1972 Duster license plate light assy #2732216
01/11/20 06:47 PM
01/11/20 06:47 PM
AndyF Offline OP
AndyF  Offline OP
The license plate light assembly is missing on my car. I looked around a bit and this is the only one I found. https://www.moparmall.com/Plymouth-Duster-Dodge-Dart-Demon-Sport-A-Body-p/722-138_a.htm
Is this all that is available? Seems odd that the big guys don't carry the part. Maybe it is something this guy tooled up and nobody else bothered with it?
Re: 1972 Duster license plate light assy [Re: AndyF] #2732262
01/11/20 09:10 PM
01/11/20 09:10 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
Seems kind of pricey, but if he tooled up to make a part that he won't sell much of....I understand the price. I'm fixing up a 70 Duster, and if mine doesn't work or is MIA, I will just bend up a bracket and mount some sort of LED light to it that is bright enough to illuminate the tag. My car is just going to be a hot rod, so originality doesn't matter. twocents
Re: 1972 Duster license plate light assy [Re: JDMopar] #2732274
01/11/20 09:40 PM
01/11/20 09:40 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Should be same assembly as Valiants that used that same bumper; might try Wildcat Auto Wrecking in Sandy, OR.
Re: 1972 Duster license plate light assy [Re: topside] #2732420
01/12/20 12:23 PM
01/12/20 12:23 PM
AndyF Offline OP
AndyF  Offline OP
If Wildcat had the part they would probably charge $200 for it.
Re: 1972 Duster license plate light assy [Re: AndyF] #2732460
01/12/20 02:14 PM
01/12/20 02:14 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Ebay shows a reproduction about $95 delivered - maybe more for less, only looked at 1st page - and plenty of workable ones as cheap as $7.
"Workable" means you'd need to fab a bracket.
Re: 1972 Duster license plate light assy [Re: AndyF] #2732587
01/12/20 10:14 PM
01/12/20 10:14 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
Try posting on FABO. I am sure there are plenty of nice used ones still out there...
Re: 1972 Duster license plate light assy [Re: QuickBpBp] #2732743
01/13/20 04:46 PM
01/13/20 04:46 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Unless you have to have it right away just keep checking around & on Ebay a good used one will turn up for a reasonable price.
Re: 1972 Duster license plate light assy [Re: 71GTX471] #2733010
01/14/20 03:41 PM
01/14/20 03:41 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: 1972 Duster license plate light assy [Re: 71TA] #2733037
01/14/20 04:50 PM
01/14/20 04:50 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
there is one on the classifieds here.
Re: 1972 Duster license plate light assy [Re: chrisf] #2734265
01/18/20 05:28 PM
01/18/20 05:28 PM
AndyF Offline OP
AndyF  Offline OP
A local A body guy had one in his parts stash that was missing the lens. He donated it to the project. The original bracket has the neat little wire holder in the center that the reproductions are missing.
Re: 1972 Duster license plate light assy [Re: 71TA] #2736641
01/25/20 08:52 PM
01/25/20 08:52 PM
AndyF Offline OP
AndyF  Offline OP
I got one of the reproduction brackets from Vans but it looked like CCC so I tossed it and used the factory one that I found. I did use the socket and lens from Vans. I also got a reproduction lens from Mancini. The repo lens from Mancini was a little nicer than the Vans lens. The Mancini lens was an authorized repo and it looks nicer and has the original Mopar pentastar on the lens. Not that it really matters to me but it might to someone else.
