VVT ?? with run in stand #2731963
01/10/20 09:03 PM
01/10/20 09:03 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
So I want to run an 09 and up Hemi on an run in stand. I would like to use my HEMI 6 ignition along with a carb and my ritter intake. The purpose of this is to find leaks and make sure everything is good BEFORE I run it on the Dyno. My questions are.
1 Does the VVT move around without the ecm attached.? The shape of the wheel is identical to the pre 09 and down so I believe the HEMI 6 would work.
2. Would I need to lock the VVT in order to use the HEMI 6?
Matt
Re: VVT ?? with run in stand [Re: MattW] #2732036
01/11/20 01:20 AM
01/11/20 01:20 AM
Deland, Florida
biff426 Offline
biff426  Offline
Deland, Florida
Unless you changed the crank tone ring to a 32 tooth it won't work. The timing pickup ring will work.
Re: VVT ?? with run in stand [Re: biff426] #2732091
01/11/20 11:03 AM
01/11/20 11:03 AM
Springtown Pa
Ray408G3Hemi Offline
Springtown Pa
X2 on the tone wheel.
When the vvt is not plugged in it stays at rest, there is a lock pin in there that keeps will only let it advance 2* when the oil pressure comes up. right around 5:40 Ric talks about it,
https://www.youtube.com/watch?v=ug7MCLccUHk
1963 Thunderbolt 496FE 10.80 (still a work in progress)
1968 Mustang slow a$$ 428 FE
1971 Boss 351 Mustang 11.20@115mph
1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA
1996 Viper GTS
2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor
2009 Ram 9.65@144MPH 463CI G3 NA
2010 Challenger 9.91 @ 139MPH 408CI G3ci NA
2019 F150 (local dealer's Lightning package) ..11.90s
Re: VVT ?? with run in stand [Re: Ray408G3Hemi] #2732339
01/12/20 01:49 AM
01/12/20 01:49 AM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
I will be mounting a 32 tooth relutor wheel on the harmonic balance.
Thx for the VVT info
Matt
