Lifter replacement do I Use break-in oil? #2728340
12/30/19 04:09 PM
12/30/19 04:09 PM
Newark DE
Dogpro Offline OP
Dogpro  Offline OP
Newark DE
70 Challenger stock 318 I am changing the lifters due to some noisy ones. The question is do I need to use a break-in oil to prevent damage to the cam or once a cam is broke in is it good to go? I don't want to ruin something for the price of an oil change. Thanks, Lou
Lou P.
Newark DE
Re: Lifter replacement do I Use break-in oil? [Re: Dogpro] #2728346
12/30/19 04:50 PM
12/30/19 04:50 PM
Sweden
Mopar Guy Offline
Mopar Guy  Offline
Sweden
Yes i would use break in oil and run engine on startup like if it whas a new cam so dont let it idel !
Re: Lifter replacement do I Use break-in oil? [Re: Mopar Guy] #2728349
12/30/19 04:56 PM
12/30/19 04:56 PM
Morrow, OH
markz528 Online content
markz528  Online Content
Morrow, OH
Fully agree................
Re: Lifter replacement do I Use break-in oil? [Re: markz528] #2728574
12/31/19 03:15 PM
12/31/19 03:15 PM
moparx Offline
moparx  Offline
i bought a 73 plymouth 4dr one time with a 318 that had a bad misfire.
turned out to be two push rods went through the rockers, allowing the lifters to jump around and come apart.
it was run quite a while by the previous owner, and by the time i got it, the lifter parts were MIA.
i just got a couple lifters off the shelf, plus a couple of rockers, and stuffed everything together.
ran it for several years after that with no problems.
but in the OP's case, use new lifters with a dab of cam paste on the bottoms, break in oil, and treat it like a cam change.
as said, NO idle time.
beer
Re: Lifter replacement do I Use break-in oil? [Re: moparx] #2728803
01/01/20 02:46 AM
01/01/20 02:46 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
You could just disassemble and clean the lifters and see if they quiet down.
The most important thing if you are replacing them is to coat the lobes and bottom of the lifters liberally with cam assembly lube and then assemble and rotate the engine a couple of times to verify that all the lifters spin. They should all turn like they are gear driven together at the same speed. I believe at least 95% all of cam failures happen because a lifter or lifters don't rotate consistently on the cam.
As for oil, you can pay the $$$ for the flavor of the month boutique oil if you want but if the lifters all spin as they should, any 15w40 diesel oil be it Rotella, Delvac or Walmart brand will be more than sufficient IMHO.
Kevin
Re: Lifter replacement do I Use break-in oil? [Re: Twostick] #2729002
01/01/20 02:53 PM
01/01/20 02:53 PM
that's what I'd do. In the same hole(s) of course. No (related) changes preceding this? I would check preload. they got noisy all of a sudden for a reason.
Re: Lifter replacement do I Use break-in oil? [Re: RapidRobert] #2729108
01/01/20 07:03 PM
01/01/20 07:03 PM
Newark DE
Dogpro Offline OP
Dogpro  Offline OP
Newark DE
Thanks for all the replies guys. I actually forgot about using cam lube. I'm not sure why they started to get noisy but they have been in the engine 20 years but only about 10,000 miles on them I figured maybe sitting in one spot over the winters may have taken a toll on them shruggy. I figure if i'm going through the trouble of taking it apart I might as well change them.
Lou P.
Newark DE
Re: Lifter replacement do I Use break-in oil? [Re: Dogpro] #2729179
01/01/20 10:16 PM
01/01/20 10:16 PM
You may have better hydrauilc lifters in your motor now than you can buy now work scope shruggy
Re: Lifter replacement do I Use break-in oil? [Re: Cab_Burge] #2729320
01/02/20 12:36 PM
01/02/20 12:36 PM
South Lyon, Michigan
6bblRoadrunner Offline
Have you checked oil pressure? Maybe your pump is going south and causing the lifter noise. Just a thought.
Re: Lifter replacement do I Use break-in oil? [Re: 6bblRoadrunner] #2729341
01/02/20 02:00 PM
01/02/20 02:00 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
If it's the original 318 and never been apart or hasn't had a timing chain in decades, the pump pickup could be plugged up with assorted nylon timing gear teeth too.
Kevin
Re: Lifter replacement do I Use break-in oil? [Re: Twostick] #2729607
01/03/20 10:42 AM
01/03/20 10:42 AM
Newark DE
Dogpro Offline OP
Dogpro  Offline OP
Newark DE
The engine was rebuilt in the mid 90's with new pump and timing chain. I only have the rallye dash oil gauge but it still shows good pressure. The lifters do quiet down after a few minutes but it tells me some of them are leaking down. I currently have the motor out of the car because my power steering box was leaking which I sent out for rebuild so I figured I would pull the the motor for easier access and while it was out detail it and perform some maintenance.
Lou P.
Newark DE
Re: Lifter replacement do I Use break-in oil? [Re: Dogpro] #2729617
01/03/20 11:40 AM
01/03/20 11:40 AM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
What grade of oil are you running in it?
Kevin
Re: Lifter replacement do I Use break-in oil? [Re: Twostick] #2729819
01/03/20 09:16 PM
01/03/20 09:16 PM
Newark DE
Dogpro Offline OP
Dogpro  Offline OP
Newark DE
For the last 4 or 5 oil changes I have used Mobil one 10w30
Lou P.
Newark DE
Re: Lifter replacement do I Use break-in oil? [Re: Dogpro] #2730410
01/05/20 10:22 PM
01/05/20 10:22 PM
California, U.S.A.
Torquemonster440 Offline
California, U.S.A.
Mobil one with a ZDDP addative hopefully?? If not, I would highly recommend a ZDDP addative, or an oil with a high ZDDP content to prevent issues with a flat tappet cam. I hope it's not too late. frown
1966 Satellie.. 12.55 @107.75. 906 heads. 3780 lbs.
Re: Lifter replacement do I Use break-in oil? [Re: Torquemonster440] #2730412
01/05/20 10:25 PM
01/05/20 10:25 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Mobil 1 15W-50 has plenty of ZDDP, but he may want to run a lighter oil.
https://mobiloil.com/~/media/amer/us/pvl/files/pdfs/mobil-1-oil-product-specs-guide.pdf
Re: Lifter replacement do I Use break-in oil? [Re: DrCharles] #2730416
01/05/20 10:38 PM
01/05/20 10:38 PM
California, U.S.A.
California, U.S.A.
Mobil 1 15w-50 sounds like a diesel blend that may have enough ZDDP, but the 10w-30 is a modern synthetic oil that is engineered for modern roller cams, ... not flat tappets. Hopefully it's just an issue with lifter bleed down, but for future reference when choosing a flat tappet cam oil, make the Zinc/ZDDP level your first priority.
Re: Lifter replacement do I Use break-in oil? [Re: Torquemonster440] #2730419
01/05/20 10:44 PM
01/05/20 10:44 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
I thought he was running a flat tappet cam.
From the Mobil chart I linked (15W-50):
"Boosted, higher viscosity, advanced full synthetic formula designed for performance vehicles. For high HT/HS applications. Racing and flat tappet applications."
shruggy
Re: Lifter replacement do I Use break-in oil? [Re: DrCharles] #2730614
01/06/20 07:41 PM
01/06/20 07:41 PM
Newark DE
Dogpro Offline OP
Dogpro  Offline OP
Newark DE
Yes I have been putting a ZDDP additive in it up
Lou P.
Newark DE
Re: Lifter replacement do I Use break-in oil? [Re: Dogpro] #2730651
01/06/20 09:44 PM
01/06/20 09:44 PM
California, U.S.A.
California, U.S.A.
Ok, cool.. that ZDDP content is the key to making these flat tappets live a long healthy life, aside from proper break in if course. And yes, to your original question, definitely use a "break-in" oil with a new set of lifters. No idling, bring it up to at least 2k and vary the rpm between 2k and 2,500 rpm over a 20 min heat cycle. This method has worked for me several times over the years. Joe Gibbs break in oil is great stuff.
