2012 hemi in 2013 ram help #2724531
12/16/19 03:50 PM
12/16/19 03:50 PM
DE
Hartlycooter Offline OP
DE
So i found a 2012 ram 5.7 hemi motor pretty cheap that was pulled with 109k from a running truck for 400 bucks. I have a 2013 ram and would like to keep this motor as a spare or for a build to swap in the truck later. I am getting conflicting info as to weather or not it will work in my 2013 as is. Hhp is 20 minutes away from my house and they tell me it wont work. The reluctor wheels are different. Modern muscle says it will bolt right in and be fine because even though the reluctors are different they are still 58 tooth. A dodge tech also told me it is a direct swap. Anyone know for sure whether or not this motor is a direct bolt in swap for my 2013?
Re: 2012 hemi in 2013 ram help [Re: Hartlycooter] #2724598
12/16/19 07:32 PM
12/16/19 07:32 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I did a 10 into a 13 and it was just fine.
Re: 2012 hemi in 2013 ram help [Re: HotRodDave] #2724601
12/16/19 07:48 PM
12/16/19 07:48 PM
DE
DE
Ok good to know. I know both have 58 tooth reluctors but 2013 the reluctor is somehow different. Thanks
Re: 2012 hemi in 2013 ram help [Re: Hartlycooter] #2724734
12/17/19 10:37 AM
12/17/19 10:37 AM
Springtown Pa
Ray408G3Hemi Offline
Springtown Pa
09-12 are thinner than the 13's and later.
1963 Thunderbolt 496FE 10.80 (still a work in progress)
1968 Mustang slow a$$ 428 FE
1971 Boss 351 Mustang 11.20@115mph
1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA
1996 Viper GTS
2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor
2009 Ram 9.65@144MPH 463CI G3 NA
2010 Challenger 9.91 @ 139MPH 408CI G3ci NA
2019 F150 (local dealer's Lightning package) ..11.90s
Re: 2012 hemi in 2013 ram help [Re: Ray408G3Hemi] #2724866
12/17/19 03:45 PM
12/17/19 03:45 PM
DE
DE
So if i decide to do mmx drop in pistons and rods on this motor should i change out the reluctor to the 13 and newer while im in there?
Re: 2012 hemi in 2013 ram help [Re: Hartlycooter] #2724986
12/17/19 11:39 PM
12/17/19 11:39 PM
Springtown Pa
Springtown Pa
I don't think you can, I think it needs to stay with the thinner one...Honestly Not sure, I'd ask Dave Weber@ MMX when you buy the parts.
1996 Viper GTS
