Re: Drag Radial vrs Drag Slick [Re: tex013] #2725336
12/19/19 10:12 AM
12/19/19 10:12 AM
Right here
HP2 Offline
HP2  Offline
Right here
Will a 28x9R15 fit on a Duster?
70 W100 Power Wagon. 318 4-spd
70 Sport Fury 440 2dr HT
71 Duster 340
71 Charger Super Bee - 383/727
72 Charger "Sabotage" - 440/727 - Street/Strip
78 Warlock in beautiful patina
Re: Drag Radial vrs Drag Slick [Re: HP2] #2725349
12/19/19 11:05 AM
12/19/19 11:05 AM
What year Duster?
I had to trim my rear 1/4 panels on my 1971 Duster (removed) 3.0 inches on the front side and 2.0 inches on the rear to make 315x60x15 on ten inch wide rims fit it work
I had a younger guy come up to that car at the Mopar race at Woodburn dragstrip back in 2008 or so and look at the car real closely and make the comment you can't make that size tire fit on this car, he said he had one and he could only make a 275x60x15 inch tire fit on it confused
I told him to step back and look real hard at my car and tell me what he saw, I then told him when he didn't see what was done to it to make them fit that I had stretch the rear wheel wells five inches and moved the rear end forward one inch to make it look stock devil
My message is you can make a larger tire fit if you want to do the work work
Re: Drag Radial vrs Drag Slick [Re: HP2] #2725352
12/19/19 11:25 AM
12/19/19 11:25 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
IIRC years ago I ran a 275 (28" tall) on my 72 Duster with no modifications.
Re: Drag Radial vrs Drag Slick [Re: Cab_Burge] #2725403
12/19/19 04:22 PM
12/19/19 04:22 PM
Right here
HP2 Offline
HP2  Offline
Right here
Originally Posted by Cab_Burge
What year Duster?
I also have a 71.
Found this on tiresize.com: 315/60R15 tires have a diameter of 29.9", a section width of 12.4"
Do you have any pics on your Duster?
71 Duster 340
Re: Drag Radial vrs Drag Slick [Re: HP2] #2725471
12/19/19 09:17 PM
12/19/19 09:17 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
If it’ll fit on a 67 B-Body, it’ll fit on anything......
Re: Drag Radial vrs Drag Slick [Re: StealthWedge67] #2725532
12/20/19 02:44 AM
12/20/19 02:44 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I run the Hoosier 30 x 9 radial slick and I really like them. As long as I stage in the grove (tire tracks) it hooks good. Its just a street car that has run 10.70's and I drive on the street all the time with the slicks .I only run SS springs with no adjustable shocks other then 90/10 shocks up front and I run from 16 to 18 psi. Ron
Re: Drag Radial vrs Drag Slick [Re: 383man] #2725580
12/20/19 10:43 AM
12/20/19 10:43 AM
Central Mississippi
mopar97 Offline OP
mopar97  Offline OP
Central Mississippi
Thanks!
Mopar born, Mopar breed, when I die, call me Mopar dead!
Re: Drag Radial vrs Drag Slick [Re: mopar97] #2725659
12/20/19 03:50 PM
12/20/19 03:50 PM
canada
W2-408 Offline
W2-408  Offline
canada
After buying my first set of 29.5X10.5 Pro Bracket Radials I will never use another tire again! Over 3 years on one set I put on about 500 passes, the 60 foot never varies more than about 8 thou throughout the day, I run them at 19 psi and don't do a burnout either. Stab the throttle out of the water and that's all. The car runs 10.20's and 60 foot times are 1.39-1.41 depending on the day. I will put new ones on for next season but I'm sure I could probably sneak a 4th year out of them, last pass of this fall was identical in all incrementals to the first pass I made in the spring. They would still be perfect for the average 11 second car. You'll never go wrong with that tire!!
Street car, 10.12 @ 132 with W2's and pump gas
Re: Drag Radial vrs Drag Slick [Re: W2-408] #2725693
12/20/19 06:12 PM
12/20/19 06:12 PM
Central Mississippi
mopar97 Offline OP
mopar97  Offline OP
Central Mississippi
Thank you W2-408
Re: Drag Radial vrs Drag Slick [Re: mopar97] #2725707
12/20/19 07:11 PM
12/20/19 07:11 PM
Windsor ,Ca.
K
Keith Richards Offline
K
Windsor ,Ca.
Here is my direct experience after running M/T 29.5 x 10.5 -15' for 10 plus years as that is what was on the car when bought back in '99 so I always stayed with that tire, in 2009 on a Wednesday night track I went out with the usual M/T drag bias tires on the car and ran a usual 10.73 @ 126. Then went back to the trailer and bolted on a set of Hoosier 30 x 9 -15's C06 radials set the air at 18psi (no tube) that a friend had taken off a car he just bought and didn't want and ran 10.51 @ 129 45 minutes later. Car is a '68 road runner with cal traks, stock leafs and a 4.10 gear. In 2013 I sold the car and just bought it back 2 months ago, Car now has split mono leafs, double adjustable shocks on back and single adjustable shocks on the front so looking forward to getting it out again soon as that has helped get it in the teens I am told.
Re: Drag Radial vrs Drag Slick [Re: Keith Richards] #2725745
12/20/19 11:05 PM
12/20/19 11:05 PM
A727Tflite Offline
A727Tflite  Offline
Keith, what did your engine speed do when you went from bias to radial.
Trap rpm.
Re: Drag Radial vrs Drag Slick [Re: A727Tflite] #2726279
12/22/19 11:18 PM
12/22/19 11:18 PM
Windsor ,Ca.
K
K
Windsor ,Ca.
Trap rpm.
From what I remember it dropped slightly about 100 as the radials are just a tad taller, I shifted at 6500 and I think was 6400 in the lights.
