Re: Aluminum 8 3/4 center section P4876445
[Re: MR_P_BODY]
#2733095
01/14/20 07:40 PM
01/14/20 07:40 PM
Posts: 16,482 Canada
CrAzYMoPaRGuY
Canada
I've been running the alum case for years without ANY issues.. twisted up one set of axles but the case was perfect.. all very hard launches I remember your posts well Mr PBody!!!
CrAzYMoPaRGuY
[Re: Thumperdart]
#2733097
01/14/20 07:41 PM
01/14/20 07:41 PM
CrAzYMoPaRGuY
Canada
Been running the Dr. Diff for a few years now and love it......it's a bit heavier but well braced...... I'll take a look. Thanks!
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#2733112
01/14/20 08:26 PM
01/14/20 08:26 PM
Posts: 5,903 Florida
Locomotion
I ran the aluminum cases for 12-14 years in my Dart Sport running mid-low 11's @ around 3,500 lbs footbraking between 1.47 and 1.53 60'.. I think it helps gear life a bit, but the ring & pinion has always been the weak point and I broke one or two and caught 1-2 in time. They were run a lot. That 11 lbs does make an obvious difference when lifting it into place! Used a steel billet yoke too.
Less ratio often means less, but bigger teeth, which are stronger.
[Re: CrAzYMoPaRGuY]
#2733123
01/14/20 09:01 PM
01/14/20 09:01 PM
Posts: 31,200 Oregon
AndyF
Chat with Doctor Diff. He knows a lot about those housings. He might have his own housing out now, not sure if he made it happen or not. I think he didn't like them, thought they were overpriced. I remember replies about 10 years? ago. They went to $900 and everybody thought wayyyyy too expensive. 10 years ago is a long time. I know that Doctor Diff has developed a bunch of 8 3/4 parts over that time. He has nodular housings available now and I know he had plans to produce an aluminum version.
[Re: CrAzYMoPaRGuY]
#2733127
01/14/20 09:06 PM
01/14/20 09:06 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
CRaZy ... is that 650 Canadian or USA horsepower? US horsepower. If Canadian horsepower the conversion would bring it down to 497 horsepower but after taxes here I would be left with nothing..... Doesn't work that way, because Canadian kilometers are shorter than US miles, so it's still 650 hp
[Re: IcorkSOAK]
#2733140
01/14/20 09:38 PM
01/14/20 09:38 PM
CrAzYMoPaRGuY
Canada
wElCoMe back cRaZy .... you going to let oleHam post now too ?
I'm almost embarrassed to say.... I don't remember Oleham's posts!!! Was he race guy or general forum guy or...? I remember YOU had an inferior motorhome.....
CrAzYMoPaRGuY
[Re: AndyF]
#2733141
01/14/20 09:40 PM
01/14/20 09:40 PM
CrAzYMoPaRGuY
Canada
Chat with Doctor Diff. He knows a lot about those housings. He might have his own housing out now, not sure if he made it happen or not. I think he didn't like them, thought they were overpriced. I remember replies about 10 years? ago. They went to $900 and everybody thought wayyyyy too expensive. 10 years ago is a long time. I know that Doctor Diff has developed a bunch of 8 3/4 parts over that time. He has nodular housings available now and I know he had plans to produce an aluminum version. Looking at my combo do you have any tips Andy? Think I should be "cross your fingers" safe or do you see anything I might address??
CrAzYMoPaRGuY
[Re: J_BODY]
#2733158
01/14/20 10:19 PM
01/14/20 10:19 PM
Posts: 23,273 Here
jcc
Here
So everything breaks at some point, in the above failure the ring pushed away from the pinion , fracturing the housing, because of large tooth breakage jamming between the R&P? Your pic does show well the clearance issue with large pinion lower numerical ratios When the Mopar Alum housing first hit the market from memory it was in the $500 range, a year or so later it went to $600 range, and last price when still offered was in $900 range. Never heard about the $200 closeout pricing.
" All sorts of things can happen when you are open to new Ideas" Inventor of Kevlar
[Re: J_BODY]
#2733159
01/14/20 10:20 PM
01/14/20 10:20 PM
CrAzYMoPaRGuY
Canada
OUCH!!! Now that's not good
CrAzYMoPaRGuY
[Re: jcc]
#2733170
01/14/20 11:09 PM
01/14/20 11:09 PM
Posts: 13,226 aZLiViN
J_BODY
aZLiViN
Back in the dark ages the parts department would get lists of overstock NS1 liquidation stuff..... that’s where we got the bare MP iron heads that reside on our “bracket Betty” mill. I had two of the aluminum pigs... actually sold them in the classifieds ions ago for a nice profit..... certainly not stupid 1k profit though! For that kind of money get the 8.75 with the .25 upgrade Just use the nodular 8.75.... at least it will contain the mayhem.
[Re: CrAzYMoPaRGuY]
#2733173
01/14/20 11:20 PM
01/14/20 11:20 PM
Posts: 1,897 Spahn Ranch
RMCHRGR
Spahn Ranch
I like mine but wouldn't spend a grand on it if I was to do it again. I paid $600 for it back when they first came out what seems like almost 20 years ago now. I didn't put it in a car until a few years ago so can't say I've made 1,000s of passes while throwing tons of power at it but it's been tested.12.1-11.90s @ 110-112. 450 hp small block/904, usually around a 1.7 60 ft, around 3,200 lbs. with driver, drag radials. Plenty of street and some highway miles driven to the track, no problems except the pinon seal leaks a bit after it sits. Weight saving was pretty significant though.
Rest of the parts is basic stuff. Strange 4.10 street gears, billet 7290 yoke, all Timken bearings, Auburn sure grip, Moser axles, no backbrace.
From what I can remember the only set up problem with mine was the counterbore in the housing where the caps install into was really tight, definitely fought with that a little bit.
'71 Duster '72 Challenger '17 Ram 1500
[Re: J_BODY]
#2733174
01/14/20 11:21 PM
01/14/20 11:21 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
..... I remember scoring some of these on closeout at work for $200 dealer cost! A little Gorilla Glue should fix that right up. CrAzYMoPaRGuY , is that 650 Morgan horses or 650 Shetland pony's???
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: tubtar]
#2733188
01/15/20 12:07 AM
01/15/20 12:07 AM
Posts: 23,273 Here
jcc
Here
Old school MW Alum vs new School Mopar 8.75
[Re: CrAzYMoPaRGuY]
#2733192
01/15/20 12:18 AM
01/15/20 12:18 AM
Posts: 30,632 Florida STAYcation
IcorkSOAK
Financed his waterbed
Florida STAYcation
I'm almost embarrassed to say.... I don't remember Oleham's posts!!! Was he race guy or general forum guy or...? I remember YOU had an inferior motorhome..... CRS ? ... that’s a illness that the eLdErY suffer from ! Luckily.., I’m quite a few years from that timetable That dastardly oleHam ? ... that fiberglass nose cone of a bomb making who proclaimed to be living in a cardboard box sometimes in a cave in east Texazz ... was my wanna been nemesis... but I was actually his ... was jsta general poster! Me thimks some of his posts are still up !
[Re: jcc]
#2733194
01/15/20 12:21 AM
01/15/20 12:21 AM
Posts: 8,017 Polson, MT
DoctorDiff
Polson, MT
I have a couple prototype aluminum 742 and 489 8.75" castings, but the production version is not available yet. If you are looking for strength, I recommend my nodular iron 489 case with HD forged steel caps. Pictures of the HD version can be seen on the right side of the link, below: https://www.doctordiff.com/8-3-4-nodular-iron-casting.html
[Re: CrAzYMoPaRGuY]
#2733196
01/15/20 12:26 AM
01/15/20 12:26 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Save the money and get one of Dr Diffs nodular units. No way any empty 8-3/4 pig is worth $1000 no matter what it’s made of in my opinion. At that price, plus gears and everything else needed, you’re into Dana budget territory. I run a stock 742 chunk with MW steel maincaps, a 35-spline spool, and a backbrace. I’m footbraking perhaps 550hp at it in a full weight (3800-lb in the beams) B-body. It’s stood up well for a number of years, probably has at least 400 passes and plenty of street miles on it.... no issues thus far. I know 8-3/4’s have their limit, but I think if set up right, they’re a little tougher than most give them credit for.
BTW: Great to see Cass (Dr Diff) weigh in here. My housing is full of his parts and Cass has spent way more time with me on the phone helping me than my business warranted. one of the good guys for sure!! 👍
