Re: Vacuum pump
[Re: Cab_Burge]
#2732452
01/12/20 01:50 PM
01/12/20 01:50 PM
Posts: 2,499 PA
moparacer
PA
If you are on gas it is ok to pull from one side but I have found on alky that pulling from both works better for removing the moisture.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
Re: Vacuum pump
[Re: moparacer]
#2732459
01/12/20 02:13 PM
01/12/20 02:13 PM
Posts: 9,996 Frostbitefalls MN (Rocky&Bullw...
gregsdart
If you are on gas it is ok to pull from one side but I have found on alky that pulling from both works better for removing the moisture. How warm do you let the motor get? I run one hose to the valvecover, motor sees over 200 degrees often on the return road, no problems. I believe it boils off as much or more than collects in the little tank.
Re: Vacuum pump
[Re: dragon]
#2732657
01/13/20 09:42 AM
01/13/20 09:42 AM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
I just pull from one side also and I'm on gas.
Re: Vacuum pump
[Re: moparacer]
#2732696
01/13/20 12:55 PM
01/13/20 12:55 PM
Posts: 43,172 Bend,OR USA
Cab_Burge
I run E85 in my S/P car, I got a lot of moisture on the first motor with no pushrod oiling. I swapped motor and added pushrod oiling and spray bar oiling and I had to improve the baffling under the suction fitting in the new valve covers with the spray bars to stop the massive oil sucking into the breather tank My car has no radiator, it has two small oil coolers for the engine coolant so it runs warmer now than other cars, I've seen 230 F when I shut it off in the pits after a run that started the run at 160+F , it is a 1/8 mile track in central OR with 80+F outside air temps. in the summer
Re: Vacuum pump
[Re: gregsdart]
#2732752
01/13/20 05:32 PM
01/13/20 05:32 PM
Posts: 2,499 PA
moparacer
PA
How warm do you let the motor get? I run one hose to the valvecover, motor sees over 200 degrees often on the return road, no problems. I believe it boils off as much or more than collects in the little tank. I run my coolant temp around 170-180 and the oil temp will get over 200 hot lapping. On mine the moisture seemed to collect on the side without the vac line. I discovered it one time when I pulled the valve covers with the engine hot to check the lash. Vac line cover was dry.
Re: Vacuum pump
[Re: moparacer]
#2732767
01/13/20 06:29 PM
01/13/20 06:29 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
One pickup point is fine on Gas for sure. Alky not a clue but don't see why you would need a second.
