Page 2 of 3 1 2 3
Re: building a billet motor plate [Re: jcc] #2732790
01/13/20 07:56 PM
01/13/20 07:56 PM
CJD AUTOMOTIVE Offline OP
Originally Posted by jcc
Its beautiful, but with that investment, I feel like it would be hard to ever in the future change my mind.
I have a decent investment in small block stuff. I am hopeful with the latest Ritter block, so don't ever anticipate a change. This old dinosaur will do everything I need it to, and not running a Gen 3 Hemi actually makes it unique. Now if an iron race tall deck Gen 3 block ever became available...
You might also consider adding a 3/4 axis CNC to your shop. biggrin
That may be coming once I enclose and air condition the other side of the shop...some day.
Did you mention the alloy?
6061-T6 for everything except the tensioner assembly and idler pulley standoffs. Those are steel.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
www.CJDAUTOMOTIVE.com
904-400-1802
"I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
Re: building a billet motor plate [Re: CJD AUTOMOTIVE] #2732833
01/13/20 11:01 PM
01/13/20 11:01 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Just ............WOW! sawzall
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: building a billet motor plate [Re: hemi-itis] #2800159
07/23/20 11:14 AM
07/23/20 11:14 AM
Took a while to find a shop willing to make these parts. I shopped it to several good shops, and all but one passed. Found a good shop in Michigan willing to do it and this is what has been made so far. Waiting on a few more pieces before everything comes back to me, then off to anodize.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: building a billet motor plate [Re: CJD AUTOMOTIVE] #2800163
07/23/20 11:16 AM
07/23/20 11:16 AM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
Nice machine work,
What machine shop did you send it too?
Re: building a billet motor plate [Re: CJD AUTOMOTIVE] #2800165
07/23/20 11:19 AM
07/23/20 11:19 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I can see why that part is so pricey.. that started as a THICK piece... very nice
wave
Re: building a billet motor plate [Re: RATTRAP] #2800170
07/23/20 11:25 AM
07/23/20 11:25 AM
Originally Posted by RATTRAP
Nice machine work,
Thanks,
Michigan Machine Worx in Lapeer
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: building a billet motor plate [Re: MR_P_BODY] #2800172
07/23/20 11:28 AM
07/23/20 11:28 AM
wave
Thanks,
Yep, 1-1/2" thick. Needed that much to be able to enclose the timing belt. It's pocket milled front and back. SW shows about 20 lbs. I'm good with that for an accessory drive bracket/motor mounts/and water pump back plate/timing belt cover.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: building a billet motor plate [Re: CJD AUTOMOTIVE] #2800194
07/23/20 12:33 PM
07/23/20 12:33 PM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
Re: building a billet motor plate [Re: CJD AUTOMOTIVE] #2800234
07/23/20 02:09 PM
07/23/20 02:09 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Well, there's something we've never seen on ebay!
Amazing stuff.
Rich H.
Esse Quam Videri
Re: building a billet motor plate [Re: ZIPPY] #2800309
07/23/20 04:45 PM
07/23/20 04:45 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I'm crazy enough to make something like that. There are a couple tricky parts there for me to machine, but my machine is capable of machining that.....
Re: building a billet motor plate [Re: markz528] #2800310
07/23/20 04:53 PM
07/23/20 04:53 PM
I was shocked that shops simply said, "nope, not interested". I provided the SW native files so tool paths would be easy to do. Just need a big Z axis for the water pump back plate...or a 5 axis/horizontal bore.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: building a billet motor plate [Re: CJD AUTOMOTIVE] #2800324
07/23/20 05:45 PM
07/23/20 05:45 PM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
I see no 5 axis machining requirement for that part, Am I missing something??
Re: building a billet motor plate [Re: RATTRAP] #2800333
07/23/20 06:00 PM
07/23/20 06:00 PM
You are correct. Tall Z axis or horizontal bore.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: building a billet motor plate [Re: CJD AUTOMOTIVE] #2800335
07/23/20 06:05 PM
07/23/20 06:05 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
My mill is a bed mill so I think it would of fit fine. I don't do it for a living - just to play. I can understand why the pros would not have interest.
Not anywhere on your scale - which is very impressive, but this is an adapter I made to fit regular 440 M/T Valve Covers on a B1 head. It was a real pain to engineer, but came out real good.
Re: building a billet motor plate [Re: markz528] #2800373
07/23/20 07:55 PM
07/23/20 07:55 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Impressive work Craig, an admirable piece of work. I only wish I had the time for constrcting something like that.
Alan Jones
Re: building a billet motor plate [Re: LA360] #2800532
07/24/20 09:40 AM
07/24/20 09:40 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
VEry niCE up
Was it ever pondered to do a machineable wax mockup as a trial first? nervous
I would have a little tense until its it in place and installed.
Re: building a billet motor plate [Re: jcc] #2800607
07/24/20 12:30 PM
07/24/20 12:30 PM
Just finished the last piece:
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: building a billet motor plate [Re: jcc] #2800610
07/24/20 12:38 PM
07/24/20 12:38 PM
VEry niCE up
You mean like 3D printing the parts and CNC routering a wood template?......
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: building a billet motor plate [Re: CJD AUTOMOTIVE] #2800627
07/24/20 01:12 PM
07/24/20 01:12 PM
North of Detroit
HemiDart68 Offline
HemiDart68  Offline
North of Detroit
very cool project. nice work.
In God we trust, all others pay cash. www.lightnens.com (Home of the world's fastest Paint Job)
Re: building a billet motor plate [Re: HemiDart68] #2800630
07/24/20 01:17 PM
07/24/20 01:17 PM
Thanks guys, few more: (yes I am excited, have a huge amount of time and money in this!)
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Page 2 of 3 1 2 3
