Re: Electrical upgrades [Re: GY3] #2731422
01/09/20 01:42 PM
01/09/20 01:42 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
If the supplemental electric pump is only run when the engine is running, then the factory scheme is actually very good.
Power the supplemental pump direct from the alternator with a relay that turns on with key in run. Use a fuse in the line
or if the draw is low enough, its possible to add a fuse to the fuse box. Its just a pain.
Headlights if used, also benefit from direct from alternator through a relay.
There's a lot of connections for the electricity to get to the headlights - and on a-bodies especially, the wires are small.
Depending on the condition of your firewall connector, for your needs a parallel wire to the ammeter's stud might be enough. Use a well insulated ring terminal.
If the bulkhead connectors are poor, then remove the alternator feed wire from the bulkhead inside and tie in a new 8 or 10 gage wire through a grommet in the firewall.
If the battery feed connection is also poor, then 10 gage with 16 gage fusible link on engine side, then 10 gage through a grommet to the ammeter red terminal.
I thought '63 had the better bulkhead connector, but maybe that was just '65. shruggy
Re: Electrical upgrades [Re: Mattax] #2731424
01/09/20 01:47 PM
01/09/20 01:47 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
This is a parallel alternator feed through a grommet.
At minimum it means any current for recharging the battery will have a dedicated route from alternator.
Illustration showing battery charging
Re: Electrical upgrades [Re: Mattax] #2731431
01/09/20 02:16 PM
01/09/20 02:16 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Doing it as above means only one fusible link is needed.
It also lets you monitor the battery charging and discharging.
Connecting the Alternator output direct to the battery or tying in at the starter relay does the same thing.
It gives the sometimes high charging current a seperate route to the battery, reducing the load on the main feed wire and connections.
Difference is that a fusible link is needed in the connecting line to protect against battery grounding, and the ammeter will no longer show charging.
Re: Electrical upgrades [Re: Mattax] #2731432
01/09/20 02:19 PM
01/09/20 02:19 PM
That is why I put a volt meter in my race car to make sure the alternator is working up
Easy peasy to do also up
I connected it to the ignition feed, shows battery voltage before starting and alternator charging voltage when running thumbs
Re: Electrical upgrades [Re: Mattax] #2731436
01/09/20 02:22 PM
01/09/20 02:22 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Some places encourage removing the alternator's feed to the main splice.
This creates a longer path through two fusible links with more connections for everything but battery recharging.
Not recommended unless running battery most of the time.
Re: Electrical upgrades [Re: Mattax] #2731450
01/09/20 02:41 PM
01/09/20 02:41 PM
IL
furious70 Offline
furious70  Offline
IL
When I went EFI on my Fury, the main criteria for rewire were:
Remove the battery charging circuit from the cabin (e.g. amp bypass, bulkhead bypass)
consolidate new power needs (efi, fuel pump, stereo, etc) on a bus and draw voltage 'sensing' from that bus
so I
bypassed amp gauge
rerouted alt output to the big post on the starter relay
efi, fuel pump, stereo draw power from the big post
allowed OEM wiring to still feed the cabin - in this case I created 2 parallel paths for power to flow from the source (alt or batt) into the cabin vs the OEM in and out
I actually didn't bypass the bulkhead, I repaired it and since I removed all draw from that circuit except the OEM equipment in the cabin and removed the battery charging from that circuit, there's no issue
I used a 1 wire alt, if not I would have run the sensing wire to the big post as well.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Electrical upgrades [Re: furious70] #2731469
01/09/20 03:33 PM
01/09/20 03:33 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Bypassing the problematic, old, original ammeter and using a voltmeter to monitor the electrical system is an easy decision for me, regardless how it is wired.
Re: Electrical upgrades [Re: CMcAllister] #2731568
01/09/20 08:35 PM
01/09/20 08:35 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
If you need new crimp spade connectors for your bulkhead block you can get some off Ebay. These are medium duty so they are OK for all but the 10 Gauge wires. I do not know where to get the heaver ones.
https://www.ebay.com/itm/Mopar-Male-Female-14-16-AWG-Gauge-Wiring-Harness-Terminal-Crimp-Connectors-NOS/192502001151?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
