4 speed guy #2726321
12/23/19 08:31 AM
12/23/19 08:31 AM
CA.
RAY1969CARS Offline OP
CA.
Doz NHRA Require a reverse lock out lever on your shifter ???
Re: 4 speed guy [Re: RAY1969CARS] #2726375
12/23/19 01:01 PM
12/23/19 01:01 PM
Washington
madscientist Offline
Washington
The NHRA doesn't require a lock out for a stick. That shifter you have is the Super Shifter III and they don't make it any more. A very good shifter.
Re: 4 speed guy [Re: madscientist] #2726389
12/23/19 01:49 PM
12/23/19 01:49 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
G-Force/Long.
Re: 4 speed guy [Re: madscientist] #2728773
12/31/19 11:28 PM
12/31/19 11:28 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
That bracket is a nice piece. Moves the shifter up and towards the driver. I have the same set up in my 65
Re: 4 speed guy [Re: NTOLERANCE] #2729544
01/03/20 01:14 AM
01/03/20 01:14 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
So, is that your shifter? is your question if NHRA doesn't require one you would want to not have a reverse lock out on your shifter? As stated above, the Hurst super shifter 2 is a very good shifter. No need to spend money on a in line .
