Re: No Oil Pressure! Cause Found With Pics [Re: Rug_Trucker] #273256
04/01/09 08:40 PM
04/01/09 08:40 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
It's a Slant, throw some bearings at it & go...
And a new oil pump , it will probably be scored ..
Rope seal ??? that's a slant it's got 7 mains . someone lost a rag it appears
My punishment for changing the oil in it. Looks like I can get rod bearings from Advanced for $24 for a set. Autozone wants $11.99 per rod. Can't get the mains to come up on Advanced. They have a crappy website.
I am going to pull one of the mains to see what it looks like. I already have the new pump. Also have one that appears to have been changed on another engine.
Time to get greasy before I go to work at 1.
Checkout www.RockAuto.com
They carry Clevite plus they give Moparts another 5% off..
Just my $0.02...
Re: No Oil Pressure! Cause Found With Pics [Re: Sinitro] #273257
04/01/09 09:56 PM
04/01/09 09:56 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Just my $0.02...
More details please about the 5% off?? Is there a code you need to enter? My local old Mopar club (CPOC) used to have a discount at NAPA, but I lost the code over the years...
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: No Oil Pressure! Cause Found With Pics [Re: GO_Fish] #273258
04/02/09 12:23 AM
04/02/09 12:23 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Just my $0.02...
Use this discount code 14282251053590
Enter into "Where do you hear about RockAuto".
Good for 5% off up to April 5th...
Later..
Re: No Oil Pressure! Cause Found With Pics [Re: Sinitro] #273259
04/02/09 12:36 AM
04/02/09 12:36 AM
Woodbridge,CA
NAS Backyard Offline
Woodbridge,CA
Looks like Rug I once found a brown paper towel wrapped around mine. It got blown in the engine from a pressure wash job. Didn't hurt the engine though.
1970 Challenger Ragtop 426 4 speed 1961 Olds 88 2 dr Sedan 394 4 speed GVOD 1968 Pontiac Firebird 428 4 speed 2000 Ford F-150 2002 HD Roadking 1961 Licence Plate collection 1995 Buick Roadmaster www.nogreenautolaws.com
Re: No Oil Pressure! Cause Found With Pics [Re: Sinitro] #273260
04/02/09 08:16 AM
04/02/09 08:16 AM
United States
STLDuster Offline
STLDuster  Offline
United States
whoops, my mistake, thought the discount code gave me an error, I entered it in the wrong area.
"No great genius has ever existed without some touch of madness." - Aristotle
Re: No Oil Pressure! Cause Found With Pics [Re: 1_WILD_RT] #273261
04/02/09 10:52 AM
04/02/09 10:52 AM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
Re: No Oil Pressure! Cause Found With Pics [Re: NAS Backyard] #273262
04/02/09 01:25 PM
04/02/09 01:25 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
Hmmmm could be. After all, he is the "Rug Trucker"
Re: No Oil Pressure! Cause Found With Pics [Re: Rug_Trucker] #273263
04/02/09 01:41 PM
04/02/09 01:41 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
could it be part of the oil filter????
Re: No Oil Pressure! Cause Found With Pics [Re: Mr.Yuck] #273264
04/02/09 11:45 PM
04/02/09 11:45 PM
Not2farfromNashville, TN
Rug_Trucker Offline OP
Nope, it is definately cloth. I didn't have a chance to play with it today.
I do want to Spray and Wash it just for the heck of it. It is probably a shop rag.
Re: No Oil Pressure! Cause Found With Pics [Re: Rug_Trucker] #273265
04/08/09 10:35 AM
04/08/09 10:35 AM
I am headed out to the shop to disassemble the engine some more. Pull the pump, and the crank.
I looked for Emery cloth and found 1" wide on a roll with 320 grit. I was really wanting a sheet. I can't find cotton sash cord to turn the cloth.
Can I accurately mic the journal with a vernier caliper with a gauge? I don't want to go too small.
BTW new standard Federal Mogul rod bearings are $3.99 each!!
If you buy a set it is $49.98!!
Fuzzy math!
Should I plastigauge the mains to decide on changing them?
Re: No Oil Pressure! Cause Found With Pics [Re: Rug_Trucker] #273266
04/08/09 11:10 AM
04/08/09 11:10 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
320 is way to coarse, I'd go 600 max.. I wouldn't have bothered pulling the crank but now that you have you might call a local machine shop & see what it would cost to have it turned & get new bearings...I know a shop local to me that turns 75% of all the cranks for other area machine shops I can get a kit with the turned crank & new rods & mains for $120.00...
Re: No Oil Pressure! Cause Found With Pics [Re: 1_WILD_RT] #273267
04/08/09 01:19 PM
04/08/09 01:19 PM
I am going to hold off on the polishing for a while. I will get the right stuff.
If it is easier pulling the crank to change seals it is coming out. I want to look at the whole thing while I am in there. I found some schrapnel that is non magnetic in the pump gears. I think I could reuse this pump? I have a new one, and another on the way.
Pics coming!
Can I find in stock locally ofset timing gear keys?
I may degree the cam to the new double roller I got from Cox Brothers Racing in '04.
Wanna go for economy!
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: No Oil Pressure! Cause Found With Pics [Re: Rug_Trucker] #273268
04/09/09 10:46 AM
04/09/09 10:46 AM
Thinking maybe the rag in to oil pan was to screen the oil entering the pump..........It really looks like gause....gauze(sp)
I found plastic between the gears in the pump. Must be from the distributor gear.
Re: No Oil Pressure! Cause Found With Pics [Re: Rug_Trucker] #273269
04/09/09 12:12 PM
04/09/09 12:12 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
thats what i was giong to say,i beleive thats called the TENNESEE PRE FILTER it keeps you from having to buy those pesky screw in types and the less oil you get to the engine the less chance of contamination.i got that right straight from the mouth of an old hillbilly who couldnt beleive no one could figer it out.
Re: No Oil Pressure! Cause Found With Pics [Re: sharpie] #273270
04/23/09 03:26 PM
04/23/09 03:26 PM
Decided to check prices on machine work. $70 to grind and polish from a small shop.
Waiting on pricing from a Mopar onlt guy near here that has all the equipment at home.
Re: No Oil Pressure! Cause Found With Pics Good News Ba [Re: Rug_Trucker] #273271
04/30/09 12:25 PM
04/30/09 12:25 PM
Got of the phone with the machine shop. Rear main was .060 and would have to be welded. (add $70!) They have another crank there that is .030 under and ready to go. Right size for the 74 converter.
$70
No wonder the rear main was leaking so bad!
Re: No Oil Pressure! Cause Found With Pics Good News Ba [Re: Rug_Trucker] #273272
04/30/09 12:44 PM
04/30/09 12:44 PM
MNobody Offline
MNobody  Offline
I've heard stories of people using a piece of leather belt for a main bearing on those things and getting alot of miles out of em LOL.
Re: No Oil Pressure! Cause Found With Pics Good News Ba [Re: MNobody] #273273
04/30/09 03:07 PM
04/30/09 03:07 PM
Dallas, TX
Hubbs Offline
Hubbs  Offline
Dallas, TX
Okay, it looks bad, but don't give up. Try some good detergent and a nice long delicate cycle. You may get lucky and get a few more uses out of that rag.
Good luck!
(Sorry, couldn't resist )
I used to be "Chubs". Sorry I've been away for so long! I got married and am now "Hubbs"! Garage: 1970 Dodge Challenger 440/4sp 2013 Dodge Charger SRT-8 2014 Ram 1500 2015 SRT Challenger Hellcat (on order)
Re: No Oil Pressure! Cause Found With Pics Good News Ba [Re: Hubbs] #273274
04/30/09 03:15 PM
04/30/09 03:15 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Had a 440 in my Imp that snapped a main cap bolt.It started to clatter a bit and I tore it down and found a headless bolt in the pan.Screwed up some bearing rods and crank.After that I replace all the main bolts and also the head bolts.Rocky
Chrysler Firepower
Re: No Oil Pressure! Cause Found With Pics Good News Ba [Re: MNobody] #273275
04/30/09 04:47 PM
04/30/09 04:47 PM
Granpa Layne did that to a model A. Also something about oatmeal and plugging the radiator or using that for antifreeze?
