Re: I thought they knew how to weld
[Re: moparx]
#2730591
01/06/20 05:16 PM
01/06/20 05:16 PM
Posts: 11,747 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
A loose and/or spinning housing can split a factory fuel tank pretty easily and create a substantial fire. Nothing to fool with. Takes a pretty decent welder to make enough heat to get that stuff put together correctly.
A welded brace WILL bow the housing regardless being in a jig. The trick is to pull and hold the housing in the opposite direction the correct amount when welding it. Once cool, it will relax back to where it should be, if it was done correctly.
[Re: Sniper]
#2730650
01/06/20 09:42 PM
01/06/20 09:42 PM
Posts: 1,115 Usa
A39Coronet
Usa
This is why I don't weld, a mans got to know his limitations. Well said, welding and painting are things I only do when it's realistic for me, and usually only when both are hidden from sight or can't really fail. I'm curious to see how they respond to OPs email.
[Re: Exit1965]
#2730678
01/06/20 11:32 PM
01/06/20 11:32 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
I think the thread makes sense in terms of how bad the quality was for a shop that should do better.
But it doesn't mean someone couldn't do a good job on them at their home, even if they're not an expert welder. I think especially back in the day, more often then not people did this in their garage or driveway without the perches falling off some time later, and without ever seeing any effect of a warped housing.
It's not that hard if you have the right settings and prep. That makes what this shop put out there even more egregious. Thank you... that is exactly the point I was trying to make ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) The local shop will be doing it tomorrow. As someone already mentioned, welding and painting are best left to others. Definitely in my case. Incidentally, I asked Cass (Dr. Diff) about this mess and he said, "I would break the other spring perch off and weld new ones on. You won't warp the tubes". I figure he knows what he's talking about ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: DoctorDiff]
#2730756
01/07/20 11:31 AM
01/07/20 11:31 AM
Posts: 22,749 Bitopia
jcc
Bitopia
You guys are missing the lesson here.
NOBODY can defend these welds.
Even a good looking weld can be problematic.
Obviously in this case as already understood by many a good welder has to balance a fine line between warpage and proper penetration.
Nobody has yet mentioned the fact there was zero weld joint prep, a 45Deg chamfer?
Being a minimal l trained welder does not qualify one to inspect welds definitively, especially ones that they did not weld themselves.
But this is were the wheels come off (pun intended):
In most cases in regular use, nobody needs to spend much time inspecting OEM welds.
This was a weld that is effectively non redundant and risks possible catastrophic outcome in failure.
Our uses are not "regular", our modifications are not OEM tested or designed, therefore anything "we" weld should be suspect, forever.
The OP's welds looked like crap from day one.
They did not wrap around the top of the perch, the highest stressed welded area.
Nobody can convince me the entire welded perch weld failed the second the u bolt was removed.
Most likely it failed slowly over time.
Any weld exposed to the elements that is incrementally failing often shows warning signs, visible cracks, rust stains, etc.
The mistake here is these signs were not spotted.
Why is for the OP (or victim?) to address.
I do my own welds, and I check every one, forever.
[Re: DoctorDiff]
#2730757
01/07/20 11:33 AM
01/07/20 11:33 AM
Posts: 59 USA
Kippy
USA
My friend tore the spring perches off his '85 W-150 while doing a burn out. The pinion spun straight up and separated the driveshaft at the slip joint. The OEM welds did not penetrate the tubes. I'm surprised it didn't happen years earlier. Whatever Dr D says concerning anything automotive is gospel for me. A real gentleman. He helped me when everyone couldn't The weld as posted if you notice did not penetrate the edges of the perch. That edge should not be visible as the weld should have penetrated it. A common mistake of beginers is not "catching" what your welding. In the case of theses perches in addition to being way to cold which results in no penetration, whoever welded theses perches just played down a bead next to the perch. He had almost no weld on the perch which shows me he wasn't watching what he was doing. Ive told so many guys to catch both parts. Even if the person who welded this was inexperienced if he or she had the amperage turned up and caught the perches, the weld most likely would have held. Anything welded on any vehicle driven on roadways has to be properly done, this thread is a perfect example of this. While im no Mopar expert, I am a journeyman union Boilermaker or was as im retired now
[Re: Kippy]
#2731069
01/08/20 12:38 PM
01/08/20 12:38 PM
DrCharles
West Plains, MO
The plot thickens... I heard back from the original shop. I have looked up your invoice to see what all work we did for you. The invoice and paperwork does not show anything about us installing perches on the rear end. We only removed your old perches. I'm not sure who welded the perches on your housing but we have no record of doing it. I have attached all paperwork including the note you sent with the housing about what you needed done. Please see the attachments! I have the same invoices, having saved every receipt for 22 years. Nothing showing any welding/moving perches, and it only makes sense that if the housing were being narrowed, back-braced, ends cut off and rewelded for alignment, that I'd have had them do the perches then! Very strange ![work work](/ubbthreads/images/graemlins/custom/work.gif) Anyhow the local fab shop removed both, cleaned them up and re-welded them (securely) and I hung it back under the Dart. Next week the chunk will return and I'll reinstall the axles. Hopefully everything will just slide in ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif)
[Re: DrCharles]
#2731084
01/08/20 01:57 PM
01/08/20 01:57 PM
jcc
Bitopia
The plot thickens... I heard back from the original shop. I have looked up your invoice to see what all work we did for you. The invoice and paperwork does not show anything about us installing perches on the rear end. We only removed your old perches. I'm not sure who welded the perches on your housing but we have no record of doing it. I have attached all paperwork including the note you sent with the housing about what you needed done. Please see the attachments! I have the same invoices, having saved every receipt for 22 years. Nothing showing any welding/moving perches, and it only makes sense that if the housing were being narrowed, back-braced, ends cut off and rewelded for alignment, that I'd have had them do the perches then! Very strange ![work work](/ubbthreads/images/graemlins/custom/work.gif) Anyhow the local fab shop removed both, cleaned them up and re-welded them (securely) and I hung it back under the Dart. Next week the chunk will return and I'll reinstall the axles. Hopefully everything will just slide in IMO, a giveaway would be if any of the paperwork shows an specific (vs say Narrow "X" inches) dim for the housing. If so they also would likely incldue a specific dim for the ctr to ctr perch location. If the Perch dim is not on an invoice that had a new housing dim, I would lean towards the feeling your original vendor did not reattach the perches, some one else did. I have in the past welded up a housing, and left the perches off, in order to test fit and to get the perch exact dim/location and angle, and then welded them later, so two welders involved in your saga is possible as I see it. First vendor might need an internet "nevermind". edir: on further reflection, ttis new info might explain a lot, for instance, why the perches were not prepped (45Deg chamber), that the weld was done on the car, over head, out of position, and restricted access, the weld area might have been contaminated by paint/rust, all items a pro welder would have resisted, and a novice would not.
[Re: Neil]
#2731225
01/08/20 08:04 PM
01/08/20 08:04 PM
DrCharles
West Plains, MO
That did occur to me also, but the housing ends do look properly welded. ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) And so far they have not fallen off. ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif) Hard to tell with the back brace - it looks good except for the end tacks (that you noted in the pics), but it is definitely possible to have a nice looking bead just lying on the surface. I'll have to see if it cracks or pops off with a few good launches. ![drive drive](/ubbthreads/images/graemlins/custom/drive.gif) Anyhow, there's no way I would have told them to only "remove the perches"... how was I supposed to put the housing back under the car then? ![work work](/ubbthreads/images/graemlins/custom/work.gif) Although I'd have rather not spent the $$$ by forgetting the gear lube and ruining a brand new Dr. Diff center section, the silver lining is that I found the defective welds before anything spun and did ugly things. I had planned to install the traction bars at some later date after putting some miles on the car...
[Re: DrCharles]
#2731487
01/09/20 04:39 PM
01/09/20 04:39 PM
jcc
Bitopia
Thanks, but I meant it to be clearly a rhetorical question. ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif) I already knew what my pinion angle was, and didn't want it changed, just the perches moved from stock B-body, to A-body with 3" spring relocation. No experienced fab/weld shop would relocate the perches only based on the above info, and additionally, they would want it (angle in degrees and perch ctr to ctr dim and if any offset is desired) in writing, to eliminate potential call backs. The members previous reply on tack welding is the tried and true method. Seems like the story is still missing some details, and since I'm newly on the OP's Ignore list, I don't have any issue with "pulling the curtain back". ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) So nobody quote me here. ![panic panic](/ubbthreads/images/graemlins/custom/panic.gif)
