'01- & back vs. '02-up Dakota/Durango wirin harness ?sUPDATE #2728073
12/29/19 06:18 PM
12/29/19 06:18 PM
Buford, GA
I_bleed_MOPAR Offline OP
Buford, GA
IIRC, '02 wiring changed and nothing is compatible with the older stuff, correct?
Found a good deal on a nice '02 Dakota w/ a bad trans and was thinking of swapping in the 5.9 & 5 spd. from the Durango.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: '01- & back vs. '02-up Dakota/Durango wiring harness ?s [Re: I_bleed_MOPAR] #2728114
12/29/19 07:52 PM
12/29/19 07:52 PM
Guitar Jones Offline
Well it is conceivably doable since they are both PCI bus.
Mopar swap grid
Re: '01- & back vs. '02-up Dakota/Durango wiring harness ?s [Re: I_bleed_MOPAR] #2728118
12/29/19 08:01 PM
12/29/19 08:01 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
Tim....is it a red 4 door 2WD, pictured with a transmission sitting in the back? I would think you'd have to swap everything from your Durango into it to make it run. The 4.7 motors don't have distributors.
Re: '01- & back vs. '02-up Dakota/Durango wiring harness ?s [Re: JDMopar] #2728123
12/29/19 08:26 PM
12/29/19 08:26 PM
Buford, GA
Buford, GA
Jonesy- looks like '01-up is PCI while my '00 Durango is CCD. I would have sworn I bought an '01 Ram manual trans PCM but maybe it was a '00. I'm guessing the PCI & CCD PCMs are not compatible? Truck has a 5.9 and a bad tranny. I thought to swap in the 5 spd. & the manual PCM but may have to buy an '01-up PCM? shruggy
Hey Jackie, no, it's a blue one w/ a 5.9. There is a silver one up your way with a 4.7. up
Tim
'71 Charger 383/727
Re: '01- & back vs. '02-up Dakota/Durango wiring harness ?s [Re: I_bleed_MOPAR] #2728147
12/29/19 09:12 PM
12/29/19 09:12 PM
JDMopar Offline
JDMopar  Offline
Ok....I was afraid it may have been one of the ones I checked on. The red quad cab I mentioned has title problems....and I balked on it. Didn't want you to get in a mess either. up
Re: '01- & back vs. '02-up Dakota/Durango wiring harness ?s [Re: I_bleed_MOPAR] #2728198
12/30/19 03:15 AM
12/30/19 03:15 AM
Tim
I thought the Durango was the 01 by the thread title. The two are not compatible but you could possibly make it work if you can swap the cluster as well.
Re: '01- & back vs. '02-up Dakota/Durango wiring harness ?s [Re: Guitar Jones] #2728227
12/30/19 09:30 AM
12/30/19 09:30 AM
Buford, GA
Buford, GA
Sorry. Forgot I turned off my sig which would have shown the Durango. blush And it was an '01 Ram PCM. Just thought to take another look at the link you posted and Ram was still CCD in '01. wink
IIRC, I thought about swapping in the cluster and column from the '01 Dakota I bought for the 5 spd. swap but it was just different enough it wouldn't work. I'll keep looking for a '00 Dakota quad cab. I'm sure one will pop up sooner or later. up
Thanks for the heads-up, Jackie. Been looking for a quad cab for a while now. Not sure I told you about being sideswiped on both sides or if you noticed it when we met up in Commerce. Too expensive to fix, too good a drivetrain to waste, and really miss having a truck also. wink
Tim
'71 Charger 383/727
Re: '01- & back vs. '02-up Dakota/Durango wiring harness ?s [Re: I_bleed_MOPAR] #2728265
12/30/19 11:28 AM
12/30/19 11:28 AM
JDMopar Offline
JDMopar  Offline
Don't know how far gone this one is, as far as being parted out...or if it has a title. 2000 quad cab with a 5.9 though! smile
https://columbia.craigslist.org/pts/d/columbia-2000-dodge-dakota/7040653541.html
Re: '01- & back vs. '02-up Dakota/Durango wiring harness ?s [Re: JDMopar] #2728302
12/30/19 01:40 PM
12/30/19 01:40 PM
Buford, GA
Buford, GA
Close but really want a 4x4. wink
Tim
'71 Charger 383/727
Re: '01- & back vs. '02-up Dakota/Durango wiring harness ?s [Re: I_bleed_MOPAR] #2732093
01/11/20 11:11 AM
01/11/20 11:11 AM
Buford, GA
Buford, GA
Thanks for the link, Jackie. up I actually wound up buying a 2wd as it was too cheap to pass up. QC 5 spd. truck missing the engine. Base Sport model but after a little research the PW, mirrors, and seats will transfer over with a minimum of effort. up
Tim
'71 Charger 383/727
Re: '01- & back vs. '02-up Dakota/Durango wiring harness ?s [Re: I_bleed_MOPAR] #2732178
01/11/20 04:42 PM
01/11/20 04:42 PM
JDMopar Offline
JDMopar  Offline
up Awesome! Where'd you find it? Your motor mounts and everything should work, I think! Don't be stingy with the pics either....lol. scope
Re: '01- & back vs. '02-up Dakota/Durango wiring harness ?s [Re: JDMopar] #2732433
01/12/20 12:50 PM
01/12/20 12:50 PM
Buford, GA
Buford, GA
It was in Cartersville, GA (30 mi. one way). Had been on FB for a month or so. Drove out to look at it and SIL talked me into buying it. wink He wants to paint it for me. Mounts are there as is everything but the engine. Good thing about the mounts is it was a 3.9 and Durango is 4wd which uses a different mount. up
Tim
'71 Charger 383/727
