Re: new bullet
[Re: DoubleD]
#2730781
01/07/20 01:06 PM
01/07/20 01:06 PM
Posts: 19,366 Las Vegas
Al_Alguire
Las Vegas
Hopefully just a small hiccup on the way to some good numbers..
Re: new bullet
[Re: racerhog]
#2741227
02/09/20 01:46 PM
02/09/20 01:46 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Good luck, and it sounds like the motor is in good hands.
Re: new bullet
[Re: hustlin hoosier]
#2742896
02/14/20 04:07 PM
02/14/20 04:07 PM
Posts: 43,190 Bend,OR USA
Cab_Burge
Back together , all is good I think we gained a little. It made 1211 hp @ 8100, 1206 @8500. Peak torque was 827 @ 7300 and falls off nicely. In the past we have always ran the break in on the dyno, this motor is pretty much untuned as it only has 3 pulls on it . When we raised the vac from 12 to 17 we have another 12 - 15 hp. We all know there is only 1 dyno that counts and we won't get there for a couple of months. It is good to see someone else say the same things I think, the dyno is only a tool, the time slip and spark plugs are the final tool to use when trying to go faster
Re: new bullet
[Re: Jeremiah]
#2749321
03/05/20 04:42 PM
03/05/20 04:42 PM
hustlin hoosier
Due to hardship issues at work, this motor is for sale. The price is $35,000 brand new only 3 dyno pulls. comes with several spares and carb. Also I have a Rossler TH210 with a mopar bell, flexplate and adpter to go to mopar it comes with a billet all aluminum Neal Chance converter. The buyer can take which ever converter he wants as I have an 8 inch that goes wrks with the above motor or a 9 inch if you make big Hp. Trans converter package is $6,000. 812 569 0494
