Dan 60 gears #272540
03/31/09 03:42 PM
03/31/09 03:42 PM
Fl. USA
PS Arrow Offline OP
PS Arrow  Offline OP
Fl. USA
The Arrow has a Dana with 4.56 gears, which would normally be fine for the track, but not much good foe street cruising. I'd like to put 4.10 in it, it has a spool, will need spacers or any extra pieces? I have no clue when it comes to a Dana all help would be appreciated.
John
Re: Dan 60 gears [Re: PS Arrow] #272541
03/31/09 04:28 PM
03/31/09 04:28 PM
Cumberland, MD
Supersonic Offline
Supersonic  Offline
Cumberland, MD
You are going to need a different spool for that. 4.56 and up use a different spool than 4.30 and down.
Re: Dan 60 gears [Re: Supersonic] #272542
03/31/09 04:31 PM
03/31/09 04:31 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
The only exceptions are:
All pro gears, regardless of ratio and Richmond 4.10 street gears take the 4.56 type (5 series) spool.
Re: Dan 60 gears [Re: DoctorDiff] #272543
03/31/09 04:53 PM
03/31/09 04:53 PM
Fl. USA
PS Arrow Offline OP
PS Arrow  Offline OP
Fl. USA
So I should have a 5 series spool since it had 4.56, but to go to a 4.10 I would have to use a pro gear or a Richmond..basically it should be a direct swap?
Re: Dan 60 gears [Re: PS Arrow] #272544
03/31/09 07:50 PM
03/31/09 07:50 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Yes, you can re-use your original 5-series spool if you install Richmond 4.10 street gears or any pro gear.
Re: Dan 60 gears [Re: DoctorDiff] #272545
03/31/09 09:24 PM
03/31/09 09:24 PM
Fl. USA
PS Arrow Offline OP
PS Arrow  Offline OP
Fl. USA
Thank You Doc!!!
