Page 8 of 10 1 2 6 7 8 9 10
Re: A few question about the E MW victor head [Re: mopar dave] #2726366
12/23/19 12:14 PM
12/23/19 12:14 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
The throat looks undersized a good amount on the intake. The valve job looks very minimum, almost out of the box. shruggy
Re: A few question about the E MW victor head [Re: B1MAXX] #2726384
12/23/19 01:24 PM
12/23/19 01:24 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
That was my initial thought as well. My VJ's in the past were always 5 angle comp jobs. This is a 3 and nothing exotic, but most on here didn't see it as a big deal and no real magic in 5 angle jobs so I went along.
Re: A few question about the E MW victor head [Re: mopar dave] #2726424
12/23/19 05:37 PM
12/23/19 05:37 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Anyway of checking throat dia., or are they back together? Were these flowed? Pretty sure you said they were reassembled, and no flow #. Just making sure. There could be 10-30 cfm before the tipover point where the port takes over.
Re: A few question about the E MW victor head [Re: B1MAXX] #2726429
12/23/19 06:17 PM
12/23/19 06:17 PM
Mt Morris Michigan
Mt Morris Michigan
Back together now. Flow numbers I got were 350@.600 and 356@.700 intake. Exhaust was 250@.600 and 254@.700
Re: A few question about the E MW victor head [Re: mopar dave] #2726593
12/24/19 12:35 PM
12/24/19 12:35 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Have you jumped in head first into the tunnel ram, or is that still just something you're considering?
And when are you expecting to have it running again?
Re: A few question about the E MW victor head [Re: mopar dave] #2726623
12/24/19 01:39 PM
12/24/19 01:39 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Right but they could be way off under .500 lift. Something for future consideration.
I did a set of SR's that I couldn't get past 325 up top (with my novice short turn hack job)
They went
311 - .500
278 - .400
227 -.300
162 - 200
88 - .100
but with a .650 flat tappet went 9.70 best. Normally 9.80's/90's in a 511ci.
Re: A few question about the E MW victor head [Re: B1MAXX] #2726627
12/24/19 02:31 PM
12/24/19 02:31 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
My main argument in the “pros” column of the discussion about the current valve job was...... they had already run solidly into the 9’s as they are.
After seeing them all cleaned up, my argument in the “cons” column is........ there is likely some flow left on the table as they are.
Hard to say for sure how much, or if it would even show up on a time slip.
But I’m sure the flow bench numbers could be improved some.
Re: A few question about the E MW victor head [Re: BradH] #2726628
12/24/19 02:36 PM
12/24/19 02:36 PM
Mt Morris Michigan
Mt Morris Michigan
Its getting T ram next off season, so the Indy 400-3 goes back on with the Thumper 1100 Dominator. It will have a boost in compression to 12.44 or 12.6:1 depending on the gasket thickness of .040 or .045, not sure I want to roll the dice on the .038" quench yet. Looks like it will have an electric water pump as well now since I cant get the new electric fan kit to fit with the belt off the water pump in the way. So it will be going out next time with more compression, electric fans/water pump and open exhaust. Not a good A/B I know, but i'm looking for a number closer to 10'o. Gonna get the carbs in January and the T ram right after. Not sure what I want to do right now as I have enough to get the Holley 750 xp's and the T ram or do I blow all of it on Thumper carbs. Good quality parts are expensive. Decisions Decisions.
Re: A few question about the E MW victor head [Re: B1MAXX] #2726631
12/24/19 02:43 PM
12/24/19 02:43 PM
Mt Morris Michigan
Mt Morris Michigan
Here's what I have from Todd at CWE.
.100-75.1 97.1
.200-164.7 114
.300-222 163.7
.400-278.6 203.8
.500-324.2 232.3
.600-347.8 249.6
.700-356 254.2
Re: A few question about the E MW victor head [Re: fast68plymouth] #2726761
12/25/19 10:25 AM
12/25/19 10:25 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
my fault, I don't know why I thought these hadn't gone 9's yet. I misunderstood the post. up I agree probably not much left then in the heads.
Re: A few question about the E MW victor head [Re: mopar dave] #2726788
12/25/19 12:06 PM
12/25/19 12:06 PM
BradH Offline
BradH  Offline
.100-75.1 97.1
.200-164.7 114
.300-222 163.7
.400-278.6 203.8
.500-324.2 232.3
.600-347.8 249.6
.700-356 254.2
So, you did or did not have the heads re-tested after getting them back this time? confused
Re: A few question about the E MW victor head [Re: BradH] #2726816
12/25/19 01:33 PM
12/25/19 01:33 PM
Mt Morris Michigan
Mt Morris Michigan
These are the original numbers I got from Todd.
Re: A few question about the E MW victor head [Re: B1MAXX] #2726817
12/25/19 01:36 PM
12/25/19 01:36 PM
Mt Morris Michigan
Mt Morris Michigan
These went 9's on another gentlemans 511 just under 13:1 compression.
Re: A few question about the E MW victor head [Re: mopar dave] #2726850
12/25/19 04:54 PM
12/25/19 04:54 PM
BradH Offline
BradH  Offline
Did you ever get the cam specs for the engine your heads were on previously?
Re: A few question about the E MW victor head [Re: mopar dave] #2726856
12/25/19 05:07 PM
12/25/19 05:07 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
You should have plenty of port speed with your engine that big and .650ish cam
Re: A few question about the E MW victor head [Re: mopar dave] #2726857
12/25/19 05:14 PM
12/25/19 05:14 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
What were the combo differences?
Re: A few question about the E MW victor head [Re: BradH] #2726917
12/25/19 09:27 PM
12/25/19 09:27 PM
Mt Morris Michigan
Mt Morris Michigan
No, Todd never got back with me on that.
Re: A few question about the E MW victor head [Re: B1MAXX] #2726918
12/25/19 09:30 PM
12/25/19 09:30 PM
Mt Morris Michigan
Mt Morris Michigan
Best I could tell he had 12.8:1 compression and a small roller .620. I had 11.26:1 and a solid flat tappet 270@50 with .625 lift.
Re: A few question about the E MW victor head [Re: mopar dave] #2727024
12/26/19 11:15 AM
12/26/19 11:15 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
With your change to the compression I would guess 30-40 hp.
Re: A few question about the E MW victor head [Re: B1MAXX] #2727036
12/26/19 12:08 PM
12/26/19 12:08 PM
Mt Morris Michigan
Mt Morris Michigan
I hope so. With run the same single 1100 Dominator this year. A tunnel ram with twin 750's next and possibly a solid roller after that.
