E body front end noise #2730361
01/05/20 06:45 PM
01/05/20 06:45 PM
Moved to N.E. Tennessee
GomangoCuda Offline OP
When I bounce the front end it sounds like a metal on metal screaching noise pretty close to the front. Could the strut rod bushing be worn bad enough to cause the washer to rub on the kmember? Dry torsion bars? No other noticeable ill effects. It's quit possible that the entire front suspension is oem.
Thanks, I've never been a front end guy.
Re: E body front end noise [Re: GomangoCuda] #2730370
01/05/20 07:26 PM
01/05/20 07:26 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
I'd believe the strut rods, if the bushings look old its certainly possible.
I would also check the clearance between the t-bar pivot and the two halves of the lower control arms, if it has excessive clearance they will make noise while driving too. If that's the case the fix is to take them out and "pinch" them and re-weld the bump stop mount.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: E body front end noise [Re: GomangoCuda] #2730383
01/05/20 08:20 PM
01/05/20 08:20 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Could be a number of things...bottom shock mount, lower control arm pivot shaft, strut rod. If you suspect its oe, it's probably a good idea to go through the entire front end. You could end up finding multiple issues. May find the issue before it turns into something else/ruins something. If you mark the upper control arm adjusters and don't change the end link adjusters, depending on what needs changed you may not need an alignment.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: E body front end noise [Re: A39Coronet] #2730403
01/05/20 09:28 PM
01/05/20 09:28 PM
ohio
ruderunner Online content
ruderunner  Online Content
ohio
Id be willing to bet that you have more than a few dried out disintegrated bushings. Lower control arm are notorious
Angry white pureblood male
Re: E body front end noise [Re: GomangoCuda] #2730418
01/05/20 10:40 PM
01/05/20 10:40 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Look at the front strut rods where they go into the K-member - look to see that the area(s) of the K-member are not broken. I had this condition on a '74 Cuda.
Re: E body front end noise [Re: Sunroofcuda] #2730432
01/05/20 11:40 PM
01/05/20 11:40 PM
Anybody know a good frontend guy in N.E. Tennessee tricities area? 10 years ago I would have broke out the fsm and bought or made the necessary tools. Now I don't know. Age, arthritis and a bad back may have caught up with me. I'll get it up in the air and see I can see anything broken but I think all the rubber parts are probably disintegrating. They could be over 50 years old. The kmember could in fact be broken. It is not original to the car and looked like it had probably been lightly hit before it was installed by previous owner. If I have to rebuild the entire frontend I guess I will looking for a better k as well
Re: E body front end noise [Re: GomangoCuda] #2730598
01/06/20 05:45 PM
01/06/20 05:45 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
Check the frame rails where the k frame bolts to. Could be cracked or rusted out
Re: E body front end noise [Re: AARCONV] #2730689
01/07/20 12:14 AM
01/07/20 12:14 AM
Good point. I'll check that close. It just occured to me that I should also check torque on the kmember to frame bolts.
I think I'll put it up on ramps and see if I can listen and feel from underneath while my wife bounces it a little to make it squeek. I still think it is coming from the area of the strut rods but I'll also look hard at the frame and kmember while I'm under there. Thanks to everyone for their ideas on where to look.
Re: E body front end noise [Re: GomangoCuda] #2730903
01/07/20 08:03 PM
01/07/20 08:03 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
mine is cracked right under the k frame bolt and it squeaks and creaks...time for a new frame or 2
Re: E body front end noise [Re: AARCONV] #2730945
01/07/20 10:33 PM
01/07/20 10:33 PM
Is it the frame rail or kmember that is cracked?
Re: E body front end noise [Re: GomangoCuda] #2730975
01/07/20 11:56 PM
01/07/20 11:56 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
Frame rail..look really good dirt hides it
