Fuel Pump Rod #2732879
01/14/20 09:13 AM
01/14/20 09:13 AM
Chicago Blackhawks
hemicar1971 Offline OP
Chicago Blackhawks
Was asked by a guy that has a Solid Roller Cam in his Hemi if he could use a stock fuel pump rod. I have never run anything but an Electric Fuel Pump with a Solid Roller Cam but his block you can use a fuel pump rod.. He was wondering if the fuel pump rod was compatible with the Roller Cam Shaft or if there is a fuel pump rod made just for a Solid Roller Cam.
1971 HEMI E BODY REGISTRY
Re: Fuel Pump Rod [Re: hemicar1971] #2732881
01/14/20 09:29 AM
01/14/20 09:29 AM
Sweden
Mopar Guy Offline
Mopar Guy  Offline
Sweden
No he needs a brass tipp rod or he will ruin the cam !
Re: Fuel Pump Rod [Re: Mopar Guy] #2732884
01/14/20 09:40 AM
01/14/20 09:40 AM
Chicago Blackhawks
Chicago Blackhawks
Is there such a thing as a fuel rod for a solid roller and were would I tell him to get one. Never looked into this always just closed it off with a block off plate and ran a electric pump that could keep up with the fuel volume I needed.
Re: Fuel Pump Rod [Re: hemicar1971] #2732886
01/14/20 09:54 AM
01/14/20 09:54 AM
Chicago Blackhawks
Chicago Blackhawks
https://www.summitracing.com/int/parts/cca-4626
It looks like there is a fuel push rod for a Steel Solid Roller Cam Shaft. Thanks
Re: Fuel Pump Rod [Re: hemicar1971] #2732887
01/14/20 09:55 AM
01/14/20 09:55 AM
Maryland
mrob Offline
mrob  Offline
Maryland
Comp makes one for B/RB engines. P/N 4646, has a bronze tip on one end.
Re: Fuel Pump Rod [Re: mrob] #2732891
01/14/20 10:06 AM
01/14/20 10:06 AM
md
mopars4ever Offline
mopars4ever  Offline
md
I got to think they wouldn`t last long.
Re: Fuel Pump Rod [Re: mopars4ever] #2732896
01/14/20 10:32 AM
01/14/20 10:32 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Howards makes one.
I've used it with my roller cam in the 505 and have over 7,000 miles on it.
I had read bad reviews on the Comp one but they "disappeared" from Summit's website...
'63 Dodge 330
11.19 @ 121 mph
Re: Fuel Pump Rod [Re: hemicar1971] #2732933
01/14/20 12:47 PM
01/14/20 12:47 PM
Sweden
Mopar Guy Offline
Mopar Guy  Offline
Sweden
That one is what i use in my RB stroker and a Carter fuel pump from mancini whit no ware on tip on a street car !
Re: Fuel Pump Rod [Re: GY3] #2733137
01/14/20 09:33 PM
01/14/20 09:33 PM
s. e. pa.
calrobb2000 Online content
calrobb2000  Online Content
s. e. pa.
howards
re doing a 383 with a howards pump rod !
motor has 14,000 miles from last rebuild by someone else !
rod has woren off app 1/16" and slightly mushromed already ?
soooo ?
