help with 1989 chrysler dayton steering column
#2727783
12/28/19 05:35 PM
12/28/19 05:35 PM
Posts: 131 British Columbia
yellowgtx
British Columbia
My grandson just got a 1989 Chrysler Daytona. No keys. Looks like someone has been hacking away at it. Looking for info or a good exploded view of the working of the column. It will need a new ignition lock. but there seems to be a ton of slop in the shaft assemble as well. An good diagrams could help Thanks
After almost 71 years I am on my last car. A 65 Plymouth Satellite straight axle altered wheel base car.
Re: help with 1989 chrysler dayton steering column
[Re: Jim_Lusk]
#2727968
12/29/19 12:03 PM
12/29/19 12:03 PM
Posts: 21,435 It's a dry heat
gtx6970
It's a dry heat
It's been a long time since I've been into one of those. There are some fasteners that loosen up at the tilt. It'll be obvious once you get in there. There are 3 inverted torx head screws under the lock plate hsg that are real common to loosen up. and are a ROYAL PAIN to get to and tighten back up. They take a special tool to remove and re-install the lockplate , pt # 13 and the pivot pins - pt # 25 in the diagram . A decent mechanic can do it in maybe a couple hours. Someone not familiar with it may take all day
[Re: gtx6970]
#2727972
12/29/19 12:21 PM
12/29/19 12:21 PM
Posts: 30,430 Florida STAYcation
BeEtLeJuIcE !
The village idiot's idiot
Florida STAYcation
..... TAKE ALL DAY ... Isn’t this the same setup as the M bodies ? What a horror show !
[Re: BeEtLeJuIcE !]
#2728100
12/29/19 07:15 PM
12/29/19 07:15 PM
gtx6970
It's a dry heat
..... TAKE ALL DAY ... Isn’t this the same setup as the M bodies ? What a horror show ! All depends on the abilities of the person doing it. Not a hard job....just lots of small parts to keep track of and hold in place going together
[Re: BeEtLeJuIcE !]
#2728112
12/29/19 07:50 PM
12/29/19 07:50 PM
Posts: 11,573 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Not too bad to work on about the 4th or 5th time you get into one, and you have all the special tools. Still a PIA. FSM is your friend. Or take the whole column out and take it to someone who's familiar with them. I wouldn't even fool with it without the proper tools. You just end up damaging stuff and not fixing anything.
[Re: BeEtLeJuIcE !]
#2728121
12/29/19 08:12 PM
12/29/19 08:12 PM
gtx6970
It's a dry heat
Is it basically the same as the M ?
Is that special socket only available from Miller ? Been far to long for me to answer that one. The lock plate tool is avail thru most tool suppliers. Don't know about the pivot pin tool. I'm not sure if I even still have either of mine.
[Re: gtx6970]
#2728136
12/29/19 08:54 PM
12/29/19 08:54 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I seem to recall being into one of those and did a quick fix by tightening 3 of the fasteners, just to get the slop out of it. Couldn't get to the last one without it coming all apart. Still need the right tools to get into it that deep.
[Re: stumpy]
#2728161
12/29/19 10:00 PM
12/29/19 10:00 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
The major parts stores loan out the tools necessary to take that column apart. Most of which have been b!$^@ed up by the backyard hack who borrowed it the last time. Don't ask how I know about that.
[Re: poorboy]
#2728343
12/30/19 04:31 PM
12/30/19 04:31 PM
yellowgtx
British Columbia
PoorBoy I took a look at it yesterday. I highly do not think it will ever go back together now. He has some how got it stripped down. The slop is from that plate having come loose and slipped down on the shaft. BUT and a big but He still cant get the ignition lock out as he has no keys and so far no luck picking the lock to remove it. I am thinking that a complete column assembly with a key would be the best bet. Any ideas what years and models would change out on it. Sounds like best bet.
[Re: yellowgtx]
#2728358
12/30/19 05:43 PM
12/30/19 05:43 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
You do know there are only about 7 key patterns. I have used my 1984 Shelby key in my 87 Omni and in my 91 Daytona. My two Rampages also share the same key. It may just take a slight giggle while pulling the key back and fourth a bit but I have jimmied a lot of Mopars over the years, Chevy's too.
When I worked for the phone company we had all Chevy vans. When we had a tech lock himself out of his work van, I'd grab all the spares in the office and go out and jiggle the door lock and usely it was the 3rd key would open the door and unlock the steering. Would not start due to chip but I could unlock so a tow truck could move it as needed.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: poorboy]
#2735644
01/22/20 05:06 PM
01/22/20 05:06 PM
yellowgtx
British Columbia
OK the kid has it tore down and says he cant get the lock ass out still. Looks like back to a lock picker to get the key to turn to pull the inners out anyway. I cant remember but on them standard trans to start them Do you need the clutch pushed in and do you need a battery hooked up to car. The sad part of al this is he just sold a 1989 Dodge Shadow FOR $300 Would of been a great complete column change over candidate
Thanks for input Ron
