Re: Bill Mitchell Products. More Mopar blocks
[Re: jim sciortino]
#2725033
12/18/19 06:54 AM
12/18/19 06:54 AM
Posts: 4,072 Mo.
racerx
Mo.
Pontiac has more than 1 option for blocks at a decent price in both aluminum and iron, while even !!!OLDSMOBILE!!! has an iron block available that according to one of Old's top builders I spoke with is.................."bad ass".
That you can't pick up the phone and order (then get) a quality small/big/HEMI MOPAR water block, is not only pathetic, it's enough to get a lifetime MOPAR guy (myself, for example) to build a Dart Big M Pro block with MBE Big 9 heads..........or something similar, on a future build.
A sad state of affairs that has gone on for too long. Like I heard a lifelong Mopar guy explain when asked why his dragster has a big Big Block GM in it. "I can spend 25k and go 4.40s and not wait on it or I can spend 35k, wait, and go 4.90s." IF I switch, I'll switch all of it. I won't put a GM engine in a Chrysler product that I own. I sold one of my 2 cars and when the other goes, I'm relocating across countr. When I get settled in, my next car will be a 67' Chevy II with a Whipple screw GM style big block. It's painful, but I don't wanna' be in position where the foundation for a good powerpant is unobtainium. What....send a rod in an iron block and you're out of business for who knows how long??? Forget about it. I would NEVER stick a non-MOPAR engine in a MOPAR car, so it's gotta' be the whole package and at least the Chevy II looks good and you can get a complete 65# carbon body for under 10K. If it was just a racecar, there are plenty of good HEMI options to choose from and that would be the way I'd go, but I like to drive stupid stuff around town. I tell you …….I like your way of thinking
[Re: racerx]
#2725106
12/18/19 12:37 PM
12/18/19 12:37 PM
Posts: 19,377 Las Vegas
Al_Alguire
Las Vegas
If I could sell all my stuff, which unless I wanna give it away does not seem likely, not much market for higher HP Mopar stuff I could not GIVE AWAY an 1100HP engine for $17K, now its fresh and ready for the dyno Id be willing to bet I couldn't sell it for that same $17K now either. If I could get out and not loose my a$$ I would be in a 66/67 Chevy II so fast it would make your head spin. I talked to RJ about building a new Chevy II when I was looking at my Stratus, in hindsight I should have just done it then. I already have a 68 Camaro with an aftermarket block in it. Its just to easy and way more options to make power.
[Re: Al_Alguire]
#2725127
12/18/19 01:54 PM
12/18/19 01:54 PM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
Al, it's sad, but I agree w/ you about your engine. The market for that type of stuff is soooo small. I love the '66-'67 novas, but I'd be all over a '70 Chevelle. Always liked the bigger cars.
[Re: an8sec70cuda]
#2725136
12/18/19 02:17 PM
12/18/19 02:17 PM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I drive and own a 6 cylinder fuel injected 2003 Chevy Malibu that my mother bought new. Does that count because that’s as close to being a Chevy guy that I care to get. I do wish a few guys would jump into the Chevy crowd as I get tired of the constant whining.
[Re: n20mstr]
#2725142
12/18/19 03:00 PM
12/18/19 03:00 PM
Al_Alguire
Las Vegas
WOW....ONE BY ONE, ALL MY HIGH HP MOPAR "HEROS" ARE GIVING UP
LMAO ! !
KEEP PLUGGING AWAY AT IT AND...…
Well I for one am pretty tapped out NA wise. We know there is a few more HP in it and will likely address it at freshen up with some new pistons, more compression and a different cam,. But its basically tapped out, at least as a reliable piece. I have all the confidence in the world it will go 200 laps between freshen ups but cannot afford to have anything happen to the block so its on a 100 lap schedule, same with the other engine and its pretty mundane really. On the bright side it appears there will be a block available again for those few that venture here with a BB. Once the Wheatcrafts get Indy back to speed. Mitchell has no interest or plans to build anything other than "stock" configuration stuff. No raised cam, no bog cam core, no revised lifter angle or spacing. And I cannot blame him one bit. I mean how many people out there would even be interested in one, more will be willing to get on forums and MF the product they have no experience with than actually will buy one. As for the other player, so far empty words and a lot of other people money, Hopefully they can get things headed in the correct direction but at this point its not happened. Can you hear the frustration yet?
[Re: Al_Alguire]
#2725153
12/18/19 03:23 PM
12/18/19 03:23 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I don’t understand why manufacturers don’t sell line delete castings. Lets say I want blank cam bore and blank lifter valley, or raw deck heights with no head bolt holes etc... less work for them and more desirable for custom builders.
[Re: TRENDZ]
#2725176
12/18/19 06:03 PM
12/18/19 06:03 PM
Posts: 2,028 Trumbull,CT.
jim sciortino
Trumbull,CT.
I never had an Indy block, but from what everyone says, it has a number of issues and even when fixed up, is not in KB's league. I wonder if the Wheatcraft crew will address this problem???
If they can get water blocks in the pipeline and get them to be reliable around the 1500 to 2000hp range, that would definitely be an alternative. Companies like CN already support above that power level with a variety of HEMI blocks, so the really high end market is covered. I know it's alot to ask since it would require design changes, but that would fill the hole between the existing Indy offering and a really good block that has no water.
As for an iron deal, I can't believe there isn't a market for something that can take a beating well above an aluminum capped and filled stock piece. I split one of them in the early 90s with Indy 440-1 heads and a moderate shot of nitrous. Granted, 1000+ is asking plenty from 50+ year old assembly line castings. Hell even Pontiac and Oldsmoblie have options and I know for a fact the Pontiac alternative is stout, as a couple friends have small tire 1/8 mile cars over 3000# that run pretty hard, including one that's been 4.90s with a plate system without block issues. Plus, they get em' in short order and for a decent price.
[Re: jim sciortino]
#2725210
12/18/19 09:01 PM
12/18/19 09:01 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
A sad state of affairs that has gone on for too long. They even make aftermarket 409 blocks. An engine that was available for just 5 years.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: Spaceman Spiff]
#2725247
12/18/19 11:15 PM
12/18/19 11:15 PM
jim sciortino
Trumbull,CT.
A sad state of affairs that has gone on for too long. They even make aftermarket 409 blocks. An engine that was available for just 5 years. Very true.....so how can the market support the existence of these pieces while the Dodge/Plymoth crowd has continuous supply and quality problems??? It would appear that every time blocks actually do hit the streets, they certainly don't sit on manufacturers shelves, unable to be unloaded.
[Re: jim sciortino]
#2725251
12/18/19 11:20 PM
12/18/19 11:20 PM
Posts: 20,192 Park Forest, IL
slantzilla
Park Forest, IL
My buddy at The Chicago Connection told me he could get rid of 100 blocks almost instantly if he could just get them.......
[Re: slantzilla]
#2725254
12/18/19 11:38 PM
12/18/19 11:38 PM
Posts: 1,103 Massillon, Ohio
cudatom
Massillon, Ohio
That doesn't surprise me.
If I wouldn't lose my azz I would just switch over to the Gen III stuff. Unfortunately I have everything I need except for pistons for a BB. I'm giving KB until the end of January and if nothing I'll pull the trigger on a BM block. Not going to waste good rods, crank, cam and heads on a stock block. If the mains let go its all gone. Not saying that can't happen with a good aftermarket block but chances are less.
Ok
[Re: slantzilla]
#2725266
12/19/19 12:23 AM
12/19/19 12:23 AM
Posts: 131 Conroe , Texas
iapco103
Conroe , Texas
My buddy at The Chicago Connection told me he could get rid of 100 blocks almost instantly if he could just get them....... Has he gotten any blocks? Paul
[Re: iapco103]
#2725290
12/19/19 02:49 AM
12/19/19 02:49 AM
slantzilla
Park Forest, IL
My buddy at The Chicago Connection told me he could get rid of 100 blocks almost instantly if he could just get them....... Has he gotten any blocks? Paul Last time I talked to him a couple months ago he had not seen any. He was pretty concerned when I told him people on here were getting blocks directly from Bulldog.
[Re: slantzilla]
#2725354
12/19/19 11:42 AM
12/19/19 11:42 AM
Posts: 43,240 Bend,OR USA
Cab_Burge
My buddy at The Chicago Connection told me he could get rid of 100 blocks almost instantly if he could just get them....... Has he gotten any blocks? Paul Last time I talked to him a couple months ago he had not seen any. He was pretty concerned when I told him people on here were getting blocks directly from Bulldog. I thought Bulldog went out of business Do you have any contact info for them now?
[Re: Cab_Burge]
#2725397
12/19/19 03:15 PM
12/19/19 03:15 PM
slantzilla
Park Forest, IL
My buddy at The Chicago Connection told me he could get rid of 100 blocks almost instantly if he could just get them....... Has he gotten any blocks? Paul Last time I talked to him a couple months ago he had not seen any. He was pretty concerned when I told him people on here were getting blocks directly from Bulldog. I thought Bulldog went out of business Do you have any contact info for them now? Bulldog is the one who is probably being sued.
[Re: Al_Alguire]
#2725400
12/19/19 04:10 PM
12/19/19 04:10 PM
Posts: 422 montana
BANDIT
montana
I have R-M built 583” BBC in one car and a 588” R-B built Mopar motor in other. One makes 150 hp more than the other and was $8000.00 cheaper. The Mopar is a wedge head, both are aluminum blocks, the Mopar is an Indy block. Bet you can’t guess which one is which. Jim.
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.35@165. 4400 DA 250” Neil and Parks Slip Joint. 7.36@183. 4600 DA 242" Mullis Dragster. 6.90@ 200mph
[Re: BANDIT]
#2725424
12/19/19 05:46 PM
12/19/19 05:46 PM
jim sciortino
Trumbull,CT.
I have R-M built 583” BBC in one car and a 588” R-B built Mopar motor in other. One makes 150 hp more than the other and was $8000.00 cheaper. The Mopar is a wedge head, both are aluminum blocks, the Mopar is an Indy block. Bet you can’t guess which one is which. Jim. Because not only do we have a block porcurement problem, unless you opt for the best of the best HEMI heads for a boosted application, they are playing with spaceships and we're stuck with chariots in the cylinder head department. The cost difference is understandable and makes sense economically for a variety of reasons, so that part of the equation doesn't bother me nearly as much as R&D/availablity nightmare.
