Re: 426 Hemi rebuild...
[Re: jlatessa]
#2925287
05/21/21 05:52 PM
05/21/21 05:52 PM
Posts: 712 Lake Villa Il
INTMD8
Lake Villa Il
Is that a red Ferrari in the backround?
Jeez, a hemi AND a Ferrari, I feel so inadequate...LOL
Good for you!
Joe Latessa, yes, I'm Italian Haha, yes it's an old F355. Thank you.
[Re: moparx]
#2926068
05/24/21 09:04 AM
05/24/21 09:04 AM
INTMD8
Lake Villa Il
were any mods needed for the coil to the spark plug length ? I trimmed .125 off of the end of the coil. Also shortened the top of the plug tubes by .200. The threaded spacers to mount the coils are .400 thick.
[Re: INTMD8]
#2926093
05/24/21 10:52 AM
05/24/21 10:52 AM
Posts: 447 Knoxville, TN
YGBSM
Knoxville, TN
Very cool!
With the coil on plug setup do you use a distributor? I can't see what's under the distributor hold-down.
1968 Charger R/T 2015 Charger R/T Scat Pack 2017 Durango Citadel
[Re: INTMD8]
#2929705
06/03/21 09:32 AM
06/03/21 09:32 AM
Posts: 2,631 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
That EFI/COP setup is so beautiful this thread should be put in the tech archives for later reference.
2011 Drag Pak Challenger
[Re: rickseeman]
#2929748
06/03/21 12:02 PM
06/03/21 12:02 PM
Posts: 17,840 S.E. Michigan
ZIPPY
S.E. Michigan
Hasn't been much interest in maintaining the tech archives....And once it is archived, nobody can reply to it. I would suggest, at whatever point it's comfortable to move, that it should be moved to the Member's project area instead. It's over hereSupposedly pictures will be saved as long as the servers keep running, and the thread can be replied to continuously.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2929917
06/03/21 09:57 PM
06/03/21 09:57 PM
Posts: 620 Deep DEEP SOUTH
LAD 524
Deep DEEP SOUTH
Great thread ! As an aside, I believe the OEM AUDI/VW coil packs are a direct fit and don't require trimming like the Coyote coils do. It would perhaps depend on whether you are using Indy or Stage V heads as I believe the Indy plug tubes are taller. I will be going down the EFI path at a later time on my 572 and am collecting parts atm.
[Re: cudaman1969]
#2942306
07/12/21 11:57 AM
07/12/21 11:57 AM
INTMD8
Lake Villa Il
It is a Keisler bellhousing. Clutch is a Mcleod 6911-07 which is dual organic discs of 9.688 diameter.
[Re: CSK]
#2966205
09/21/21 11:29 PM
09/21/21 11:29 PM
INTMD8
Lake Villa Il
Thank you, much appreciated
[Re: INTMD8]
#2966247
09/22/21 09:05 AM
09/22/21 09:05 AM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
Thank you, much appreciated Your efi wiring looks better than mine, it was hard to find a good routing, I have so many relays ,diodes ad ons under the hood, it looks like a wiring factory exploded LOL
