heater issue 65 Belvedere #2726759
12/25/19 10:17 AM
12/25/19 10:17 AM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
My blower was on a auxillary switch, I decided to investigate and unfortunately the only bit left was the back plate from the switch, is there anyway of repairing it to work just for heat, or do I need a new switch. ?
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: heater issue 65 Belvedere [Re: deaks] #2726767
12/25/19 10:56 AM
12/25/19 10:56 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I think the part you want is 2291095
A couple of links for you to see what it looks like.
https://bluestarperformance.com/par...r-blower-switch-2291095-1963-65-nos.html
https://www.ebay.com/itm/NOS-Mopar-...ow-Defogger-Switch-2291095-/333330986612
Not sure you can fix what you have. Also not sure if this is a switch with two speeds or a rheostat, probably a switch, the parts manual calls it a switch. So you probably have 12V in and then either no output (off), 12v out to the resistor pack on the heater box for low speed and 12v out to the motor for high. Two speed blower in this case, looking at the wiring diagrams, that is what it looks like.
You can get botht eh FSM and parts manual in electronic format here http://www.mymopar.com/index.php?pid=31
Re: heater issue 65 Belvedere [Re: Sniper] #2726778
12/25/19 11:33 AM
12/25/19 11:33 AM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
Sorry, i've not explained it very well, it's the heater vac switch for the push buttons, that's up the creek.
Mick
best 60ft 1.36
Re: heater issue 65 Belvedere [Re: deaks] #2726781
12/25/19 11:43 AM
12/25/19 11:43 AM
N.Y.
sixpacksteve Offline
N.Y.
Call Joe Suchy!
Hell Hath No Fury Like Mine
Re: heater issue 65 Belvedere [Re: deaks] #2726785
12/25/19 12:04 PM
12/25/19 12:04 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Depends, AC or no AC switch? 4 or 5 buttons essentially.
If it's a 5 button one I've successfully retrofitted a 3895790 vacuum switch into my 65 Cuda. The electrical hook ups are a tad different. I think this switch lets you turn the AC on/off in defrost by pulling the defrost button out, which I believe is the difference but it has been a very long time. My write up from last millennia on how I did that is here. http://www.oocities.org/steve.knickerbocker/cuda/cuda.htm
If it's a 4 button unit, those are hard to find. I know one place that rebuilds them, but you seem to not have anything to rebuild.
Re: heater issue 65 Belvedere [Re: Sniper] #2726823
12/25/19 01:57 PM
12/25/19 01:57 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
How do i get the switch out ?
best 60ft 1.36
Re: heater issue 65 Belvedere [Re: deaks] #2726824
12/25/19 02:03 PM
12/25/19 02:03 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
You can download the service manual at this link.
http://www.mymopar.com/index.php?pid=109
A snip from my copy, not super detailed though.
Re: heater issue 65 Belvedere [Re: deaks] #2727234
12/26/19 11:15 PM
12/26/19 11:15 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
Call Joe Suchy & he knows a guy in TX who restored my 64 Beldere switch and Joe gave me his contact info.
Joe only sells parts for early B bodies.
JOE SUCHY
MOPAR CARS AND PARTS
770-964-4441
8355 SPENCE ROAD
FAIRBURN, GA 30213
Re: heater issue 65 Belvedere [Re: Triggerfish] #2727326
12/27/19 11:18 AM
12/27/19 11:18 AM
Niles , Ohio
therocks Online content
therocks  Online Content
Niles , Ohio
The switch comes out pretty easy.Remove the plastic face plate after you remove the round warm piece.Small allen screw holds it on.Then the panel that houses the push buttons comes out.The cable for the heat control is also attached but usually has enough to get to the vacuum switch.It unscrews for the metal panel.The vacuum lines attach to it.Probally broken as most are.Rocky
Chrysler Firepower
Re: heater issue 65 Belvedere [Re: therocks] #2727328
12/27/19 11:31 AM
12/27/19 11:31 AM
Florida STAYcation
dOoC Online penguin-006
The village idiot's idiot
dOoC  Online Penguin-006
Florida STAYcation
THIS ole Geezer knows his $hit ! .... he’s been working on BRAND NEW 65s ... since he was FIFTY years old ! xmaseek
Re: heater issue 65 Belvedere [Re: therocks] #2727331
12/27/19 11:35 AM
12/27/19 11:35 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Having dealt with old vacuum switches there is no way I'd restore an old one if a new one was available. Once the nipples break off due to age it's just a matter of time. Especially since a new 5 button switch is $120.
Original Air will restore them, too.
If you want to try yourself, some info
https://www.forbbodiesonly.com/moparforum/threads/vacuum-switch-repair.164146/
there are some sort of very thin hardboard looking sliders inside that move around to open and block the various vacuum ports that tend to get old, dry and fall apart. So if yours are bad, well good luck trying to make new ones. Also, the electrical part of it, especially the blower circuit, tend to heat up and start warping/melting the plastic. I tried to DIY the one that was originally in my 65 Cuda, with mixed results, but ended up replacing it with the part number I mentioned above. If you can find one a Standard Motors HS101 is their version of that part.
Re: heater issue 65 Belvedere [Re: Sniper] #2727383
12/27/19 02:03 PM
12/27/19 02:03 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
Got the switch out but half of it was resting above the fuse box, some parts were missing, only two sliders, no wire terminals either.
best 60ft 1.36
Re: heater issue 65 Belvedere [Re: deaks] #2727391
12/27/19 02:24 PM
12/27/19 02:24 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Looks like the 4 button switch, which as far as I can find is not available new and pickings are real thin used/NOS which by thin means I can't find them either. I did read somewhere that someone modded a 5 switch unit to work but other than that I know nothing about the mod. Looks like you might need to contact a rebuilder, show them your pictures and see if they can help. Hopefully they have patterns to make new sliders and the bits and pieces needed to replace what's missing. Who knows, maybe they cannibalize a 5 button switch.
Re: heater issue 65 Belvedere [Re: Sniper] #2727623
12/28/19 10:46 AM
12/28/19 10:46 AM
Niles , Ohio
Niles , Ohio
Doc wrong again.Ive had my 65 since 69.Had it before I got the wife.Thats a long time.IIRC someone was repopping repos of the switch.Most the vacuum lines brek off.Mine broke years ago.But with M1 intake and Dominator carb I have no vacuum into the cabin.Rocky
Chrysler Firepower
