Re: Did i wreck this new fuel line? I am mad. [Re: sharpie] #272659
03/31/09 08:10 PM
03/31/09 08:10 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Well, I just installed he front to rear brake line and that was a piece of cake and took all of 10 minutes to remove the old one and install the new one. Wish the fuel was that easy.
I dont know fuel lines, what kind of compression fitting will work?
and is the tubbing bender I have decent or should get a new one and what type of flaring tool. I have several cars to do and one is a 38 Plymouth that will require special shaped fuel lines I would imagine and its a 5.7 hemi. so return lines too??
Dave'
Re: Did i wreck this new fuel line? I am mad. [Re: RUMBLON] #272660
03/31/09 08:14 PM
03/31/09 08:14 PM
Madera, CA.
MowP4rsn Offline
MowP4rsn  Offline
Madera, CA.
Dave, ignore my compression fitting comment...I confused the fuel line with brake line d'oh!
Re: Did i wreck this new fuel line? I am mad. [Re: RUMBLON] #272661
03/31/09 08:16 PM
03/31/09 08:16 PM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
Cutting and patching will work. That being said if it was my rig and another $75 wasn't going to break the bank I would get a replacement. It's two less places for a fuel leak to decide to start. If I patched it the only one who would know is me and that is all it would take.
Re: Did i wreck this new fuel line? I am mad. [Re: Classof70Chally] #272662
03/31/09 08:51 PM
03/31/09 08:51 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Yes I agree and now that I am having a martini and realized I at least learned something I am now happy. I would like to know what kind of tubbign benders everyone is using and what they look like and what kind of flaring tools to get for the enxt projects.
Re: Did i wreck this new brake line? I am mad. [Re: Classof70Chally] #272663
03/31/09 09:04 PM
03/31/09 09:04 PM
At a gas station near you
badblack68 Offline
badblack68  Offline
As a pipefitter for 20 plus years, I would say you toasted it. That line is NFG now.
Re: Did i wreck this new brake line? I am mad. [Re: badblack68] #272664
03/31/09 09:27 PM
03/31/09 09:27 PM
Sparks,Nv.
P
pete Offline
super street
pete  Offline
super street
P
Sparks,Nv.
OOPS! There's a few things you could do as mentioned, it's just a matter of what you'll settle for. Pete
Re: Did i wreck this new brake line? I am mad. [Re: pete] #272665
03/31/09 09:42 PM
03/31/09 09:42 PM
ERIE PA home of the RENCH MOB
mike_vango Offline
mike_vango  Offline
i just bent up some 3/8 line for my dart. took the old one out and used it for a template. no probs.
got a coil of fuel line for $25 and the bender for $30. got the bender at sears
http://www.sears.com/shc/s/p_10153_12605_00950509000P?keyword=bender
Re: Did i wreck this new brake line? I am mad. [Re: mike_vango] #272666
03/31/09 10:16 PM
03/31/09 10:16 PM
Clarksville, Tennessee
monoptn Offline
mopar addict
monoptn  Offline
mopar addict
I put a 3/8 stainless from Finelines in my demon. It took quite a bit of "rasslin" to get it in, and I had to massage it some too. I made it without any kinks though. If I had it to do over again, I think I might cut it near the middle, then splice it. I think I got lucky not kinking it.
Re: Did i wreck this new brake line? I am mad. [Re: monoptn] #272667
03/31/09 10:23 PM
03/31/09 10:23 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
my 3/8 stainless line went in my cuda remarkably easy. i thought it was going to be a pita but it wasnt. i cant believe i held off on doing it for 10 years thinking it was going to be hard
Re: Did i wreck this new brake line? I am mad. [Re: aarcuda] #272668
04/01/09 12:50 AM
04/01/09 12:50 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Nice job on that one!
Looks like you now have lots of spare tubing for any leaks.
Re: Did i wreck this new fuel line? I am mad. [Re: RUMBLON] #272669
04/01/09 01:03 AM
04/01/09 01:03 AM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
It's salvageable, if need be. You could cut the bend and install a new section using two unions such as the one pictured below. Would require a flare tool.
Re: Did i wreck this new fuel line? I am mad. [Re: sharpie] #272670
04/01/09 03:11 AM
04/01/09 03:11 AM
I just bent my fuel line yesterday (5/16"). To make a 90, I used a spool-type bender ($10 at the local NAPA) and bent it about 60*, then moved toward the apex of the bend a little, bent another 5* and did that a couple more times, working away from my original bend, till I finally got a 90* bend. Granted, the radius of that bend is larger, but it doesn't have any kinks.
I do what Brian does. It wont take a tight radius without kinking & I am definitely going to try(carefully) heating next time with a torch. I never thought about that with fuel lines.
Re: Did i wreck this new brake line? I am mad. [Re: mike_vango] #272671
04/01/09 09:48 AM
04/01/09 09:48 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
I bought one like the Imperial model on the same page. I haven't had a need for it yet.
I have a cheaper silver looking one for years that hurts my hand when I use it.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Did i wreck this new brake line? I am mad. [Re: Rug_Trucker] #272672
04/01/09 09:56 PM
04/01/09 09:56 PM
Connecticut
FurryStump Online content
FurryStump  Online Content
Connecticut
I went with mild steel. I have heard people have issues with leaks due to stainless being so much harder. It can leak at the flare. Another vote to get another one. I used Fineline.
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: Did i wreck this new fuel line? I am mad. [Re: RUMBLON] #272673
04/01/09 10:51 PM
04/01/09 10:51 PM
Harrisburg Pa. 17112
moparmikethree Offline
I did the same on my Challenger fuel line. Mine was aluminum . I have a kink like yours and have been running it for over 3 years, with no fuel problems.
I however would cut out the bad and add a union.
An old timers trick is to lay the tube against the round part of a ball pien hammer and bend arount it. Keeping it tight to the hammer. Will bend around and not kink.
Try it , it works!!
