Best Gen 3 motor mounts for old cars???
#2733386
01/15/20 03:46 PM
01/15/20 03:46 PM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
What is the best motor mount conversion for 65 Coronet stock K-member 6.1 hemi about 750hp?
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
Re: Best Gen 3 motor mounts for old cars???
[Re: 65 Hemi]
#2733411
01/15/20 05:42 PM
01/15/20 05:42 PM
Posts: 1,115 Usa
A39Coronet
Usa
I don't know if they're the "best" but the TTI mounts were the only ones I could get as Schumacher never answered or returned emails or calls. I will say the TTI's bolted right up a s I had no problem getting the engine in. I paired mine with some Moroso solid mounts, again no issues with fitment.
[Re: A39Coronet]
#2733679
01/16/20 04:38 PM
01/16/20 04:38 PM
Posts: 2,968 Far Northeast.
mymcodebee
Far Northeast.
Do not use these! They split before we even fired the engine!
We switched to the second ones.
These are not my photos as I just grabbed them for reference. I can dig up the photos to show the damage if anyone needs them.
[Re: mymcodebee]
#2733696
01/16/20 06:01 PM
01/16/20 06:01 PM
65 Hemi
San Diego CA
Who makes them? Do not use these! They split before we even fired the engine!
Doug
[Re: mymcodebee]
#2733750
01/16/20 08:55 PM
01/16/20 08:55 PM
Posts: 1,115 Usa
A39Coronet
Usa
These are not my photos as I just grabbed them for reference. I can dig up the photos to show the damage if anyone needs them. Post pics please. What did TTI say when you shared the pics with them? If you can get Schumacher on the horn to place an order, more power to you. He was MIA for me so the TTIs were the only game in down.
[Re: mymcodebee]
#2733815
01/17/20 08:07 AM
01/17/20 08:07 AM
mymcodebee
Far Northeast.
Mancini makes/sells the good ones.
The junk ones came from magnum force. Not sure where they purchased them from..?
[Re: mymcodebee]
#2733895
01/17/20 01:02 PM
01/17/20 01:02 PM
Posts: 2,260 IL
furious70
IL
I'm hoping to do a test fit in my coronet the end of the month, I bought from bouchillon performance. I did have to grind the block on the dr's side a little
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: mymcodebee]
#2733963
01/17/20 06:03 PM
01/17/20 06:03 PM
Posts: 1,115 Usa
A39Coronet
Usa
Mancini makes the good ones. Mancini doesn't make them, they repackage product and are only a vendor.
[Re: furious70]
#2739683
02/04/20 03:21 PM
02/04/20 03:21 PM
Posts: 2,260 IL
furious70
IL
I'm hoping to do a test fit in my coronet the end of the month, I bought from bouchillon performance. I did have to grind the block on the dr's side a little I got my engine in this weekend. I had to grind on the ear of the mount to fit the K member and the nobbies that fit in the mount pads were tight, but eventually got the engine to sit down in them. 727 hooked to it and the cross member bolted all in just fine as well.
