Wiper linkage won't stay on
#2731237
01/08/20 08:26 PM
01/08/20 08:26 PM
Posts: 28,069 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Have you guys run into an issue where the wiper bushings won't cooperate? The bushings on my 92 D250 broke so I replaced them today using a touch of white lithium grease. I installed the linkage and it popped off twice. On round three it held so I put the cowl and everything back together. When I ran them again it survived three wipes before popping off. One bushing came from NAPA and the other from Autozone.
I can hear and feel the bushings popping into place and have no idea why this has become such an issue.
It's dark so I'm done messing with it for now.
It is supposed to rain tomorrow and I need to hook 13,000 lbs to the truck and get it down the road before the ugly storms hit on Friday.
Re: Wiper linkage won't stay on
[Re: iapco103]
#2731264
01/08/20 09:52 PM
01/08/20 09:52 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
Been there , done that. They need to pop TWICE before they are fully seated. If you stop after the first pop, it will come loose. Squeeze em down with pliers and the excess grease will come out. Paul PITA job I'm not going to miss. 2¢ Shouldn't this have been your 4th or 5th round of bushings by now?
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: 3hundred]
#2731267
01/08/20 09:56 PM
01/08/20 09:56 PM
Posts: 131 Conroe , Texas
iapco103
Conroe , Texas
Been there , done that. They need to pop TWICE before they are fully seated. If you stop after the first pop, it will come loose. Squeeze em down with pliers and the excess grease will come out. Paul PITA job I'm not going to miss. 2¢ Shouldn't this have been your 4th or 5th round of bushings by now? You are far too kind in your assessment of that job, LOL. Paul
[Re: 3hundred]
#2731479
01/09/20 04:05 PM
01/09/20 04:05 PM
feets
Senior Management
Senior Management
Irving, TX
Been there , done that. They need to pop TWICE before they are fully seated. If you stop after the first pop, it will come loose. Squeeze em down with pliers and the excess grease will come out. Paul PITA job I'm not going to miss. 2¢ Shouldn't this have been your 4th or 5th round of bushings by now? Yeah, this will be the 4th time for this job on my truck.
[Re: feets]
#2732940
01/14/20 01:05 PM
01/14/20 01:05 PM
Posts: 7,833 east side of Ohio
basketcase
east side of Ohio
did you completely pull the link out of the truck? The only time I ever had trouble with the linkage popping back off was when I didn't get the linkage back in correctly. Had an in law yapping while I was working.And I always put a touch of grease on the new bushings.
1981 Dodge D150 360 auto
