Engine hoist bottle jack repair kit?
#2731736
01/10/20 01:06 PM
01/10/20 01:06 PM
Posts: 8,666 Buford, GA
I_bleed_MOPAR
Buford, GA
Allied EH23. I can only find one source for a repair kit which appears to be an O-ring & a bushing they call a "u-cup". Just shy of $28 shipped. Any luck sourcing just an O-ring from a parts house or hardware store? Or am I going to have to bite the bullet and pay the ransom? Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
Re: Engine hoist bottle jack repair kit?
[Re: elmor353]
#2731911
01/10/20 06:49 PM
01/10/20 06:49 PM
Posts: 20,600 in a cattle trailer down by th...
Guitar Jones
At $28.00 you're halfway to the cost of a new jack from Harbor Freight. Why bother tearing it apart and hoping you can fix it? I have a bottle jack on my engine hoist that quit working. I thought about fixing it myself like you, but why go through the hassle when you can get a new one fairly cheap? These cylinders usually have a tube that the ram seals to. The tube baloons and that is why it leaks. No amount of resealing will fix this. Buy the 8 ton unit instead of the 3 ton and you should be set for awhile.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
