Page 7 of 10 1 2 5 6 7 8 9 10
Re: A few question about the E MW victor head [Re: CSK] #2725909
12/21/19 05:43 PM
12/21/19 05:43 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I did a fair amount of back cut testing on Brads heads.
They didn’t respond well to a long back cut.
Here is a close look at some of the ones I did for Brad way back when.
4 angles, longer top angle, bottom angle blended into bowl, no pronounced edge where the valve job ends and the bowl starts:
Re: A few question about the E MW victor head [Re: fast68plymouth] #2725910
12/21/19 05:52 PM
12/21/19 05:52 PM
So. Burlington, Vt.
So. Burlington, Vt.
It looks to me as though the CNC lines had been polished out of Dave’s heads before they were put into service.
I’ve never seen where bead blasting the heads would make the lines disappear...... so I have to assume they just weren’t there.
Re: A few question about the E MW victor head [Re: fast68plymouth] #2725913
12/21/19 06:00 PM
12/21/19 06:00 PM
So. Burlington, Vt.
So. Burlington, Vt.
The bottom angle thing is probably just how it looks in the other pics I posted.
In this pic the bottom angle does seem like it’s about 60*
A lot of this stuff is hard to really assess without having it in your hands.
BTW, what did the chamber volume end up at after the milling?
Re: A few question about the E MW victor head [Re: fast68plymouth] #2725922
12/21/19 06:19 PM
12/21/19 06:19 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Thanks for looking and assessing. The valve job stays as is and heads are going back on soon. Steve took off .045 from deck and .054 from intake side giving me 67cc in the chamber. If I use a .040 gasket that would give me 12.6:1 and with a .045 gasket would give 12.44:1 compression.
Re: A few question about the E MW victor head [Re: mopar dave] #2725925
12/21/19 06:26 PM
12/21/19 06:26 PM
So. Burlington, Vt.
So. Burlington, Vt.
I didn’t think you’d be changing that valve job......i’m just passing on some observations.
Is the short block zero deck?
Re: A few question about the E MW victor head [Re: fast68plymouth] #2725929
12/21/19 06:39 PM
12/21/19 06:39 PM
Mt Morris Michigan
Mt Morris Michigan
no, its .002 positive. If I keep the heads they will get a JV next time.
Re: A few question about the E MW victor head [Re: mopar dave] #2725931
12/21/19 06:51 PM
12/21/19 06:51 PM
So. Burlington, Vt.
So. Burlington, Vt.
There is likely “some” flow to be had by cutting the seats and some blending....... but whether or not that would show up on a time slip is another story.
Re: A few question about the E MW victor head [Re: fast68plymouth] #2725941
12/21/19 07:24 PM
12/21/19 07:24 PM
Mt Morris Michigan
Mt Morris Michigan
Maybe I should have a couple ports flowed before I reinstall the heads.
Re: A few question about the E MW victor head [Re: mopar dave] #2725947
12/21/19 07:32 PM
12/21/19 07:32 PM
So. Burlington, Vt.
So. Burlington, Vt.
Well...... “flowing” the heads doesn’t actually make them any better....... but at least you’d know what you have.
I looked at my notes again....... when I did my test, it was a 4 angle seat and 2.25 intake valve.
So...... there could still be a 4 angle seat in one hole, but that’s not going to be representative of what the others flow with 3 angles and a smaller valve.
My notes show I tested the number 4 or 5 cylinder.
So if you pull those two intake valves, one of those seats might still have the 4 angles...... although if they recut it, the 4th angle could be mostly gone.
Re: A few question about the E MW victor head [Re: fast68plymouth] #2725960
12/21/19 07:50 PM
12/21/19 07:50 PM
Mt Morris Michigan
Mt Morris Michigan
It would be good to just know what I have. I may check that tomorrow.
Re: A few question about the E MW victor head [Re: mopar dave] #2725963
12/21/19 08:03 PM
12/21/19 08:03 PM
So. Burlington, Vt.
So. Burlington, Vt.
If you find one seat still has the 4 angles..... what i’m saying is...... flow a different one.
Re: A few question about the E MW victor head [Re: fast68plymouth] #2725964
12/21/19 08:08 PM
12/21/19 08:08 PM
Mt Morris Michigan
Mt Morris Michigan
ok, I understand. I will have the one flowed that I just pulled the valves from.
Re: A few question about the E MW victor head [Re: mopar dave] #2725973
12/21/19 08:41 PM
12/21/19 08:41 PM
So. Burlington, Vt.
So. Burlington, Vt.
Re: A few question about the E MW victor head [Re: fast68plymouth] #2725993
12/21/19 10:38 PM
12/21/19 10:38 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Dave - Can you get any clear close-up pics of the intake valve seat?
FWIW, here's my original Hughes CNC Victor and a Chapman Stage VI. Both pics should be clear enough to zoom in to see more details of their respective valve seat configs.
EDIT: Stupid questions - what size are the intake valves... and are they all same size?
Re: A few question about the E MW victor head [Re: BradH] #2726062
12/22/19 11:58 AM
12/22/19 11:58 AM
Mt Morris Michigan
Mt Morris Michigan
I put the valves back in Brad. I see what pics I have to post.
Re: A few question about the E MW victor head [Re: mopar dave] #2726066
12/22/19 12:04 PM
12/22/19 12:04 PM
Mt Morris Michigan
Mt Morris Michigan
A few more.
Re: A few question about the E MW victor head [Re: mopar dave] #2726067
12/22/19 12:04 PM
12/22/19 12:04 PM
So. Burlington, Vt.
So. Burlington, Vt.
CNC ported ProComp Victor I prepped last year:
Re: A few question about the E MW victor head [Re: mopar dave] #2726069
12/22/19 12:13 PM
12/22/19 12:13 PM
Shelby Twp. Mi
HardcoreB Online content
HardcoreB  Online Content
Shelby Twp. Mi
If you're brave enough... it wouldn't hurt to run a cutter finish around the bottom to blend the sharp edge.
Re: A few question about the E MW victor head [Re: HardcoreB] #2726075
12/22/19 12:26 PM
12/22/19 12:26 PM
So. Burlington, Vt.
So. Burlington, Vt.
Re: A few question about the E MW victor head [Re: HardcoreB] #2726076
12/22/19 12:27 PM
12/22/19 12:27 PM
Mt Morris Michigan
Mt Morris Michigan
I think ill leave as is for now.
