Engine hoist bottle jack repair kit?
#2731736
01/10/20 01:06 PM
01/10/20 01:06 PM
Posts: 8,681 Buford, GA
I_bleed_MOPAR
Buford, GA
Allied EH23. I can only find one source for a repair kit which appears to be an O-ring & a bushing they call a "u-cup". Just shy of $28 shipped. ![shocked shocked](/ubbthreads/images/graemlins/custom/shocked.gif) Any luck sourcing just an O-ring from a parts house or hardware store? Or am I going to have to bite the bullet and pay the ransom? ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif) Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif) )
Re: Engine hoist bottle jack repair kit?
[Re: elmor353]
#2731911
01/10/20 06:49 PM
01/10/20 06:49 PM
Posts: 20,679 in a cattle trailer down by th...
Guitar Jones
At $28.00 you're halfway to the cost of a new jack from Harbor Freight. Why bother tearing it apart and hoping you can fix it? I have a bottle jack on my engine hoist that quit working. I thought about fixing it myself like you, but why go through the hassle when you can get a new one fairly cheap? These cylinders usually have a tube that the ram seals to. The tube baloons and that is why it leaks. No amount of resealing will fix this. Buy the 8 ton unit instead of the 3 ton and you should be set for awhile.
