but i'm uncomfortable with that. My clearances are .029/.033. I just found this GP-1 that is offered in a 15/40 group. They claim in a 383 small block chevy 5hp gain and cooler temps just by changing oil. Either way looks like a good enough oil. Anyone here ever use this stuff? They have my interests.
Re: Driven GP-1 oil
[Re: mopar dave]
#2734293
01/18/20 07:48 PM
01/18/20 07:48 PM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
I think I would have good piece of mind with the 40 grade vs the 30. How much do you think would be gained going from 50 to 30 grade oil. Would really like to know hp differences between the 2. Current oil pressures are 80 cold, 30 hot at idle and 65 hot WOT. Try what you are comfortable with trying and see how it effects the pressure especially at the high rpms. There's a good chance that idle psi drops a little and high rpm pressure increases going to a 15W-40. (when compared with 15W-50 at the same oil temperature) If so, then next change you can try 10W-30 if you want. But if the high rpm pressure drops then of course you don't want to go thinner.
Re: Driven GP-1 oil
[Re: mopar dave]
#2734308
01/18/20 08:45 PM
01/18/20 08:45 PM
Posts: 43,719 Bend,OR USA
Cab_Burge
I use regular, not synthetic, Valvoline 5W20WT in my hot street motors, VR1 10w30Wt in my E85 bracket motor. I like to see at least .0030 on the rods and .0035+ bearing clearances on the mains I've never seen or heard of a rod bearing or main bearing spinning because of to much oil clearances, I have seen that happen with them to tight though
Re: Driven GP-1 oil
[Re: Cab_Burge]
#2734310
01/18/20 08:48 PM
01/18/20 08:48 PM
Posts: 30,632 Florida STAYcation
IcorkSOAK
Financed his waterbed
Florida STAYcation
I use regular, not synthetic, Valvoline 5W20WT in my hot street motors, VR1 10w30Wt in my E85 bracket motor. I like to see at least .0030 on the rods and .0035+ bearing clearances on the mains I've never seen or heard of a rod bearing or main bearing spinning because of to much oil clearances, I have seen that happen with them to tight though Only 3 this time ? .. you get TWO credits !
