1970 Belvedere Tach Wiring #2727809
12/28/19 07:14 PM
12/28/19 07:14 PM
Costa Mesa, California
michaelphbarnett Offline OP
what is hooked up to the two terminals on the back of a 1970 Belvedere tachometer? I'm pretty sure the terminal on the right, when viewed from the back, is hooked up to the negative terminal of the ignition coil. I'm not sure about the terminal on the left.
Re: 1970 Belvedere Tach Wiring [Re: michaelphbarnett] #2727818
12/28/19 08:06 PM
12/28/19 08:06 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
I would assume it for a light...
Just my $0.02... wink
Re: 1970 Belvedere Tach Wiring [Re: michaelphbarnett] #2727819
12/28/19 08:14 PM
12/28/19 08:14 PM
N
NITROUSN Online content
NITROUSN  Online Content
N
I would have to look but I thought there were 3 terminals. Ground, keyed 12 volt and tach negative.
Re: 1970 Belvedere Tach Wiring [Re: NITROUSN] #2727825
12/28/19 08:23 PM
12/28/19 08:23 PM
I forgot to mention the ground terminal. thanks.
Re: 1970 Belvedere Tach Wiring [Re: michaelphbarnett] #2727903
12/29/19 07:36 AM
12/29/19 07:36 AM
It works! Here's a video of it working. I used my 1988 Dodge Ramcharger AW100 to test it. I was trying to get it off of the fast idle. Thanks NITROUSN.
