Page 9 of 10 1 2 7 8 9 10
Re: A few question about the E MW victor head [Re: mopar dave] #2727062
12/26/19 01:46 PM
12/26/19 01:46 PM
I saw a 30 HP increase going from a single Holley 1050 CFM Dominator carb. on a Indy 440-3 intake to two of the same list # Holley 1050 on a Indy M.W. tunnel ram intake with no other changes shruggy
I also tested two different sets of heads on the same short block using the same intake and carb, that was with a set of Indy SR M.W. heads and a set of ported 440-1 heads that flowed right at 30 CFM more on the 440-1 heads. My old pump gas 400 stroker motor made 727 HP with the SR heads and 775 HP with the 440-1 heads with the same compression ratio, both heads had 76.0 CC combustion chambers work
Their was a issue with the dyno headers on the 440-1 heads, the exhaust port on the 440-1 heads where slightly bigger on the exhaust port floor than the headers where(1/8 to 3/16 inch step into the headers tsk), which would make the motors start to have a slight random miss above 5200 RPM whiney shruggy
Re: A few question about the E MW victor head [Re: Cab_Burge] #2727181
12/26/19 07:36 PM
12/26/19 07:36 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I'm not sold on the roller making it faster justifying the cost. Just maybe a different solid when the time comes.
Re: A few question about the E MW victor head [Re: B1MAXX] #2727202
12/26/19 08:30 PM
12/26/19 08:30 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Let’s add some...... stirthepot
When I flowed one of those heads, it was with a 2.25 valve and a 4 angle seat.
It flowed 356.
With a 2.20 valve on a 3 angle seat....... would it still flow 356?
Maybe runaway
Re: A few question about the E MW victor head [Re: fast68plymouth] #2727206
12/26/19 08:42 PM
12/26/19 08:42 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Todd told me these heads had 2.25 valves. That must be where the confusion came in. They do have 2.20 valves.
Re: A few question about the E MW victor head [Re: mopar dave] #2727227
12/26/19 10:14 PM
12/26/19 10:14 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I'm still confused... ya' don't drop a 2.20 valve on a seat cut for a 2.25 without something looking "wrong".
Re: A few question about the E MW victor head [Re: BradH] #2727267
12/27/19 04:44 AM
12/27/19 04:44 AM
Mt Morris Michigan
Mt Morris Michigan
I'm as confused as you now. My heads have 2.200 valves.
Re: A few question about the E MW victor head [Re: mopar dave] #2727319
12/27/19 10:54 AM
12/27/19 10:54 AM
So. Burlington, Vt.
So. Burlington, Vt.
I don’t know how there’s any confusion.
As I’ve mentioned several times in this thread....... the heads were bought as the bare heads with blank seats.
I cut one intake and one exhaust seat so I could test them before and after they were cnc ported.
I cut the intake seat to 2.25”.
I remember doing it that way....... and my notes confirm that’s what I did.
I only cut ONE intake seat(#4 or #5 cylinder).
The remaining 7 were done at another shop.
What size valves they used to determine what size to cut the seat I have no idea.
Since they appear to be seating correctly from the pics of the valves, they appear to have been cut for the valves that are in the heads.
If one were to pull the #4 and #5 intake valves out........the remnants of my 4 angle valve seat might still be there.
Of course, since it appears there has been some amount of hand blending after the cnc job, that 4th(bottom) angle I used when I flowed the heads might have also been blended away.
The main point was...... when I flowed them, it had a 2.25 valve and a 4 angle seat.
It now has a 2.20 valve and a 3 angle seat.
I’m thinking those two changes would make some kind of difference in flow.
But...... maybe not.
Re: A few question about the E MW victor head [Re: fast68plymouth] #2727329
12/27/19 11:32 AM
12/27/19 11:32 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I have a tool for setting the seat, using the valve. I don't think that a 2.25 would even work on a seat for a 2.20, and if they were re-cut to 2.20 that would have sunk them noticeably.
I'm confused also. So one seat is cut for 2.25 and it has a 2.20 valve on it. Or one valve is 2.25?
I think that next time these get a freshen, I would determine the throat and decide at that point if the 2.20 is ok, or if it needs to go to 2.25 to get them proportionally right, and put a good valve job on them. I don't like that intake seat geometry at all. Just doesn't look touched at all.
Re: A few question about the E MW victor head [Re: B1MAXX] #2727345
12/27/19 11:55 AM
12/27/19 11:55 AM
Mt Morris Michigan
Mt Morris Michigan
I will make note of that. In the past with my small block builds I seen some fancy valve jobs and these look fairly basic to me as well, but the way I understand it, they don't have to be fancy to work well.
Re: A few question about the E MW victor head [Re: B1MAXX] #2727350
12/27/19 12:10 PM
12/27/19 12:10 PM
So. Burlington, Vt.
So. Burlington, Vt.
Quote
Once again....... these heads were bought as bare heads with blank uncut seats.
They are unusable as they come that way.
Someone has to cut the seats to be able to run the heads.
Re: A few question about the E MW victor head [Re: fast68plymouth] #2727351
12/27/19 12:13 PM
12/27/19 12:13 PM
BradH Offline
BradH  Offline
Only because I would have thought the seat cut by you for the 2.25 valve wouldn't have re-cut cleanly for the smaller 2.20 that the heads were finished with, unless that one seat is noticeably lower in the chamber than the others.
Re: A few question about the E MW victor head [Re: BradH] #2727354
12/27/19 12:20 PM
12/27/19 12:20 PM
So. Burlington, Vt.
So. Burlington, Vt.
Hit the 45 with a stone to widen it up a bit, hit the 30 to bring the outer edge in......probably only sink it .010-.015 or so.
Must be no one believes I know what I did with that head.
Re: A few question about the E MW victor head [Re: BradH] #2727356
12/27/19 12:22 PM
12/27/19 12:22 PM
Mt Morris Michigan
Mt Morris Michigan
i'm with Brad on this. That was my confusion as well.
Re: A few question about the E MW victor head [Re: mopar dave] #2727358
12/27/19 12:23 PM
12/27/19 12:23 PM
So. Burlington, Vt.
So. Burlington, Vt.
You guys win.
Forget I mentioned it.
Re: A few question about the E MW victor head [Re: fast68plymouth] #2727360
12/27/19 12:25 PM
12/27/19 12:25 PM
BradH Offline
BradH  Offline
I absolutely believe what you did to that head. What I found confusing is that the heads were finished w/ the smaller valves, despite what I would have thought was obvious that a larger valve had been cut for the one test port.
Re: A few question about the E MW victor head [Re: fast68plymouth] #2727361
12/27/19 12:26 PM
12/27/19 12:26 PM
BradH Offline
BradH  Offline
You guys win.
Too late... laugh2
Re: A few question about the E MW victor head [Re: fast68plymouth] #2727382
12/27/19 01:58 PM
12/27/19 01:58 PM
Mt Morris Michigan
Mt Morris Michigan
at this point, they work. They flow air and make power. They are getting bolted on this weekend, so really doesn't matter at this point. Next time they come off they get shaved again, VJ with possible larger valve and set up for a possible roller cam or springs for a new SFT cam. Its all good for now. Thanks guys for all the great info here.
Re: A few question about the E MW victor head [Re: mopar dave] #2727393
12/27/19 02:28 PM
12/27/19 02:28 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Bob at MCH, thought i'd gain no more than 20 hp from 2 points comp on my -1's.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: A few question about the E MW victor head [Re: deaks] #2727394
12/27/19 02:31 PM
12/27/19 02:31 PM
So. Burlington, Vt.
So. Burlington, Vt.
Did you try it?
What was the result?
Re: A few question about the E MW victor head [Re: fast68plymouth] #2727599
12/28/19 08:31 AM
12/28/19 08:31 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
If you mean me, no, not yet. I 've been working on other cars and the house, so the engine's on the stand still. The car 's looking a little shabby at the moment, so I'd like to spray it before I put the motor in. Besides milling the heads, i've also bought a 400 indy intake with the dom flange to keep things lower in the engine bay, so I can seal the hood.
Mick
best 60ft 1.36
