Re: Roller lifter inspection
[Re: Wirenut]
#2729129
01/01/20 08:09 PM
01/01/20 08:09 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
This is the best I could do to check it. Thanks Doug Would clean and dry mean soaked in solvent or lacquer thinner to get the oil out and blow dry? Not sure I’m following re the measurements. Do you mean measure the width of the wheels to see if something is mushrooming ? Or just check the clearance between the roller and lifter body? G
[Re: Clanton]
#2729141
01/01/20 08:43 PM
01/01/20 08:43 PM
Posts: 2,175 Duloc
The Shadow
Duloc
This is the best I could do to check it. Thanks Doug Would clean and dry mean soaked in solvent or lacquer thinner to get the oil out and blow dry? Not sure I’m following re the measurements. Do you mean measure the width of the wheels to see if something is mushrooming ? Or just check the clearance between the roller and lifter body? G that indicator check isn't going to help if the axle is worn
[Re: Clanton]
#2729252
01/02/20 06:14 AM
01/02/20 06:14 AM
Posts: 9,835 MI, usa
dvw
MI, usa
This is the best I could do to check it. Thanks Doug Would clean and dry mean soaked in solvent or lacquer thinner to get the oil out and blow dry? Not sure I’m following re the measurements. Do you mean measure the width of the wheels to see if something is mushrooming ? Or just check the clearance between the roller and lifter body? G I'd move the indicator 90 degrees to check the axle. But you need an indicator that measures in ,000x". Still tough to get an accurate reading without a fixture. The width measurement is the body itself. Measure the body parallel to the axle with a mic. Doug
[Re: Wirenut]
#2729419
01/02/20 05:55 PM
01/02/20 05:55 PM
Posts: 4,048 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Testing OEM applications we check lash with a .0001" resolution dial indicator WHEN NEW. typically they'll have about .0003/4 NEW then they'll settle quickly another .0002 for a total of .0006ish WHEN the lash grows again THEY ARE ON THEIR WAY TO FAILING. Some may start out .0005 to .0006 and settle. We also check them via rolling as described here. The key is to check them new. We even have had an occasional lifter SETTLE about .0011" but again typically the 'wear-in' is typically about .0002" form as measured new.
[Re: HardcoreB]
#2729638
01/03/20 12:55 PM
01/03/20 12:55 PM
Clanton
northern,Ohio,USA
While most may not be able to measure to OEM specs I would say some info is better than none.Thank you for your info to guide us. Testing OEM applications we check lash with a .0001" resolution dial indicator WHEN NEW. typically they'll have about .0003/4 NEW then they'll settle quickly another .0002 for a total of .0006ish WHEN the lash grows again THEY ARE ON THEIR WAY TO FAILING. Some may start out .0005 to .0006 and settle. We also check them via rolling as described here. The key is to check them new. We even have had an occasional lifter SETTLE about .0011" but again typically the 'wear-in' is typically about .0002" form as measured new.
[Re: Clanton]
#2729738
01/03/20 05:36 PM
01/03/20 05:36 PM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
I found out Comp no longer rebuilds their lifters just fyi. They will still rebuild them until they run out of parts. A couple of weeks ago they still had some parts available.
[Re: R3 Racing]
#2729976
01/04/20 01:34 PM
01/04/20 01:34 PM
Clanton
northern,Ohio,USA
I was just repeating what Dallas from Comp told me on rebuilding the lifters on the phone The lifters I bought from you are there now. The will rebuild 829's, no problem. This is my second set in a month.
[Re: Clanton]
#2729987
01/04/20 01:55 PM
01/04/20 01:55 PM
Posts: 2,499 PA
moparacer
PA
If they are old and used my inspection usually consists of taking them out, looking at them and throwing them in the trash.
Anyone who has had a lifter come apart and destroy and engine knows what I am talking about.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: moparacer]
#2729992
01/04/20 02:14 PM
01/04/20 02:14 PM
Clanton
northern,Ohio,USA
Old and used is kinda vague.lol If they are old and used my inspection usually consists of taking them out, looking at them and throwing them in the trash.
