Re: Driver Side Remote Mirror Dis-Assembly?
[Re: 44D6PAKCUDA]
#2730693
01/07/20 12:36 AM
01/07/20 12:36 AM
Posts: 849 Avondale AZ
Prodart440
Avondale AZ
It is possible. I did it but it's been 10 years or so. Something about opening up the lead around the cables to remove them, and then crimping them back in when re assembling. Hopefully someone can get you more information....
Aaron
68 Roadrunner 383/AT 69 Dart GT Conv. 383/AT 05 Dodge Ram 4x4 Cummins 06 GoManGo R/T Daytona #757 68 Coronet 440
[Re: 44D6PAKCUDA]
#2730705
01/07/20 05:47 AM
01/07/20 05:47 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Is there way to remove the 3 cable from a driver side remote mirror (A/E/B Body) and still be able to reattach/reassemble the mirror? It looks like there are some type of metal barrel crimped on the end of each cable,and if you to just clip them off to remove the cables from the housing(mirror glass end),there my not be enough cable left to try and reattach them.Any suggestions? It's easy. First you need to notice that the cables and barrels is color coded. You need to reproduce this so you get the cables back in the right slot. Colored electrical tape works well. Remember you have to mark BOTH the barrel and cable. Next take a small flat bladed screwdriver and slowly work the jaws of the clamp apart. You want to get it a minimal distance apart then slip the cable out. Once you have all three out you can separate the two pieces.
[Re: Morty426]
#2730724
01/07/20 09:15 AM
01/07/20 09:15 AM
Posts: 1,331 Clinton, NJ
njmopar
Clinton, NJ
It's easy.
I wouldn't call it easy. The clamp jaws you need to spread are a lightweight cast material. You need to be really careful not to split when opening or reclamping. I had varied success. I was able to use an expoxy held with a zip tie until it cured for one that split on reclamping.
[Re: 44D6PAKCUDA]
#2730747
01/07/20 10:37 AM
01/07/20 10:37 AM
Morty426
Sacramento CA
Are you referring to the remote/knob end or the end with the mirror head? I assume the remote knob end as the mirror head end has the small connectors on the end of each cable and can not pull thru the mirror plate. I did the end where the knob is IIRC
[Re: 44D6PAKCUDA]
#2731318
01/09/20 05:51 AM
01/09/20 05:51 AM
Posts: 1,923 Medina, Ohio
HEMICUDA
Medina, Ohio
Are you referring to the remote/knob end or the end with the mirror head? I assume the remote knob end as the mirror head end has the small connectors on the end of each cable and can not pull thru the mirror plate. If you break the pot metal that clamps the cable sleeve, send me an email Jimmy, I have a new one you're welcome to.
[Re: Morty426]
#2731651
01/10/20 08:23 AM
01/10/20 08:23 AM
HEMICUDA
Medina, Ohio
Are you referring to the remote/knob end or the end with the mirror head? I assume the remote knob end as the mirror head end has the small connectors on the end of each cable and can not pull thru the mirror plate. I did the end where the knob is IIRC On it's way Jimmy.
