Re: What are you using to warm you up?
[Re: Greg55_99]
#2730752
01/07/20 11:11 AM
01/07/20 11:11 AM
Posts: 2,368 Banana Republic
FM3AAR
Banana Republic
Mr. Heater kerosene 50K BTU torpedoes. Garages are well insulated and these bring the temp up fast and it lasts for awhile. If all day in the garage is planned, I have a ceiling hung 35K BTU propane thermostat controlled for cleaner heat.
“You’ll own nothing” — And “you’ll be happy about it.” K. Schwab
[Re: Greg55_99]
#2730761
01/07/20 11:46 AM
01/07/20 11:46 AM
Posts: 20,655 in a cattle trailer down by th...
Guitar Jones
There's a wood burning stove in my garage in WV. I haven't been up there in the cold to fire it up yet though so how well it works is yet to be determined.
[Re: Guitar Jones]
#2730790
01/07/20 01:19 PM
01/07/20 01:19 PM
Posts: 1,497 North East USA
BIGGERED
Reasonable Title
Reasonable Title
North East USA
There's a wood burning stove in my garage in WV. I haven't been up there in the cold to fire it up yet though so how well it works is yet to be determined. I would be curious what your insurance company thinks of that? With your cheap natural gas I'd recommend a hanging unit heater, ideally mutispeed burner and blower. Red
[Re: Greg55_99]
#2730791
01/07/20 01:25 PM
01/07/20 01:25 PM
Posts: 5,139 East Aurora (Buffalo) NY
RoadRunner
I installed a radiant heat system in my garage when we built it 14 years ago. I use a high efficiency water heater as a heat source. Keeps garage relatively close to 50 degrees all winter. On coldest days, the heater has a hard time keeping up with the BUTs, but for minimal investment, works great.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: BIGGERED]
#2730792
01/07/20 01:25 PM
01/07/20 01:25 PM
Posts: 9,534 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
A quick note on the wood stoves and ins. All I had to do is get a "Pro" to inspect and sign off that it was a safe functional setup to code and answered a few other minor things about haz. material storage, paints, ect... got a fireproof locker, ect and extinguishers in there proper place, blah blah blah......have the local fire chief walk through one time a year and sign off....... not a big thing.
I love the warm dry heat, things dont rust in my shop, ever.
STOP POTATO HATE!
[Re: DrCharles]
#2730796
01/07/20 01:43 PM
01/07/20 01:43 PM
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Id use her big azz to smother a fire if one started. Yea she will keep you warm and not breathing when she rolls over on ya while you sleep.
I dont worry about too much in that way, obviously I wont spray laq. on that side of my shop and but things like brake clean, carb cleaner does not saturate the air enough to cause a issue.
My biggest oh crap moment was one am I walked in and had a 10 gallon jug of C16 leak fully onto the floor and still no boom.
Ya just got to be a little bit more aware, but really id be almost more concerned about a gas p light or the auto start system on some gas furnaces.
STOP POTATO HATE!
[Re: BIGGERED]
#2730811
01/07/20 02:53 PM
01/07/20 02:53 PM
Guitar Jones
There's a wood burning stove in my garage in WV. I haven't been up there in the cold to fire it up yet though so how well it works is yet to be determined. I would be curious what your insurance company thinks of that? With your cheap natural gas I'd recommend a hanging unit heater, ideally mutispeed burner and blower. Red It was a $178/yr surcharge for the wood stove. It used to be in the house.
[Re: Greg55_99]
#2730812
01/07/20 02:57 PM
01/07/20 02:57 PM
Posts: 25,910 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Got two of these 140K BTU natural gas units in my shop but can only run one at a time because the consumption exceeds the gas line capacity.
[Re: Greg55_99]
#2730897
01/07/20 07:37 PM
01/07/20 07:37 PM
Posts: 43,259 Bend,OR USA
Cab_Burge
I use a older, legal in Oregon still, wood stove to burn up some of the trees I had cut down on our lot here in Bend, it had around 34 big pine trees on it when we bought it in 2004. I've had eight trees remove so far I hate raking up pine cones and pine needles, these trees are really messy also I forgot about the Wal Mart brand oil filled electric heater that I leave on in the engine room most of the winter, that will keep it around 55 to 65 F in that part of my shop if it isn't real cold outside, below 10F at night. The wood stove will heat up the engine room to 80F + in a hurry if I stuff it full of wood, I have a set of double doors that open into the other part of the shop and I have had to open them all the way open to reduce the temps in the engine room, some day maybe I will get the handle on how much wood to burn to keep it right at 60 to 70F
[Re: poorboy]
#2730980
01/08/20 12:14 AM
01/08/20 12:14 AM
Posts: 7,497 Minnesota
Hemi_Joel
Minnesota
I have a 125,000 btu Gordon Ray infrared tube. It is 30' long and hangs about a foot below the ceiling. I love the radiant heat, it is so warm and comfy to work under its rays! I have a 500 gallon propane tank to feed it. I pre-buy 1000 gallons per year in mid summer when prices are low. I don't have to take delivery of all 1000 gallons at once, they come out on a regular schedule and keep it full. I usually don't use 1000 gallons, so I get credit for what I don't use. My 50x80 shed is very well insulated, and has no windows, 1 overhead door and one walk in door, so 125k btu is enough, even in -20F temps. It is a very reliable heater, its been here for 25 years with only regular maintenance, except for replacing 1 10' tube about 5 years ago.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Greg55_99]
#2730991
01/08/20 02:05 AM
01/08/20 02:05 AM
Posts: 1,908 Nebraska
4406bbl
Nebraska
It's winter and my garage is cold up here in New England. I got this "butt warmer" over 20 years ago in Germany when I was stationed there and switched it over to propane with a regulator from an old barbeque grill. Doesn't heat the whole garage, but it keeps my hind end and hands warm when I'm messing around with my car. Also don't worry about ventilation since the garage ceiling is so high. What are you guys using?
Greg I use gas that brings in outside air for combustion. I would warn everyone to put any unvented heater on a timer, or get a carbon monoxide shutoff, some units have the. I had a friend that was changing a trans on his van fall asleep in a garage with a torpedo heater, it was ugly. He spent 2 weeks in the hospital, he was never right after that. It screwed his brain up, went from a good paying job to a plain repetitive job, just couldn't think fast anymore. It turned him into a droid for lack of a better term, seriously do not chance it. 25 years of hell for him.
[Re: Greg55_99]
#2731065
01/08/20 12:16 PM
01/08/20 12:16 PM
Posts: 34,937 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
My garage has heat and air , I like to be cool in summer and warm in winter
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: Hemi_Joel]
#2731073
01/08/20 12:41 PM
01/08/20 12:41 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
I pre-buy 1000 gallons per year in mid summer when prices are low. I don't have to take delivery of all 1000 gallons at once, they come out on a regular schedule and keep it full. I usually don't use 1000 gallons, so I get credit for what I don't use Wow... that must be a thousand bucks (or two) just to heat your shop! I used to live in Presque Isle, Maine and in Feb. the heating oil bill was more than the mortgage (small older house).
