70 horn button adapter #2731662
01/10/20 09:56 AM
01/10/20 09:56 AM
taunton, mass. 02780
moparthunder70 Offline OP
Okay, 1970 horn button adapter (dodge coronet ) is a one year only part ? What is the difference between a 69 horn button adapter and a 70 ? I have one from a 69 and it looks almost identical to the pictures I've seen of the 70. Someone suggested that three drilled holes are the difference ?
Re: 70 horn button adapter [Re: moparthunder70] #2731664
01/10/20 10:02 AM
01/10/20 10:02 AM
Lansing, MI
70gtx440dana Offline
Lansing, MI
The outer diameter is larger on a 70 adapter. Ignition moved to column in 70. Column diameter increased. 69 Steering wheel will not fit properly either.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 70 horn button adapter [Re: 70gtx440dana] #2731732
01/10/20 12:53 PM
01/10/20 12:53 PM
Thank you...that answers the question..appreciate it..best site for mopar knowledge...
