Re: Race Engine reality, what works
[Re: dvw]
#2734203
01/18/20 01:59 PM
01/18/20 01:59 PM
Posts: 4,457 Washington
madscientist
Washington
LOL. Most guys don't test correctly.
Most guys don't dyno stuff B2B where you take out many variables.
Most guys have a chassis that is already at its saturation point for power. Any more and it just flexes away any added power.
[Re: dvw]
#2734211
01/18/20 02:22 PM
01/18/20 02:22 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The biggest changes I’ve seen usually revolve around some component that’s either not working right, or isn’t a good match for the rest of the combo.
The biggest differences I’ve seen have come from these items....... but not at all consistently. For each instance where I saw a big change....... there would be dozens where it did nothing.
- cams - carbs - intake manifolds - swapping to a tunnel ram - vacuum pumps - headers
[Re: fast68plymouth]
#2734226
01/18/20 03:18 PM
01/18/20 03:18 PM
Posts: 12,391 Taxes & Virus's R-US, NY
Dragula
Years ago, sealing the carb to the hood. This was worth 1-3mph and +.1 in ET....Nobody believes me on that, but it is true.
For me this 2019, it was upgraded rocker arms and push rods....Was wrecking pushrods and rockers like candy at .680 lift with our new 400/512 combo. Went to Comp SS rockers with more offset on the intakes, and Manton series 5 extreme push rods....Wow...Night and day difference. Never even took the valve covers off this year.
Was using the 440source rockers and pushrods, which worked well for 6 years, but now we are in the low 6's in the 1/8th and finding we needed better parts.
Also, the other biggest gain we netted was working with Thumper on the carb setup and I ported the crap out of the manifold....netted .22 total and 2mph
Last years big gain was calling Hoosier and getting the right slicks for our car....How about a 1.31 60ft!
A while before that, sealed the carb to the hood.....
Things that netted us nothing, but we like anyways: Firecore wires over Procomp generic ones Light weight crank....6lbs lighter Switching from a 440/512 to 400/512 increasing compression from 10.75 to 13 Front facing hood scoop Trans brake PPP shifter Magnefuel 500 pump over a 275
[Re: dvw]
#2734227
01/18/20 03:21 PM
01/18/20 03:21 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
This most likely falls outside of the original topic, but there is no single more important part to having a fast car, than the torque converter.
[Re: TRENDZ]
#2734228
01/18/20 03:30 PM
01/18/20 03:30 PM
Dragula
This most likely falls outside of the original topic, but there is no single more important part to having a fast car, than the torque converter. It is definitely not outside the topic.....Many combos are held back by the wrong or bad torque convertor. This is especially critical to the folks that run a glide....Typically you know when you have the right convertor, but not so the other way around.
[Re: Dragula]
#2734236
01/18/20 03:57 PM
01/18/20 03:57 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Lots of guys like me to spend big money for little gain. Again 95% of us are bracket racers or street n strip guys so thin ring packs, lightweight components, belt drives, and vacuum pumps show little gains. A 5.00 lock ring on your distributor works wonders and is surely cheaper than other options out there. As far as deck plates I personally don’t use them. How long does a dead prefectly machined block in the machine shop stay perfect when the crank is bolted in place with 8 rods and spinning 7200 rpm. Now throw in the “heat factor). What does the block do when at Racing temps. Do you think it stays perfect like in the machine shop. Your guess is as good as mine but I’m thinking no. I like spending around 1000.00 to machine a block and balance an assembly at a shop I trust rather than crazy money making the shop owner rich. If it makes you sleep better at night then go ahead and spend big money. If you are sitting at home because you can’t afford the tricks, maybe it’s time to stop believing the ragazines written by guys that get paid to suggest you spend your hard earned money.
[Re: dvw]
#2734237
01/18/20 03:58 PM
01/18/20 03:58 PM
Posts: 1,099 Massillon, Ohio
cudatom
Massillon, Ohio
Doug, for me what I have found out going with better parts was longevity of the combination. It didn't necessarily pick up many horsepower or run a better number at the strip. However I had less failures.
Now regarding machine work I've always tried to pick shops that have a quality reputation. The reason being same point as above. Quality machine work and parts tends to make a combination last longer. I'm a bracket racer I'm not trying to gain every 10,000th of a second I want a quality combination that is consistent. Yes even good parts fail and good shops make mistakes but over the past 40 years I found that when doing this I spend less time working on my combination.
Ok
[Re: cudatom]
#2734250
01/18/20 04:36 PM
01/18/20 04:36 PM
Posts: 2,861 Pattison Texas
CSK
Pattison Texas
To be Honest the 512 Low deck I built makes about 150 HP MORE than I really thought it would make, Hrdro roller, dingleberry hone job, 440 source heads ported by me using a toy flow bench [Super Flow 110 ] ,wide ring gap on second ring, 9.7 to one compression, most of the ? in dvw's thread is more about longevity of the build IMOP. all that said ,, I love my Dodge Sorry Im sharing in the race section, my junk is Street & sometimes strip. The LARGEST gain I have done was from tuning, also getting rid of a baffled muffler & going to a straight through muffin
[Re: mopar dave]
#2734271
01/18/20 05:49 PM
01/18/20 05:49 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I hope to see what adding over 2 points of compression does this year going from flat tops to dome pistons. I run alcohol so it’s no added cost to try it and the deal on the Pistons was to good to turn down. My last Edelbrock headed 408 ran 9.70’s so I’m looking forward to the results
[Re: TRENDZ]
#2734275
01/18/20 06:14 PM
01/18/20 06:14 PM
Posts: 287 PA
Harry's Taxi 2
PA
This most likely falls outside of the original topic, but there is no single more important part to having a fast car, than the torque converter. I strongly second this one.
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
[Re: CSK]
#2734277
01/18/20 06:20 PM
01/18/20 06:20 PM
Posts: 4,680 Wichita
GY3
Wichita
I have a lighter Molnar rotating assembly (mainly rods, crank weight was the same) and metric pistons rings. I did it mainly because other parts were close to the same $ and it has to be easier on the block.
Again, street/strip brigade here.
[Re: Harry's Taxi 2]
#2734280
01/18/20 06:32 PM
01/18/20 06:32 PM
BradH
This most likely falls outside of the original topic, but there is no single more important part to having a fast car, than the torque converter. I strongly second this one. Same here, even for a dual purpose car. Went from too tight to too loose to just right to finally improve the 60-ft and reign in the slippage on the big end. The difference between the last two converters was .2 and 2 MPH, all the result of reduced slippage. Getting a carburetor that's "happy" with the rest of the combination has shown solid improvements, too. Doesn't have to be any bigger or make more HP if you can improve the shift recovery.
[Re: BradH]
#2734283
01/18/20 06:45 PM
01/18/20 06:45 PM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
Biggest gain for me was cylinder heads . From hand prepped out of box , to CNC (stock port) to current TF270 This was tried on my 440 and 505 RB motors . Solid .25 gain with TF270 over CNC source . Which is about what i expected . This is from engine only , converter also made gains seperatelly .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: Dragula]
#2734291
01/18/20 07:35 PM
01/18/20 07:35 PM
Posts: 2,042 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
For me, it was upgraded rocker arms and push rods....Was wrecking pushrods and rockers like candy at .680 lift with our new 400/512 combo. Went to Comp SS rockers with more offset on the intakes, and Manton series 5 extreme push rods....Wow...Night and day difference. Never even took the valve covers off this year.
This for me also! I wasn't even looking for an improvement when replaced my rocker arms last winter. I was running the old MP blue rocker arms (alum roller, same as the Crane Gold rockers) but I broke another one at the last race of the season. I had a couple of spares, but when I started looking at the broken one and compared it to the other 3 that I had broken in the past few years, they were all broken in the same place. Upon closer inspection (w/ flashlight & magnifying glass) of the other rockers still on the engine, I found that 7 others were in various stages of cracking in the exact same place. At that point, I ordered a new set of Hughes rockers, which also required new push rods (Smith Bros.), After setting up new rockers & push rods, I was extremely impressed by the roller pattern on the valve tip. Fast forward to this season, I finally figured out that the car had picked up WELL over a tenth of a second, closer to 2 tenths. At first, I just thought it was due to the weather, or track conditions or tire pressure or whatever, until I went to Clay City, Ky for the Mopar show in sept, and routinely ran low 10.30's (1/4 mile). I went back to my log book and found it was indeed running quicker than the last few years. Nothing else was changed on the car at all. Had to be the rockers & push rods??
Brian Dunnigan
