New Glass
#2729842
01/03/20 10:01 PM
01/03/20 10:01 PM
Posts: 10,570 Freeport IL USA
poorboy
Freeport IL USA
For those of you that didn't know, I recently replaced the back window frame on my 48 Plymouth coupe. The original window frame on my coupe was rotted out all the way across the top, and in both bottom corners. There is nothing that remains original on this car,it was a rusty body shell put onto a Dakota Chassis and in the last 7 years, my wife and I have driven this over 50,000 miles. When it was thrown together, I fully expected it would be dead in a year or two. The rear window frame was one of those things I wasn't really too concerned about. Last year, it started leaking water, the time had come to do something.
I spent a little time looking for the sheet metal surrounding the business coupe's flat glass but came up empty handed. So then I searched out any rear window frame with some attached metal I could weld in. That process led me to a rear window frame for a 37 Ford coupe, that is a 2 piece split window. That window frame is now installed in my car, and the search began for new rubber weatherstripping and new glass. Since I have no pattern, I simply bought replacement glass for that 37 Ford coupe from Bob's Classic Glass. The delivered price for the green tinted 2 pieces of glass was $95, about 1/2 of what my local guy wanted. I ordered the glass on 12/20 and it arrived today, 1/3. The glass looks really good. It looks to fit better then the rubber I ordered from Dennis Carpenter, a prominent Ford aftermarket supplier, which I ordered the same day and was here within 2 days.
When I'm ready to do all the glass on my 49 Dodge pickup, I'm getting it from Bob's Classic Glass. He even has new truck quarter windows available for less money then I've seen used stuff priced at. Just wanted to give you guys a heads up. Pictures or it didn't happen. The 1st picture is the new window frame welded in. The 2nd picture was the original window frame. Gene
Re: New Glass
[Re: poorboy]
#2729918
01/04/20 10:59 AM
01/04/20 10:59 AM
Posts: 19,413 north of coder
moparx
looks like a good solution you thought of. surprisingly, using ford parts can sometimes be a saving grace because there are so many parts being reproduced. plus, your repair looks good, and matches the theme of the car well. good job gene !
Re: New Glass
[Re: Old Ray]
#2730178
01/05/20 04:06 AM
01/05/20 04:06 AM
Posts: 4,247 Newfoundland
codfish
Newfoundland
Ya looks great . Nice job I've used Bobs as well for door glass on my 37 Coupe. Couldn't find it anywhere else actually (without the vent windows ). His price, including shipping to eastern Canada was still cheaper than having it made locally. codfish
Re: New Glass
[Re: Cab_Burge]
#2756278
03/26/20 08:04 PM
03/26/20 08:04 PM
poorboy
Freeport IL USA
Try www.bobsclasicautoglass.com When you sort through all the mess that used to take you directly to a specific website, you want to click on his "home" page. I need to take a picture of my finished rear glass. Gene
