Re: Consistentcy
[Re: jwb123]
#2729302
01/02/20 11:36 AM
01/02/20 11:36 AM
Posts: 1,894 Spahn Ranch
RMCHRGR
Spahn Ranch
I have a brake pressure gauge and I leave with the same brake pressure with a foot brake car. Would have never thought about that, thanks for the tip!
'71 Duster '72 Challenger '17 Ram 1500
Re: Consistentcy
[Re: RMCHRGR]
#2729304
01/02/20 11:45 AM
01/02/20 11:45 AM
Posts: 8,035 Tulsa OK
Bad340fish
Tulsa OK
Best thing I can offer is to be consistent with engine temps. I drive my mid ten second car to the track so everything is good and warm when I start the day and I think that helps the rear axle and trans temp to stay consistent. I run electric fans and water pump and I try to hit the burnout box at 140 degrees every pass. My car usually doesn't lose the race, its always the guy hitting the gas on the starting line!
68 Barracuda Formula S 340
Re: Consistentcy
[Re: RMCHRGR]
#2729305
01/02/20 11:46 AM
01/02/20 11:46 AM
Posts: 20,202 PA.
pittsburghracer
"Little"John
"Little"John
PA.
It all starts with consistent 60 foot times.
Re: Consistentcy
[Re: pittsburghracer]
#2729319
01/02/20 12:36 PM
01/02/20 12:36 PM
Posts: 1,030 ohio
67mprfan
ohio
All replies above-mentioned are correct so I will say seat time also being comfortable and ready for when the lights start dropping
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
Re: Consistentcy
[Re: dvw]
#2729403
01/02/20 05:07 PM
01/02/20 05:07 PM
Posts: 11,706 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Stuff wears out. Don't expect it to last forever. Shocks, tires, ignition parts. fuel system, valve springs. I'd like to have a dollar for every guy who has said "I just put those shocks on 5 years ago." Yeah, and you beat them to death in the trailer dragging it up and down the road. Pay attention to that stuff.
Re: Consistentcy
[Re: Pacnorthcuda]
#2729462
01/02/20 08:34 PM
01/02/20 08:34 PM
Bad340fish
Tulsa OK
Slow the car down.
As much as no one wants to do that, it lends itself to consistency....big time! LOL To an extent, I tried to race my Jeep awhile back. It ran from 17.82 to 17.09 lol. I figured it was intake temp related, if I were to race it again I would probably hang a tube out the bottom of the compartment to let it get fresh air. Coolant temp was the same each pass.
Re: Consistentcy
[Re: Cab_Burge]
#2729524
01/02/20 11:51 PM
01/02/20 11:51 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Just keep chipping away at the car over time. Most of the cars that I know print tickets like copy machines are cars that have been sorted out over time. My car is starting to get to the point where I feel like I have an equipment advantage most times I stage it. As you race, you need to pay close attention to what went wrong and why. Then work on those things. The exact same goes for your own performance behind the wheel. The ability to focus in on a singular thing when you need to is a skill. If you come away from a round where you missed you’re number, you need to know why. Can you be sure you hit your shift points? What was your exact thought just after the staged light came on? If you’re like me, it took a while to even recognize that I wasn’t cued into those things as keenly as I thought I was.
Bottom line: it is hard! Really hard... to be consistently good as a bracket or index racer.
Re: Consistentcy
[Re: StealthWedge67]
#2729565
01/03/20 08:50 AM
01/03/20 08:50 AM
Posts: 10,049 MN
JERICOGTX
MN
Hold a 10th, and drive the stripe accordingly. LOL.
69 GTX
68 Road Runner
Re: Consistentcy
[Re: J_BODY]
#2729577
01/03/20 09:35 AM
01/03/20 09:35 AM
Posts: 10,049 MN
JERICOGTX
MN
I agree with the converter being an important key. I have one for my 727 that produced a stack of 1.34 60ft times at 5 different tracks. It got so good we had a right and left lane dial at one. Helped us go a ton of rounds. My other converter will result in faster ETs, and would dip into the high 1.2/low 1.3 60, but not consistent. Of course doing this on a 10” tire mid 9sec ride leaves something to be desired. .....of course I changed intakes, went to a dominator AND set the 727 aside for a 904 so basically ruined a perfectly good bracket car 4 link, and 14x32's..
69 GTX
68 Road Runner
