"as if" restoration #2730279
01/05/20 02:13 PM
01/05/20 02:13 PM
AndyF Online content OP
AndyF  Online Content OP
I've been working on my '72 Duster for a while and ended up going in a direction of "as if" restoration. What that means to me is the engine compartment is put together "as if" the factory had modern technology in 1972. So what would a 1972 Duster look like if the factory had access to EFI and modern electronics. Of course there is no way to know for sure what they would've done so I just did my best. I'm using OEM parts as much as possible as well as factory type bolts, wires, harnesses, hoses, etc. I used a Cordoba radiator and shroud since they are factory parts but are designed for a big block. I used the late model spool type engine mounts since I think the factory would've gone that way had they put a big block in a Duster. I'm not sure on the headers. Ford engineers have used headers on the Mustang so it is possible that Mopar engineers would have installed headers. I used a billet master cylinder which I'm sure the factory would not have used but I liked the built in prop valve and it looks nice. I went with a Denso alternator which I think the factory would've done if they had had access to modern alternators.
The car also has a big anti-sway bar and 13 inch brakes with Viper rotors which I'm sure the factory would've installed if they had the technology. Anyway, just my take on things.
Re: "as if" restoration [Re: AndyF] #2730296
01/05/20 02:40 PM
01/05/20 02:40 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
I suppose that's one way to look at it, any year you were thinking? I know today they would never use a copper brass radiator with mechanical fans (it would be aluminum/plastic with electric fans), a car without power brakes or power steering.
Otherwise a lot of this looks familiar to my Small Block. I've also got a T56 Magnum transmission.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: "as if" restoration [Re: goldduster318] #2730313
01/05/20 03:11 PM
01/05/20 03:11 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Chrysler would've used whatever was the least-expensive option available to them that would get the car past its warranty period laugh2
Engine would all be one color, and things would also generally be as quick & easy to assemble as possible.
That said, it's a clean installation with obviously a lot of thought applied.
I think painting the fender flanges would be a nice finishing touch; everything else is so clean thumbs.
Honestly, I think the interior should either be blue or black, and not a mix of the two colors, but those are just my (unsolicited) opinions.
Re: "as if" restoration [Re: topside] #2730351
01/05/20 05:30 PM
01/05/20 05:30 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I recently had a LOT of sheet metal replaced on my '69 RR as well as some additional stuff like mini tubs, frame connectors, torque boxes etc installed at the same time. The guy doing the work said he'd make it look factory and I told him if I wanted a sloppy mess there are a hundred other shops I could have taken it to at a fraction of the cost !! If you want to make it look "factory", do it as if the day they built your car they actually gave a damn.
Re: "as if" restoration [Re: topside] #2730374
01/05/20 07:46 PM
01/05/20 07:46 PM
I would've painted the fender flanges had I thought about it at the time. Just an oversight on my part. The interior is a similar story. It was originally med blue but the only parts I've been able to find so far are black. So it is gradually becoming a black interior. I found a NOS dash pad that was black, a like new steering wheel that was black, a set of Duster bucket seats that were black, etc. So the car appears to be headed towards Spinnaker White exterior and Black interior. Not what I had planned but just kind of where it is heading.
Re: "as if" restoration [Re: AndyF] #2730379
01/05/20 08:02 PM
01/05/20 08:02 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Don't sweat the details. Just cover it all with a big plastic cover. That's what they do today, isn't it? grin
Master, again and still
Re: "as if" restoration [Re: DaveRS23] #2730636
01/06/20 08:53 PM
01/06/20 08:53 PM
Not for me. I hate that look. I'm not even sure why the OEMs spend the extra money for those plastic covers. They don't usually waste money like that. Guess they figure it looks good or something.
Re: "as if" restoration [Re: AndyF] #2730840
01/07/20 03:59 PM
01/07/20 03:59 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Pretty cool. But I thought Mopar switched to Denso alternators smile
PS Did you ever sort out the "as if" Borgeson steering box/pump setup?
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: "as if" restoration [Re: 71TA] #2730937
01/07/20 10:15 PM
01/07/20 10:15 PM
Yes I have that all figured out. I designed some brackets to mount a new Type II Corvette type PS pump to my big block. It came out looking pretty nice. Laser cut brackets, formed and then powder coated. I included a square hole for a breaker bar. I went with ARP bolts rather than factory style. Used formed tubing for the pressure line to get it around and down the backside of the pump.
Re: "as if" restoration [Re: 71TA] #2730940
01/07/20 10:18 PM
01/07/20 10:18 PM
I did put a Denso alternator on the Duster but I mounted it down low so it is out of the way. Never liked how the factory stuck them way up in the air.
Re: "as if" restoration [Re: AndyF] #2733923
01/17/20 02:25 PM
01/17/20 02:25 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Grand Cherokee uses the same pump, along with the older cherokee's, they may have different rib count pulleys though depending on the engine. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: "as if" restoration [Re: astjp2] #2734264
01/18/20 05:26 PM
01/18/20 05:26 PM
Some Mopar guys have a hard time with using Corvette parts so maybe I'll just tell them the PS pump is from a Grand Cherokee. Then they'll be able to sleep better at night.
