I am headed out to the shop to disassemble the engine some more. Pull the pump, and the crank.
I looked for Emery cloth and found 1" wide on a roll with 320 grit. I was really wanting a sheet. I can't find cotton sash cord to turn the cloth.
Can I accurately mic the journal with a vernier caliper with a gauge? I don't want to go too small.
BTW new standard Federal Mogul rod bearings are $3.99 each!!
If you buy a set it is $49.98!!
![](/ubbthreads/images/graemlins/confused.gif)
Fuzzy math!
![](/ubbthreads/images/graemlins/laugh2.gif)
Should I plastigauge the mains to decide on changing them?
