Re: Aluminum 8 3/4 center section P4876445
[Re: dOc !]
#2733200
01/15/20 12:59 AM
01/15/20 12:59 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
No way ? .. but how about a MAG housing ! You’d still have to put an 8-3/4” ring & pinion in it, wouldn’t ya........ 🤔
[Re: racerx]
#2733223
01/15/20 08:15 AM
01/15/20 08:15 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
For that kind of money get the 8.75 with the .25 upgrade smile
what is a .25 upgrade? Math.... 8.75 + .25 =
[Re: TRENDZ]
#2733233
01/15/20 08:59 AM
01/15/20 08:59 AM
Posts: 20,630 in a cattle trailer down by th...
Guitar Jones
I had the aluminum center section in my Duster for more than 2 decades. It would still break a ring gear though. When I put a pro gear in it I never had another problem. Many hard trans brake launches on it. I used it in the Scamp when I built that car. The Duster was right at 3000 pounds and the Scamp was 2700.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: CrAzYMoPaRGuY]
#2733237
01/15/20 09:08 AM
01/15/20 09:08 AM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
To the OP, I understand your particular situation wanting to make the 8.75 work b/c you've already invested a lot in the housing and all. Not questioning that.
Just saying...one can build a complete Dana 60 from a truck housing for close to what it costs to build one of these aluminum 8.75 centersections and have a rearend that most cars will never break. The 9" is a little more expensive, but worth it IMO, especially when you get faster.
[Re: StealthWedge67]
#2733238
01/15/20 09:08 AM
01/15/20 09:08 AM
Posts: 30,424 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
No way ? .. but how about a MAG housing ! You’d still have to put an 8-3/4” ring & pinion in it, wouldn’t ya........ 🤔 But as that LooneyVille proclaimed ... a Pro Gear is the ticket !
[Re: Guitar Jones]
#2733251
01/15/20 09:26 AM
01/15/20 09:26 AM
Posts: 13,185 aZLiViN
J_BODY
aZLiViN
When I put a pro gear in it I never had another problem. Aren't those about as rare as the aluminum center section this post started with? ....and I’m still a moron running a Mopar trans so gear breakage = trans tear down and inspect. S60 was one of the best mods I’ve done, so I have no knowledge on how to make a 8.75 live..... but I know how to kill em!
[Re: J_BODY]
#2733288
01/15/20 10:36 AM
01/15/20 10:36 AM
Guitar Jones
When I put a pro gear in it I never had another problem. Aren't those about as rare as the aluminum center section this post started with? ....and I’m still a moron running a Mopar trans so gear breakage = trans tear down and inspect. S60 was one of the best mods I’ve done, so I have no knowledge on how to make a 8.75 live..... but I know how to kill em! 4.89 or 4.86 ratio is all you can get so I had to build the car around that.
[Re: TRENDZ]
#2733423
01/15/20 06:12 PM
01/15/20 06:12 PM
Posts: 4,066 Mo.
racerx
Mo.
what is a .25 upgrade? Math.... 8.75 + .25 = ok….got it Thaxs,i thought that I have everything none to man done to a 8.75.thought I was missing something.
[Re: jcc]
#2733438
01/15/20 06:44 PM
01/15/20 06:44 PM
Guitar Jones
I'm thinking you have way too much time on your hands, or, you never sleep.
[Re: Dave_J]
#2733535
01/16/20 04:15 AM
01/16/20 04:15 AM
Posts: 16,477 Canada
CrAzYMoPaRGuY
Canada
..... I remember scoring some of these on closeout at work for $200 dealer cost! A little Gorilla Glue should fix that right up. CrAzYMoPaRGuY , is that 650 Morgan horses or 650 Shetland pony's??? Morgan Fairchild??
CrAzYMoPaRGuY
[Re: DoctorDiff]
#2733536
01/16/20 04:20 AM
01/16/20 04:20 AM
CrAzYMoPaRGuY
Canada
I have a couple prototype aluminum 742 and 489 8.75" castings, but the production version is not available yet. If you are looking for strength, I recommend my nodular iron 489 case with HD forged steel caps. Pictures of the HD version can be seen on the right side of the link, below: https://www.doctordiff.com/8-3-4-nodular-iron-casting.html Grrrr My center is a 742 right now, but I'll take a boo. Are you going to be selling aluminum centers? What do you think of the MP piece, if price wasn't a factor?
CrAzYMoPaRGuY
[Re: an8sec70cuda]
#2733537
01/16/20 04:25 AM
01/16/20 04:25 AM
CrAzYMoPaRGuY
Canada
Just saying...one can build a complete Dana 60 from a truck housing for close to what it costs to build one of these aluminum 8.75 centersections and have a rearend that most cars will never break. The 9" is a little more expensive, but worth it IMO, especially when you get faster. If things don't work out with the 8 3/4 I will toss a Dana under the car, no 8.75 + .25 for this guy! Had one in my Demon. Never again
CrAzYMoPaRGuY
[Re: jcc]
#2733538
01/16/20 04:29 AM
01/16/20 04:29 AM
CrAzYMoPaRGuY
Canada
Can't say as I did! What's the theory behind that??
CrAzYMoPaRGuY
[Re: jcc]
#2733539
01/16/20 04:31 AM
01/16/20 04:31 AM
CrAzYMoPaRGuY
Canada
Old school MW Alum vs new School Mopar 8.75 That looks interesting as heck, but I'm sure hard to find!?!?!
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#2733551
01/16/20 09:38 AM
01/16/20 09:38 AM
StealthWedge67
Puyallup, WA
It seems to me that what breaks the 8-3/4 is when the case deflects in the housing, distorting the relationship from axle centerline to case centerline. A backbrace will help hold the axles true, but the case can still distort the front of the housing. I This allows the axles to pry against the diff / spool and cause the ring gear and pinion to lose their proper relationship. If this is true, then it seems you could help this issue by triangulating the front of the case to the housing at a point out toward the spring perches. A few years ago I drew up plans for a threaded rod with heim joints from the snubber perch to an outboard point on the face of the housing. My thought was that this could control the case deflection in the housing to some extent, thus keeping the axles square to the case.
Thoughts?
[Re: jlatessa]
#2733590
01/16/20 12:12 PM
01/16/20 12:12 PM
Posts: 16,474 On the run…
BloFish
On the run…
I’ve been very happy with my Randy’s Ring and Pinion aluminum 4.56 center section.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
#2733650
01/16/20 03:11 PM
01/16/20 03:11 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Thoughts? The above partly answers the OP's previous question he asked. My thinking, looking at the OEM entire housing solution, the cantilevered front housing flange seemed to be the most flexible item, and why I tried to tie it into the back side of the housing,, and if the back side has a brace, so much the better.
