Anyone restore fuel tank sending units? #2733851
01/17/20 11:04 AM
01/17/20 11:04 AM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Based on some feedback I've received, today's fuel tank sending units are not reliable/as good as originals. Here are a couple of pics of my original sending units. The copper point/tip has worn over the years and now is impacting the ohm resistance. Anyone repair originals or know if there are rebuild kits available?
If I need to replace with a new one... any recommendations on brand?
Re: Anyone restore fuel tank sending units? [Re: vinnyd76] #2733859
01/17/20 11:49 AM
01/17/20 11:49 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Dad used these guys for his Pontiac sending unit, expensive but worth it when nothing else is available.
https://www.bobsspeedometer.com/1/120/index.asp
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Anyone restore fuel tank sending units? [Re: vinnyd76] #2733888
01/17/20 12:56 PM
01/17/20 12:56 PM
BDW Offline
BDW  Offline
I’d fix that yourself. Solder it up, then use nail file to shape.
Re: Anyone restore fuel tank sending units? [Re: BDW] #2733933
01/17/20 03:12 PM
01/17/20 03:12 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Agree. Fix it or have it fixed.
See the three links in the post below for repairing info.
https://www.forabodiesonly.com/mopa...nding-unit.450810/page-2#post-1972789574
Re: Anyone restore fuel tank sending units? [Re: Mattax] #2734077
01/18/20 08:20 AM
01/18/20 08:20 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
You can fix that yourself. Solder is ok but very soft. Id solder a small piece of copper into the hole and then file the shape. Probably a 18th inch piece of 12 or 14 guage solid wire.
Look closely and you can probably take the arm off easily and then get the wiper to the bench for access.
I've used a company called Sending Unit Repair and Rebuild. Results are hit and miss.
Angry white pureblood male
Re: Anyone restore fuel tank sending units? [Re: ruderunner] #2734304
01/18/20 08:37 PM
01/18/20 08:37 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
One of the posts on A bodies board listed, the guy soldered a brass nail in the hole. that or a small brass screw would probably last a lot longer than the solder by itself work beer
Re: Anyone restore fuel tank sending units? [Re: TJP] #2734318
01/18/20 09:17 PM
01/18/20 09:17 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I wonder how a copper pop rivet would work?
Re: Anyone restore fuel tank sending units? [Re: Sniper] #2734788
01/20/20 09:43 AM
01/20/20 09:43 AM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
I was wondering the same thing, but thinking brass.
RIVETS
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
